I’m using grafana graphs with the grafana image renderer and static images that I include with the Image element into my sitemap. I’m already pre-render the images and cache them to make them load fast in the sitemap.
Still I get a lot of image flickering, because on iOS with the openhab App the image is reloaded/re-rendered every time another item (on the same frame? I’m not sure) gets an update.
It’s not an Image refresh problem itself, I set that to a quite high value .. I don’t need to re-render graphs that often ( `Image refresh=100000 url=”…”`)
Is that a bug/known issue or am I doing something wrong?
I can not see this behaviour in the basic UI in the browser with the same sitemap.
