Hi all, I’m new to openhab and I just installed the “astro binding”. However it doesn’t show that it has installed but when I check the log viewer it shows that it has been installed. I also did not receive any update in my inbox. I also tried manually searching for any “thing” for the network binding and nothing shows up either. Tried this did not help either, https://www.openhab.org/docs/tutorial/configuration.html
Anybody got a clue what’s wrong? I’m using a raspberrypi with 2.4.0 Release Build
It depends on your needs
You can still add network things manually via Configuration → Things → Network Binding → Add Things manually with the 2.4 release.
If you want to have your things auto-discovered, upgrade to the 2.5M1 Milestone build.
The log doesn’t say anything. I managed to add things manually and it’s working but I assume the ideal case would it to be able to search for things automatically.
