I had similar issues, ended up doing a big bang and migrated the essential stuff first, then moved on with less essential stuff.
Some things can sure sure be done on advance like if you use old mqtt notation etc.
Edit: 3500 items, 3000 lines of code but that is native java code.
If you do your things first without items and give them the same name/id as before, you can import your items without any change.
This also keeps your rules in the files working.
You can add semantic model later or leave it completely.
Thanks for the info, I wasnāt aware of that! But due to breaking changes in the rules DSL, I need to review all of themā¦ But if the item names remain, it would be a big step forward.
Thanks and sorry for going off topic in this thread!
@splatch I have only 170 things but the main amount of items is due to my crypto currency realtime monitorā¦ So basically I have about 15 items for each crypto currency which will get updated multiple times per minuteā¦
