I saw this issue:
and the documentation over here:
https://www.eclipse.org/smarthome/documentation/javadoc/org/eclipse/smarthome/core/library/items/ImageItem.html
As far as i know openHAB Beta 4 should already use ESH 0.9, am i right?
So i should theoretically be able to use the new Item Type. So the next question would be how to set the data for that item type. Is there a method to set the rawdata from an url For example, so that every time the cover art from plex or from the squeezebox changes i could refresh the Image Item via a rule.
