I’m trying to implement the default AngularJS Slider found in this site https://angular-slider.github.io/angularjs-slider/ but nothing is working.
I followed some guide and taken example from Habpanel source code in GitHub that uses what I want to use!
Here an example: https://github.com/openhab/org.openhab.ui.habpanel/blob/master/web/app/widgets/slider/slider.tpl.html. I want to implement a slider as the deafult widget, but I want to use a multi-range slider.
My code:
<div oc-lazy-load="['/static/habpanel/script.js', '/static/habpanel/script.js', '/static/habpanel/rzslider.js']"> <div ng-app="rzSliderDemo"> <div ng-controller="MainCtrl" class="wrapper"> <div class="row"> <div class="col-xs-12"> <rzslider rz-slider-model="range_slider_ticks_values.minValue" rz-slider-high="range_slider_ticks_values.maxValue" rz-slider-options="range_slider_ticks_values.options"></rzslider> </div> </div> </div> </div> </div>
var app = angular.module(‘rzSliderDemo’, [‘rzSlider’, ‘ui.bootstrap’]);
app.controller(‘MainCtrl’, function ($scope, $rootScope, $timeout, $modal) {
//Minimal slider config
$scope.minSlider = {
value: 10
};//Slider with selection bar $scope.slider_visible_bar = { value: 10, options: { showSelectionBar: true } }; //Range slider config $scope.minRangeSlider = { minValue: 10, maxValue: 90, options: { floor: 0, ceil: 100, step: 1 } }; //Slider with selection bar $scope.color_slider_bar = { value: 12, options: { showSelectionBar: true, getSelectionBarColor: function(value) { if (value <= 3) return 'red'; if (value <= 6) return 'orange'; if (value <= 9) return 'yellow'; return '#2AE02A'; } } }; //Slider config with floor, ceil and step $scope.slider_floor_ceil = { value: 12, options: { floor: 10, ceil: 100, step: 5 } }; //Slider config with callbacks $scope.slider_callbacks = { value: 100, options: { onStart: function () { $scope.otherData.start = $scope.slider_callbacks.value * 10; }, onChange: function () { $scope.otherData.change = $scope.slider_callbacks.value * 10; }, onEnd: function () { $scope.otherData.end = $scope.slider_callbacks.value * 10; } } }; $scope.otherData = { start: 0, change: 0, end: 0 }; //Slider config with custom display function $scope.slider_translate = { minValue: 100, maxValue: 400, options: { ceil: 500, floor: 0, translate: function (value) { return '$' + value; } } }; //Slider config with steps array of letters $scope.slider_alphabet = { value: 0, options: { stepsArray: 'ABCDEFGHIJKLMNOPQRSTUVWXYZ'.split('') } }; //Slider with ticks $scope.slider_ticks = { value: 5, options: { ceil: 10, floor: 0, showTicks: true } }; //Slider with ticks and values $scope.slider_ticks_values = { value: 5, options: { ceil: 10, floor: 0, showTicksValues: true } }; //Slider with ticks and values and tooltip $scope.slider_ticks_values_tooltip = { value: 5, options: { ceil: 10, floor: 0, showTicksValues: true, ticksValuesTooltip: function (v) { return 'Tooltip for ' + v; } } }; //Range slider with ticks and values $scope.range_slider_ticks_values = { minValue: 1, maxValue: 8, options: { ceil: 10, floor: 0, showTicksValues: true } }; //Slider with draggable range $scope.slider_draggable_range = { minValue: 1, maxValue: 8, options: { ceil: 10, floor: 0, draggableRange: true } }; //Slider with draggable range only $scope.slider_draggable_range_only = { minValue: 4, maxValue: 6, options: { ceil: 10, floor: 0, draggableRangeOnly: true } }; //Vertical sliders $scope.verticalSlider1 = { value: 0, options: { floor: 0, ceil: 10, vertical: true } }; $scope.verticalSlider2 = { minValue: 20, maxValue: 80, options: { floor: 0, ceil: 100, vertical: true } }; $scope.verticalSlider3 = { value: 5, options: { floor: 0, ceil: 10, vertical: true, showTicks: true } }; $scope.verticalSlider4 = { minValue: 1, maxValue: 5, options: { floor: 0, ceil: 6, vertical: true, showTicksValues: true } }; $scope.verticalSlider5 = { value: 50, options: { floor: 0, ceil: 100, vertical: true, showSelectionBar: true } }; $scope.verticalSlider6 = { value: 6, options: { floor: 0, ceil: 6, vertical: true, showSelectionBar: true, showTicksValues: true, ticksValuesTooltip: function (v) { return 'Tooltip for ' + v; } } }; //Read-only slider $scope.read_only_slider = { value: 50, options: { ceil: 100, floor: 0, readOnly: true } }; //Disabled slider $scope.disabled_slider = { value: 50, options: { ceil: 100, floor: 0, disabled: true } }; // Slider inside ng-show $scope.visible = false; $scope.slider_toggle = { value: 5, options: { ceil: 10, floor: 0 } }; $scope.toggle = function () { $scope.visible = !$scope.visible; $timeout(function () { $scope.$broadcast('rzSliderForceRender'); }); }; //Slider inside modal $scope.percentages = { normal: { low: 15 }, range: { low: 10, high: 50 } }; $scope.openModal = function () { var modalInstance = $modal.open({ templateUrl: 'sliderModal.html', controller: function ($scope, $modalInstance, values) { $scope.percentages = JSON.parse(JSON.stringify(values)); //Copy of the object in order to keep original values in $scope.percentages in parent controller. var formatToPercentage = function (value) { return value + '%'; }; $scope.percentages.normal.options = { floor: 0, ceil: 100, translate: formatToPercentage, showSelectionBar: true }; $scope.percentages.range.options = { floor: 0, ceil: 100, translate: formatToPercentage }; $scope.ok = function () { $modalInstance.close($scope.percentages); }; $scope.cancel = function () { $modalInstance.dismiss(); }; }, resolve: { values: function () { return $scope.percentages; } } }); modalInstance.result.then(function (percentages) { $scope.percentages = percentages; }); modalInstance.rendered.then(function () { $rootScope.$broadcast('rzSliderForceRender'); //Force refresh sliders on render. Otherwise bullets are aligned at left side. }); }; //Slider inside tabs $scope.tabSliders = { slider1: { value: 100 }, slider2: { value: 200 } }; $scope.refreshSlider = function () { $timeout(function () { $scope.$broadcast('rzSliderForceRender'); }); }; //Slider with draggable range $scope.slider_all_options = { minValue: 2, options: { floor: 0, ceil: 10, step: 1, precision: 0, draggableRange: false, showSelectionBar: false, hideLimitLabels: false, readOnly: false, disabled: false, showTicks: false, showTicksValues: false } }; $scope.toggleHighValue = function () { if ($scope.slider_all_options.maxValue != null) { $scope.slider_all_options.maxValue = undefined; } else { $scope.slider_all_options.maxValue = 8; } }
Please help!
