I have a bit of a strange issue which I need some help with. I have a bunch of lights in our living room, some z-wave, other hue, which I’d like to change together as various ‘scenes’. eg. cooking, dinner, tv. So I’ve setup a String
item that holds the current scene and rules that act on changes
.items
String Living_Room_Light_Scene
.rules
rule "Living Room: Switch to a new light scene"
Item Living_Room_Light_Scene received command
logInfo('debug', 'Light scene received a command: '+ receivedCommand)
if(receivedCommand == 'cooking') {
Wall_Switch_Kitchen_Downlights.sendCommand(ON)
Wall_Switch_Kitchen_Island.sendCommand(ON)
Wall_Switch_Dining_Room.sendCommand(20)
Living_Room_Play_Lamp_1_Dimmer.send(new HSBType(new DecimalType(30), new PercentType(60), new PercentType(90)))
Living_Room_Play_Lamp_2_Dimmer.send(new HSBType(new DecimalType(30), new PercentType(60), new PercentType(90)))
Wall_Switch_Living_Downlights_Rear.sendCommand(40)
Wall_Switch_Living_Downlights_Front.sendCommand(40)
Wall_Switch_Living_Sconce.sendCommand(30)
} else if(receivedCommand == 'dinner') {
Wall_Switch_Living_Downlights_Rear.sendCommand(OFF)
Wall_Switch_Living_Downlights_Front.sendCommand(OFF)
} else if(receivedCommand == 'tv') {
Wall_Switch_Kitchen_Downlights.sendCommand(OFF)
Wall_Switch_Dining_Room.sendCommand(OFF)
Living_Room_Play_Lamp_1_Dimmer.send(new HSBType(new DecimalType(30), new PercentType(60), new PercentType(30)))
Living_Room_Play_Lamp_2_Dimmer.send(new HSBType(new DecimalType(30), new PercentType(60), new PercentType(30)))
Wall_Switch_Living_Downlights_Rear.sendCommand(20)
Wall_Switch_Living_Downlights_Front.sendCommand(20)
Wall_Switch_Living_Sconce.sendCommand(8)
} else if(receivedCommand == 'movie') {
Wall_Switch_Kitchen_Island.sendCommand(OFF)
Living_Room_Play_Lamp_1_Dimmer.send(new HSBType(new DecimalType(30), new PercentType(60), new PercentType(10)))
Living_Room_Play_Lamp_2_Dimmer.send(new HSBType(new DecimalType(30), new PercentType(60), new PercentType(10)))
Wall_Switch_Living_Downlights_Front.sendCommand(10)
Wall_Switch_Living_Sconce.sendCommand(OFF)
} else if(receivedCommand == 'breakfast') {
Living_Room_Play_Lamp_1_Dimmer.sendCommand(OFF)
Living_Room_Play_Lamp_2_Dimmer.sendCommand(OFF)
} else if(receivedCommand == 'off') {
} else (
logInfo('debug', 'Light scene unknown ' + receivedCommand + '. Doing nothing..')
.sitemap
Frame label="Inside lights" icon="light" {
Switch item=Living_Room_Light_Scene label="Living Room" mappings=['off'='Off','cooking'='On']
Selection item=Living_Room_Light_Scene label="Scene:" icon="light" mappings=['cooking'='Cooking','breakfast'='Breakfast','tv'='TV - Dimmed','movie'='TV - Dark']
so far so good. I’ve added a field into the sitemap and when I make changes from the web or mobile apps, I get consistent, very fast (sub 2s) response times to the lighting changes.
Now, the problems start when I want to trigger the same scenes from click on a Hue Dimmer Switch (the 4 button one). I have a rule that listens for the button presses and then updates the Living_Room_Light_Scene
item - which I expected to occur very quickly.
Instead I am seeing either it working very slowly (4-10s) or not at all. While at other times, it appears to work fairly quickly. In all cases, I’m seeing my debug messages from the rule that runs on Dimmer button presses get triggered promptly, but the subsequent actions are either slow or never occur. Am I hitting some type of limit or issue? Here’s the rule listening for button presses:
rule "Manage Hue Dimmer switch button presses"
Channel "hue:0820:001788a0e258:14:dimmer_switch_event" triggered
var Number currentSceneId = 0;
if(Living_Room_Scene_Number.state == NULL) {
Living_Room_Scene_Number.postUpdate(0)
} else {
currentSceneId = Living_Room_Scene_Number.state
var newCommand = Hue_Remote_Kitchen_Button_Value.state.toString
var maxSceneId = 5
logInfo('debug', 'Button press found. Value: ' + newCommand )
// how about the on switch?
if( newCommand == '1002.0') {
if(Living_Room_Scene_Number.state == NULL || Living_Room_Scene_Number.state == UNDEF || Living_Room_Scene_Number.state == maxSceneId) {
currentSceneId = 0
currentSceneId = currentSceneId + 1
if(currentSceneId == 1) {
Living_Room_Light_Scene.sendCommand('cooking')
} else if(currentSceneId == 2) {
Living_Room_Light_Scene.sendCommand('dinner')
} else if(currentSceneId == 3) {
Living_Room_Light_Scene.sendCommand('tv')
} else if(currentSceneId == 4) {
Living_Room_Light_Scene.sendCommand('movie')
} else if(currentSceneId == 5) {
Living_Room_Light_Scene.sendCommand('breakfast')
Living_Room_Scene_Number.postUpdate(currentSceneId)
// off switch clicks
if( newCommand == '4002.0' || newCommand == '4000.0' ) {
currentSceneId = 0
Living_Room_Light_Scene.sendCommand('off')
My log is getting Info like this:
2022-02-21 17:09:14.643 [INFO ] [org.openhab.core.model.script.debug ] - Button press found. Value: 1002.0
2022-02-21 17:09:14.645 [INFO ] [org.openhab.core.model.script.debug ] - Light scene received a command: cooking
2022-02-21 17:09:19.247 [INFO ] [org.openhab.core.model.script.debug ] - Button press found. Value: 1002.0
2022-02-21 17:09:19.248 [INFO ] [org.openhab.core.model.script.debug ] - Light scene received a command: dinner
2022-02-21 17:09:21.805 [INFO ] [org.openhab.core.model.script.debug ] - Button press found. Value: 1002.0
2022-02-21 17:09:21.807 [INFO ] [org.openhab.core.model.script.debug ] - Light scene received a command: tv
2022-02-21 17:09:26.933 [INFO ] [org.openhab.core.model.script.debug ] - Button press found. Value: 1002.0
2022-02-21 17:09:26.933 [INFO ] [org.openhab.core.model.script.debug ] - Light scene received a command: movie
2022-02-21 17:09:28.466 [INFO ] [org.openhab.core.model.script.debug ] - Button press found. Value: 1002.0
2022-02-21 17:09:28.468 [INFO ] [org.openhab.core.model.script.debug ] - Light scene received a command: breakfast
2022-02-21 17:09:32.053 [INFO ] [org.openhab.core.model.script.debug ] - Button press found. Value: 1000.0
2022-02-21 17:09:32.564 [INFO ] [org.openhab.core.model.script.debug ] - Button press found. Value: 1002.0
2022-02-21 17:09:32.565 [INFO ] [org.openhab.core.model.script.debug ] - Light scene received a command: cooking
I’m running OpenHAB 3.2.0 on a VM instance in a Proxmox host, with 4Gb RAM and 2 cores of a Ryzen 5600G CPU. Seems plenty.
It appears to me that whether I change Living_Room_Light_Scene
from the Sitemap/UI or from another rule, it should behave the same. The fact it’s not has me perplexed. Can anyone provide some guidance or suggestions?
