I’m using openHAB 2 on a raspberry PI 3 (openhabianpi) with the Razberry 2 (Z-Wave) module.
I tried to include two Z-Wave devices, but they are both shown as “unknown device”. No items are added.
Repeat the inclusion process again, and again, and - if required - again …
I had the same problem especially with the Fibaro motion sensor and learned, that the controller and the z-wave device sometimes need to communicate several times until all data of the device have been transmitted to the controller. Finally it worked.
I tried to include the motion sensor more then ten times, but I always got this warning in the openhab log:
2018-01-21 14:23:07.578 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 2: Device discovery could not resolve to a thingType! 7FFFFFFF:7FFFFFFF:7FFFFFFF::0.0
I found out, that the Razberry 2 Module was damaged (I tried to set up a Z-Way server, but I got the same problem).
Now I‘m using the Z-Wave USB stick.
