Hello I try to ivlude this smoke detector but it don’t run. It creates a new node but without content. I found some older blog here in this community but probably it’s unsolved.
The file “/var/lib/openhab/zwave/node19.xml” do not exist.
Is this smoke detector presently not part of openHAB?
Here is my log file:
2016-03-29 15:00:41.682 DEBUG o.o.b.z.i.p.s.AddNodeMessageClass[:84]- NODE 19: Adding slave.
2016-03-29 15:00:41.683 DEBUG o.o.b.z.i.p.ZWaveController[:648]- Notifying event listeners: ZWaveInclusionEvent
2016-03-29 15:00:41.684 DEBUG o.o.b.z.i.ZWaveActiveBinding[:449]- ZwaveIncomingEvent
2016-03-29 15:00:41.685 DEBUG o.o.b.z.i.p.s.ZWaveCommandProcessor[:66]- Sent message Message: class = AddNodeToNetwork (0x4A), type = Request (0x00), payload = 81 FF
2016-03-29 15:00:41.686 DEBUG o.o.b.z.i.p.s.ZWaveCommandProcessor[:67]- Recv message Message: class = AddNodeToNetwork (0x4A), type = Request (0x00), payload = FF 03 13 0E 04 A1 02 9C 31 86 72 70 85 8E 8B 56 84 80
2016-03-29 15:00:41.687 DEBUG o.o.b.z.i.p.s.ZWaveCommandProcessor[:68]- Checking transaction complete: class=AddNodeToNetwork, expected=AddNodeToNetwork, cancelled=false
2016-03-29 15:00:41.688 DEBUG o.o.b.z.i.p.s.ZWaveCommandProcessor[:74]- transaction complete!
2016-03-29 15:00:41.688 DEBUG o.o.b.z.i.p.ZWaveController[:648]- Notifying event listeners: ZWaveTransactionCompletedEvent
2016-03-29 15:00:41.689 DEBUG o.o.b.z.i.ZWaveActiveBinding[:449]- ZwaveIncomingEvent
2016-03-29 15:00:42.787 DEBUG o.o.b.z.i.p.ZWaveController$ZWaveReceiveThread[:1530]- Receive Message = 01 07 00 4A FF 05 13 00 5B
2016-03-29 15:00:42.806 DEBUG o.o.b.z.i.p.ZWaveController$ZWaveReceiveThread[:1446]- Receive queue ADD: Length=1
2016-03-29 15:00:42.806 DEBUG o.o.b.z.i.p.ZWaveController[:1194]- Receive queue TAKE: Length=0
2016-03-29 15:00:42.808 DEBUG o.o.b.z.i.p.SerialMessage[:243]- Assembled message buffer = 01 07 00 4A FF 05 13 00 5B
2016-03-29 15:00:42.809 DEBUG o.o.b.z.i.p.ZWaveController[:1195]- Process Message = 01 07 00 4A FF 05 13 00 5B
2016-03-29 15:00:42.810 DEBUG o.o.b.z.i.p.ZWaveController[:194]- Message: class = AddNodeToNetwork (0x4A), type = Request (0x00), payload = FF 05 13 00
2016-03-29 15:00:42.810 DEBUG o.o.b.z.i.p.s.AddNodeMessageClass[:94]- Add Node: Protocol done.
2016-03-29 15:00:42.811 DEBUG o.o.b.z.i.p.s.ZWaveCommandProcessor[:66]- Sent message Message: class = AddNodeToNetwork (0x4A), type = Request (0x00), payload = 81 FF
2016-03-29 15:00:42.812 DEBUG o.o.b.z.i.p.s.ZWaveCommandProcessor[:67]- Recv message Message: class = AddNodeToNetwork (0x4A), type = Request (0x00), payload = FF 05 13 00
2016-03-29 15:00:42.813 DEBUG o.o.b.z.i.p.s.ZWaveCommandProcessor[:68]- Checking transaction complete: class=AddNodeToNetwork, expected=AddNodeToNetwork, cancelled=false
2016-03-29 15:00:42.814 DEBUG o.o.b.z.i.p.s.ZWaveCommandProcessor[:74]- transaction complete!
2016-03-29 15:00:42.814 DEBUG o.o.b.z.i.p.ZWaveController[:648]- Notifying event listeners: ZWaveTransactionCompletedEvent
2016-03-29 15:00:42.815 DEBUG o.o.b.z.i.ZWaveActiveBinding[:449]- ZwaveIncomingEvent
016-03-29 15:02:13.806 DEBUG o.o.b.z.i.p.i.ZWaveNodeStageAdvancer[:1020]- NODE 19: Node advancer - WAIT: The WAIT is over!
2016-03-29 15:02:13.807 DEBUG o.o.b.z.i.p.i.ZWaveNodeStageAdvancer[:202]- NODE 19: Node advancer - checking initialisation queue. Queue size 0.
2016-03-29 15:02:13.807 DEBUG o.o.b.z.i.p.ZWaveController$ZWaveSendThread[:1364]- NODE 6: Response processed after 72ms/219ms.
2016-03-29 15:01:04.543 DEBUG o.o.b.z.i.ZWaveActiveBinding[:449]- ZwaveIncomingEvent
2016-03-29 15:01:04.543 DEBUG o.o.b.z.i.p.i.ZWaveNodeStageAdvancer[:1034]- NODE 19: Node advancer - FAILED_CHECK: Transaction complete (IsFailedNodeID:Request) success(true)
2016-03-29 15:01:04.544 DEBUG o.o.b.z.i.p.i.ZWaveNodeStageAdvancer[:202]- NODE 19: Node advancer - checking initialisation queue. Queue size 1.
2016-03-29 15:01:04.544 DEBUG o.o.b.z.i.p.i.ZWaveNodeStageAdvancer[:208]- NODE 19: Node advancer - message removed from queue. Queue size 0.
2016-03-29 15:01:04.545 DEBUG o.o.b.z.i.p.i.ZWaveNodeStageAdvancer[:267]- NODE 19: Node advancer - FAILED_CHECK: queue length(0), free to send(true)
2016-03-29 15:01:04.545 DEBUG o.o.b.z.i.p.i.ZWaveNodeStageAdvancer[:332]- NODE 19: Node advancer: loop - FAILED_CHECK try 1: stageAdvanced(false)
2016-03-29 15:01:04.546 DEBUG o.o.b.z.i.p.i.ZWaveNodeStageAdvancer[:890]- NODE 19: Node advancer - advancing to WAIT
2016-03-29 15:01:04.547 DEBUG o.o.b.z.i.p.i.ZWaveNodeStageAdvancer[:332]- NODE 19: Node advancer: loop - WAIT try 0: stageAdvanced(true)
2016-03-29 15:01:04.547 DEBUG o.o.b.z.i.p.i.ZWaveNodeStageAdvancer[:380]- NODE 19: Node advancer: WAIT - Listening=false, FrequentlyListening=false
2016-03-29 15:01:04.548 DEBUG o.o.b.z.i.p.i.ZWaveNodeStageAdvancer[:398]- NODE 19: Node advancer: WAIT - Still waiting!
2016-03-29 15:01:04.548 DEBUG o.o.b.z.i.p.ZWaveController$ZWaveSendThread[:1364]- NODE 255: Response processed after 51ms/219ms.
2016-03-29 15:01:31.373 DEBUG o.o.b.z.i.c.ZWaveConfiguration[:1095]- doSet domain ‘nodes/node19/Name’ to 'Rauchmelder 1’
2016-03-29 15:02:13.727 DEBUG o.o.b.z.i.ZWaveNetworkMonitor[:351]- NODE 6: Sending periodic PING.
2016-03-29 15:02:13.728 DEBUG o.o.b.z.i.p.c.ZWaveNoOperationCommandClass[:72]- NODE 6: Creating new message for command No Operation
2016-03-29 15:02:13.729 DEBUG o.o.b.z.i.p.SerialMessage[:113]- NODE 6: Creating empty message of class = SendData (0x13), type = Request (0x00)
2016-03-29 15:02:13.730 DEBUG o.o.b.z.i.p.ZWaveController[:947]- Callback ID = 131
