Incorporating Matter
Sound like a good idea, i was also thinking about a larger change i want to make to add in the concept of a bridged node thing and some tweaks to endpoints, so i’ll want to flush those out before a beta.
Can you elaborate?
So for most devices today, we have a 1:1 mapping between node and endpoints, so a openHAB endpoint is really a matter node + endpoint, thats fine, and should stay the same. For nodes with multiple endpoints, like a thermostat with a humidity sensor, we now have 2 endpoints, which is awkward as now both have a dependency on a shared node that is not exposed, and this is not great for the user either. In the case i am proposing we have a single openHAB thing, with additional channels. So in this case, humidity is just an additional channel, not a new thing. My inovelli has 6 endpoints for color, buttons, etc… which are all things in openHAB, but would be way easier to manage as simply channels on a single thing.
Bridged Nodes are still just matter nodes, but are defined differently in the spec to be treated differently by clients. Here i propose we have a bridged node thing as a openHAB bridge type, and then child Bridged Endpoint things. The bridge node would expose its own channels on bridge information, allow for decommissioning and also act as a openHAB bridge does, reflecting the connectivity of the bridge, which then controls ThingStatus for its children.
I am going to just play around modeling this today to see how it would work, that will help me flush the idea out more.
For a Matter device, having always only one thing would be of course better if doable.
For hue, that would mean a bridge thing for the hue bridge and one child thing for each hue device. Makes sense also.
That would mean the configuration would need a list of endpoint IDs.
Hi there, I’m trying to connect a tasmota plug but can not quite make it work. After initiating the scan I get the following lines in the logs of the plug:
19:11:35.752 MTR: New Commissioning (PASE id=41925) from [fe80::abf:b8ff:fe3b:dcff%st1]:33277
19:11:35.918 MTR: MessageHandler::msg_received exception: value_error;Nonce size must be 7..13
I think the according log lines of the binding are these:
2024-11-29 19:11:35.384 [DEBUG] [nternal.client.MatterWebsocketClient] - sendMessage: {"id":"6687b112-e782-4726-b889-e7204644b3c3","namespace":"nodes","function":"pairNode","args":["05235813929"]}
2024-11-29 19:11:35.385 [TRACE] [internal.util.MatterWebsocketService] - Controller: Received request: {"id":"6687b112-e782-4726-b889-e7204644b3c3","namespace":"nodes","function":"pairNode","args":["05235813929"]}
2024-11-29 19:11:35.386 [TRACE] [internal.util.MatterWebsocketService] - ClientController: Executing function nodes.pairNode(["05235813929"])
2024-11-29 19:11:35.387 [DEBUG] [internal.util.MatterWebsocketService] - PeerCommissioner: Commissioning device with identifier {"shortDiscriminator":3} and 1 scanners and knownAddress "undefined"
2024-11-29 19:11:35.387 [DEBUG] [internal.util.MatterWebsocketService] - ControllerDiscovery: Start Discovering devices using identifier {"shortDiscriminator":3} ...
2024-11-29 19:11:35.387 [DEBUG] [internal.util.MatterWebsocketService] - ControllerDiscovery: Found 3 devices using identifier {"shortDiscriminator":3}
2024-11-29 19:11:35.387 [TRACE] [internal.util.MatterWebsocketService] - ControllerDiscovery: Server addresses to try: undefined: udp://fe80::da13:2aff:fe4b:1028%eth1:5540,undefined: udp://192.168.3.205:5540
2024-11-29 19:11:35.387 [TRACE] [internal.util.MatterWebsocketService] - ControllerDiscovery: Try to communicate with udp://fe80::da13:2aff:fe4b:1028%eth1:5540 ...
2024-11-29 19:11:35.387 [DEBUG] [internal.util.MatterWebsocketService] - PeerCommissioner: Commissioning device SII: 5000 SAI: 300 SAT: undefined T: 0 DT: undefined PH: undefined ICD: 0 VP: 65521+32768 DN: undefined RI: undefined PI: undefined
2024-11-29 19:11:35.388 [TRACE] [internal.util.MatterWebsocketService] - MessageExchange: New exchange channel: udp://fe80::da13:2aff:fe4b:1028%eth1:5540 on session insecure/7437816039900975752 protocol: 0 id: 61341 session: insecure/7437816039900975752 peerSessionId: 0 active threshold ms: 4000 active interval ms
: 300 idle interval ms: 5000 maxTransmissions: 5 useMrp: true
2024-11-29 19:11:35.388 [TRACE] [internal.util.MatterWebsocketService] - ExchangeManager: Message » id: 0/61341/125533754 type: 0/32 acked: undefined reqAck: true duplicate: false payload: 153001209b403d0741a420ad13f0ba57f3db9a88bbe3f62cbb0f7a501d7ab1723b03be7e25028e6a240300280435052501f40125022c012503a00f24041124
050c26060000030124070a1818
2024-11-29 19:11:35.537 [TRACE] [internal.util.MatterWebsocketService] - MessageExchange: Message « id: 0/61341/82190300 type: 0/33 acked: 125533754 reqAck: true duplicate: false payload: 153001209b403d0741a420ad13f0ba57f3db9a88bbe3f62cbb0f7a501d7ab1723b03be7e3002206282392e26a15ab5211d5cfcffa94f205b25bd204197f0cfe
271e5fc9c4ab7532503c5a335042501e8033002107433ba696cf73ec7cef69bebed04c7041818
2024-11-29 19:11:35.545 [TRACE] [internal.util.MatterWebsocketService] - ExchangeManager: Message » id: 0/61341/125533755 type: 0/34 acked: 82190300 reqAck: true duplicate: false payload: 15300141048d91fcf59f8d5097568e0c70d58818a3cdc82bf42c10ea7c94f46ce32e1a5bf9591c2a0749ffc23936f9aa8916e8da28739684888b6c031d3d270
b89a4ff02bd18
2024-11-29 19:11:35.948 [TRACE] [internal.util.MatterWebsocketService] - DeviceAdvertiser: Resubmission started, re-announce node 7437816039900975752
2024-11-29 19:11:35.948 [TRACE] [internal.util.MatterWebsocketService] - DeviceAdvertiser: Announcing fabric: 1
2024-11-29 19:11:35.949 [TRACE] [internal.util.MatterWebsocketService] - MessageExchange: Resubmit message 125533755 (retransmission attempt 1, backoff time 400ms))
2024-11-29 19:11:35.949 [TRACE] [internal.util.MatterWebsocketService] - ExchangeManager: Message » id: 0/61341/125533755 type: 0/34 acked: 82190300 reqAck: true duplicate: false payload: 15300141048d91fcf59f8d5097568e0c70d58818a3cdc82bf42c10ea7c94f46ce32e1a5bf9591c2a0749ffc23936f9aa8916e8da28739684888b6c031d3d270
b89a4ff02bd18
2024-11-29 19:11:36.262 [TRACE] [internal.util.MatterWebsocketService] - MessageExchange: Message « id: 0/61341/82190301 type: 0/35 acked: 125533755 reqAck: true duplicate: false payload: 1530014104a5f3e9a4f0e54b0943de354cb4837ce62b9a5382d6cdf3578eed5f6226dec6725417811d5fc1c9909230ea0185af698234055ba6b9faf7b99bd62
be6e453f705300220f1acfee2f6d3a50307afe97b7b5df756e32c7b062a5db097833598265b2c31b318
2024-11-29 19:11:36.281 [TRACE] [internal.util.MatterWebsocketService] - ExchangeManager: Message » id: 0/61341/125533756 type: 0/36 acked: 82190301 reqAck: true duplicate: false payload: 15300120f0e097d8a21a0db1fd5d22ae49c5c6015a1d82f021b61fcd37d73feed463bf8618
2024-11-29 19:11:36.351 [TRACE] [internal.util.MatterWebsocketService] - MessageExchange: Message « id: 0/61341/82190302 type: 0/64 acked: 125533756 reqAck: false duplicate: false payload: 00000000000000000000
2024-11-29 19:11:36.351 [TRACE] [internal.util.MatterWebsocketService] - SecureSession: Created secure PASE session for fabric index undefined secure/27278 idleIntervalMs: 5000 activeIntervalMs: 300 activeThresholdMs: 4000 dataModelRevision: 17 interactionModelRevision: 11 specificationVersion: 0 maxPathsPerInvoke
: 1 caseAuthenticatedTags:
2024-11-29 19:11:36.352 [DEBUG] [internal.util.MatterWebsocketService] - PaseClient: Pase client: Paired successfully with udp://fe80::da13:2aff:fe4b:1028%eth1:5540.
2024-11-29 19:11:36.352 [DEBUG] [internal.util.MatterWebsocketService] - InsecureSession: End insecure session insecure/7437816039900975752
2024-11-29 19:11:36.352 [DEBUG] [internal.util.MatterWebsocketService] - PeerCommissioner: Start commissioning of node 4017621861095916441 into fabric 1 (index 1)
2024-11-29 19:11:36.352 [TRACE] [internal.util.MatterWebsocketService] - Controller~missioner: Commissioning options: {"regulatoryLocation":1,"regulatoryCountryCode":"XX","nodeId":"undefined","wifiNetwork":{"wifiSsid":"","wifiCredentials":""},"threadNetwork":{"networkName":"","operationalDataset":""},"fabric":{"fa
bricIndex":1,"fabricId":"1","nodeId":"2043585585612848172","rootNodeId":"2043585585612848172","operationalId":"cdc71343318b253c","rootPublicKey":"04db5795618fd8a4e75ebc93ad75793f5fbb43d686de133f2c1db31f38559dfd8a6512430f6e83921adf43ed61f3d0ce4a458b56b64b19918750f1ca8d6b240081","rootVendorId":65521,"rootCert":"1530
0101002402013703241400182604378bfb2c2605b7c1a84137062414001824070124080130094104db5795618fd8a4e75ebc93ad75793f5fbb43d686de133f2c1db31f38559dfd8a6512430f6e83921adf43ed61f3d0ce4a458b56b64b19918750f1ca8d6b240081370a35012901182402603004140d3813087187f3f867633044bf5740fdaad506d13005140d3813087187f3f867633044bf5740fdaad
506d118300b40d1dad3ec822a494c67dfeca67a7aee8db390bf4cbca837c626117ea75e6abbebf77582e26f08f8b1deaf4be90d3bf6c69f7dd22b5de9b3a969759a0ef3c3bacc18","identityProtectionKey":"0e02f7b53c7769c428b8ea5abf3a7a2a","operationalIdentityProtectionKey":"dd05d6f7bea0ad903b636d4b5a1c7e5a","intermediateCACert":"undefined","operati
onalCert":"15300101012402013703241400182604378bfb2c2605b7c1a841370624150127112cfc8f4243465c1c1824070124080130094104793d2d127424e62d3abc2ce75089a5ac10b802e6c1202bae3c122fe670bc70757d4bbd014ecaccec875579a25d3d017e90a4de5178da5346b5da9c5cb1aa01a7370a3501280118240201360304020401183004141245fad1714d4730560f3c1f3d288c68
34cb33723005140d3813087187f3f867633044bf5740fdaad506d118300b40f368cf3bac85f8f158d3e0f532b44c15e6ca1cb93fd2b022d2da1c04055487c0de785be21a46d309bebb19026a3ef53cb7b66235bac94cae52f7da3f3d89433218","label":""},"discovery":{"knownAddress":"undefined","identifierData":{"shortDiscriminator":3},"discoveryCapabilities":{"b
le":false,"onIpNetwork":true}},"passcode":22809734}
2024-11-29 19:11:36.352 [DEBUG] [internal.util.MatterWebsocketService] - Controller~missioner: Skipping NetworkCommissioning steps because the device is already on IP network (udp)
2024-11-29 19:11:36.353 [DEBUG] [internal.util.MatterWebsocketService] - Controller~missioner: Executing commissioning step 0.1: GetInitialData
2024-11-29 19:11:36.353 [TRACE] [internal.util.MatterWebsocketService] - Controller~missioner: Creating new cluster client for cluster Descriptor (endpoint 0, isFeatureSpecific false)
2024-11-29 19:11:36.353 [TRACE] [internal.util.MatterWebsocketService] - InteractionClient: Sending read request: attributes: 0x0/Descriptor(0x1d)/partsList(0x3) and events: undefined
2024-11-29 19:11:36.353 [TRACE] [internal.util.MatterWebsocketService] - MessageExchange: New exchange channel: udp://fe80::da13:2aff:fe4b:1028%eth1:5540 on session secure/27278 protocol: 1 id: 61342 session: secure/27278 peerSessionId: 41925 active threshold ms: 4000 active interval ms: 300 idle interval ms: 5000
2024-11-29 19:11:36.353 [TRACE] [internal.util.MatterWebsocketService] - InteractionClient: Sending read request to udp://fe80::da13:2aff:fe4b:1028%eth1:5540 on session secure/27278 for attributes 0x0/Descriptor(0x1d)/partsList(0x3) and events undefined
2024-11-29 19:11:36.354 [TRACE] [internal.util.MatterWebsocketService] - ExchangeManager: Message » id: 41925/61342/161861642 type: 1/2 acked: undefined reqAck: true duplicate: false payload: 1536001724020024031d2404031818290324ff0c18
2024-11-29 19:11:36.756 [TRACE] [internal.util.MatterWebsocketService] - DeviceAdvertiser: Resubmission started, re-announce node 0
2024-11-29 19:11:36.756 [TRACE] [internal.util.MatterWebsocketService] - DeviceAdvertiser: Announcing fabric: 1
2024-11-29 19:11:36.757 [TRACE] [internal.util.MatterWebsocketService] - MessageExchange: Resubmit message 161861642 (retransmission attempt 1, backoff time 335ms))
2024-11-29 19:11:36.757 [TRACE] [internal.util.MatterWebsocketService] - ExchangeManager: Message » id: 41925/61342/161861642 type: 1/2 acked: undefined reqAck: true duplicate: false payload: 1536001724020024031d2404031818290324ff0c18
2024-11-29 19:11:38.681 [TRACE] [internal.util.MatterWebsocketService] - MessageExchange: Resubmit message 161861642 (retransmission attempt 4, backoff time 1525ms))
2024-11-29 19:11:38.681 [TRACE] [internal.util.MatterWebsocketService] - ExchangeManager: Message » id: 41925/61342/161861642 type: 1/2 acked: undefined reqAck: true duplicate: false payload: 1536001724020024031d2404031818290324ff0c18
2024-11-29 19:11:40.206 [TRACE] [internal.util.MatterWebsocketService] - MessageExchange: Wait additional 4704ms for processing time and peer resubmissions after all our resubmissions
2024-11-29 19:11:40.418 [DEBUG] [internal.util.MatterWebsocketService] - CaseServer: An error occurred during the commissioning RetransmissionLimitReachedError
2024-11-29 19:11:40.418 [DEBUG] [internal.util.MatterWebsocketService] - InsecureSession: End insecure session insecure/11750243087572098096
2024-11-29 19:11:40.418 [TRACE] [internal.util.MatterWebsocketService] - none:   at #retransmitMessage (webpack://matter-server/./node_modules/@matter/protocol/dist/cjs/protocol/MessageExchange.js?:393:37)
2024-11-29 19:11:40.418 [TRACE] [internal.util.MatterWebsocketService] - none:   at StandardTimer.eval [as callback] (webpack://matter-server/./node_modules/@matter/protocol/dist/cjs/protocol/MessageExchange.js?:386:42)
2024-11-29 19:11:40.418 [DEBUG] [internal.util.MatterWebsocketService] - ExchangeManager: The previous message has not been acked yet, cannot send a new message.
2024-11-29 19:11:40.418 [TRACE] [internal.util.MatterWebsocketService] - none:   at Timeout.eval [as _onTimeout] (webpack://matter-server/./node_modules/@matter/general/dist/cjs/time/Time.js?:134:12)
2024-11-29 19:11:40.418 [TRACE] [internal.util.MatterWebsocketService] - none:   at listOnTimeout (node:internal/timers:573:17)
2024-11-29 19:11:40.419 [TRACE] [internal.util.MatterWebsocketService] - none:   at process.processTimers (node:internal/timers:514:7)
I’m not sure if that’s a problem with the binding or the plug, but I could connect the plug to Google Home just fine, jfwiw. If there’s anything I can do to test or debug further please let me know :slight_smile:
If you paired it with Goole Home, what pairing code are you using to commission with openHAB?
I’m using the one the plug gives me when enabling commisioning. Which seems to always be the same, even when repeating the process or adding or removing the Google Home association.
And the same error occurs also when there’s no other association in the plug.
Sorry, where do these lines show up? they are not int the other logs you posted so i don’t understand where are seeing those in context to the pairing process. i would need a complete log dump form the time you hit scan until it gets a retransmission error. There will be a lot of logs, but its necessary to have all of them to troubleshoot.
Once the device is paired with a controller, the device pairing code is no longer valid. If you remove the device from all controllers (and they tell the device to remove themselves) or hard reset the device then the original pairing code will work again. So i need to know exactly what you have done before the commissioning process with openHAB to help troubleshoot.
See device-pairing-general in the readme for a little more explination (it also mentioned somewhere else in the readme too)
Alright, got it. But the problem doesn’t seem to be related to the Google Home pairing. I only added the plug to GH after I couldn’t make it work in openhab.
I just reset the plug and started all over (no GH involved at all). These are the logs from the scan process:
2024-11-29 20:02:02.380 [DEBUG] [nternal.client.MatterWebsocketClient] - sendMessage: {"id":"c1cf358b-1e39-40f1-9fa3-55e4ae315e12","namespace":"nodes","function":"pairNode","args":["30582449783"]}
2024-11-29 20:02:02.382 [TRACE] [internal.util.MatterWebsocketService] - Controller: Received request: {"id":"c1cf358b-1e39-40f1-9fa3-55e4ae315e12","namespace":"nodes","function":"pairNode","args":["30582449783"]}
2024-11-29 20:02:02.383 [TRACE] [internal.util.MatterWebsocketService] - ClientController: Executing function nodes.pairNode(["30582449783"])
2024-11-29 20:02:02.384 [DEBUG] [internal.util.MatterWebsocketService] - PeerCommissioner: Commissioning device with identifier {"shortDiscriminator":12} and 1 scanners and knownAddress "undefined"
2024-11-29 20:02:02.384 [DEBUG] [internal.util.MatterWebsocketService] - ControllerDiscovery: Start Discovering devices using identifier {"shortDiscriminator":12} ...
2024-11-29 20:02:02.384 [DEBUG] [internal.util.MatterWebsocketService] - ControllerDiscovery: Found 1 devices using identifier {"shortDiscriminator":12}
2024-11-29 20:02:02.385 [TRACE] [internal.util.MatterWebsocketService] - ControllerDiscovery: Server addresses to try: undefined: udp://fe80::da13:2aff:fe4b:1028%eth1:5540,undefined: udp://192.168.3.205:5540
2024-11-29 20:02:02.385 [TRACE] [internal.util.MatterWebsocketService] - ControllerDiscovery: Try to communicate with udp://fe80::da13:2aff:fe4b:1028%eth1:5540 ...
2024-11-29 20:02:02.385 [DEBUG] [internal.util.MatterWebsocketService] - PeerCommissioner: Commissioning device SII: 5000 SAI: 300 SAT: undefined T: 0 DT: undefined PH: undefined ICD: 0 VP: 65521+32768 DN: undefined RI: undefined PI: undefined
2024-11-29 20:02:02.385 [TRACE] [internal.util.MatterWebsocketService] - MessageExchange: New exchange channel: udp://fe80::da13:2aff:fe4b:1028%eth1:5540 on session insecure/9675013274245749261 protocol: 0 id: 61346 session: insecure/9675013274245749261 peerSessionId: 0 active threshold ms: 4000 active interval ms: 300 idle interval ms: 5000 maxTransmissions: 5 useMrp: true
2024-11-29 20:02:02.386 [TRACE] [internal.util.MatterWebsocketService] - ExchangeManager: Message » id: 0/61346/125533763 type: 0/32 acked: undefined reqAck: true duplicate: false payload: 15300120e0165505ed067558e6e2f9df120eb465873cef0c46b1187f4e8139ca07ae47792502916a240300280435052501f40125022c012503a00f24041124050c26060000030124070a1818
2024-11-29 20:02:02.591 [TRACE] [internal.util.MatterWebsocketService] - MessageExchange: Message « id: 0/61346/15528849 type: 0/33 acked: 125533763 reqAck: true duplicate: false payload: 15300120e0165505ed067558e6e2f9df120eb465873cef0c46b1187f4e8139ca07ae4779300220eb7a01d33a9246432fa2eae4d0d3b76e5ee9d72fe64321ecc72c4283daf325732503929735042501e8033002104b678554546ad1493b593cca8ea481cf1818
2024-11-29 20:02:02.604 [TRACE] [internal.util.MatterWebsocketService] - ExchangeManager: Message » id: 0/61346/125533764 type: 0/34 acked: 15528849 reqAck: true duplicate: false payload: 1530014104f78286a91ccc582f2e1e2eed83cc517b620db9c4f7fc43ddad223356c0be525514227b711488ce648ca6a93a0530d3ddb3109d131e24fee1882765c893ac099a18
2024-11-29 20:02:02.981 [TRACE] [internal.util.MatterWebsocketService] - DeviceAdvertiser: Resubmission started, re-announce node 9675013274245749261
2024-11-29 20:02:02.982 [TRACE] [internal.util.MatterWebsocketService] - DeviceAdvertiser: Announcing fabric: 1
2024-11-29 20:02:02.982 [TRACE] [internal.util.MatterWebsocketService] - MessageExchange: Resubmit message 125533764 (retransmission attempt 1, backoff time 385ms))
2024-11-29 20:02:02.982 [TRACE] [internal.util.MatterWebsocketService] - ExchangeManager: Message » id: 0/61346/125533764 type: 0/34 acked: 15528849 reqAck: true duplicate: false payload: 1530014104f78286a91ccc582f2e1e2eed83cc517b620db9c4f7fc43ddad223356c0be525514227b711488ce648ca6a93a0530d3ddb3109d131e24fee1882765c893ac099a18
2024-11-29 20:02:02.999 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 5d3e66201db6817d/7835080616108383874 qname: 5D3E66201DB6817D-6CBBCC4EEDB05E82._matter._tcp.local port: 59600 interface: eth1
2024-11-29 20:02:02.999 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 5d3e66201db6817d/7835080616108383874 qname: 5D3E66201DB6817D-6CBBCC4EEDB05E82._matter._tcp.local port: 59600 interface: docker0
2024-11-29 20:02:02.999 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 5d3e66201db6817d/7835080616108383874 qname: 5D3E66201DB6817D-6CBBCC4EEDB05E82._matter._tcp.local port: 59600 interface: br-3e21d1d2b60e
2024-11-29 20:02:02.999 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 5d3e66201db6817d/7835080616108383874 qname: 5D3E66201DB6817D-6CBBCC4EEDB05E82._matter._tcp.local port: 59600 interface: br-7ac25da1f717
2024-11-29 20:02:02.999 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 5d3e66201db6817d/7835080616108383874 qname: 5D3E66201DB6817D-6CBBCC4EEDB05E82._matter._tcp.local port: 59600 interface: br-9dd9e484c2d8
2024-11-29 20:02:02.999 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 5d3e66201db6817d/7835080616108383874 qname: 5D3E66201DB6817D-6CBBCC4EEDB05E82._matter._tcp.local port: 59600 interface: br-0ac7bf6ea376
2024-11-29 20:02:02.999 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 5d3e66201db6817d/7835080616108383874 qname: 5D3E66201DB6817D-6CBBCC4EEDB05E82._matter._tcp.local port: 59600 interface: br-10b953e5e977
2024-11-29 20:02:02.999 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 5d3e66201db6817d/7835080616108383874 qname: 5D3E66201DB6817D-6CBBCC4EEDB05E82._matter._tcp.local port: 59600 interface: br-7837f96b44e0
2024-11-29 20:02:02.999 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 5d3e66201db6817d/7835080616108383874 qname: 5D3E66201DB6817D-6CBBCC4EEDB05E82._matter._tcp.local port: 59600 interface: veth9f63a6c
2024-11-29 20:02:02.999 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 5d3e66201db6817d/7835080616108383874 qname: 5D3E66201DB6817D-6CBBCC4EEDB05E82._matter._tcp.local port: 59600 interface: veth38c5666
2024-11-29 20:02:02.999 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 5d3e66201db6817d/7835080616108383874 qname: 5D3E66201DB6817D-6CBBCC4EEDB05E82._matter._tcp.local port: 59600 interface: veth1aa2676
2024-11-29 20:02:02.999 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 5d3e66201db6817d/7835080616108383874 qname: 5D3E66201DB6817D-6CBBCC4EEDB05E82._matter._tcp.local port: 59600 interface: veth73b0f7c
2024-11-29 20:02:02.999 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 5d3e66201db6817d/7835080616108383874 qname: 5D3E66201DB6817D-6CBBCC4EEDB05E82._matter._tcp.local port: 59600 interface: veth4a180e0
2024-11-29 20:02:02.999 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 5d3e66201db6817d/7835080616108383874 qname: 5D3E66201DB6817D-6CBBCC4EEDB05E82._matter._tcp.local port: 59600 interface: veth0ff681f
2024-11-29 20:02:02.999 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 5d3e66201db6817d/7835080616108383874 qname: 5D3E66201DB6817D-6CBBCC4EEDB05E82._matter._tcp.local port: 59600 interface: veth6edbc88
2024-11-29 20:02:02.999 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 5d3e66201db6817d/7835080616108383874 qname: 5D3E66201DB6817D-6CBBCC4EEDB05E82._matter._tcp.local port: 59600 interface: veth1fa94de
2024-11-29 20:02:03.000 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 5d3e66201db6817d/7835080616108383874 qname: 5D3E66201DB6817D-6CBBCC4EEDB05E82._matter._tcp.local port: 59600 interface: vethe2c91fe
2024-11-29 20:02:03.000 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 5d3e66201db6817d/7835080616108383874 qname: 5D3E66201DB6817D-6CBBCC4EEDB05E82._matter._tcp.local port: 59600 interface: veth2318292
2024-11-29 20:02:03.000 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 5d3e66201db6817d/7835080616108383874 qname: 5D3E66201DB6817D-6CBBCC4EEDB05E82._matter._tcp.local port: 59600 interface: vethf25a038
2024-11-29 20:02:03.008 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 785e8ace71dca77f/639902294 qname: 785E8ACE71DCA77F-0000000026242256._matter._tcp.local port: 5540 interface: eth1
2024-11-29 20:02:03.008 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 785e8ace71dca77f/639902294 qname: 785E8ACE71DCA77F-0000000026242256._matter._tcp.local port: 5540 interface: docker0
2024-11-29 20:02:03.008 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 785e8ace71dca77f/639902294 qname: 785E8ACE71DCA77F-0000000026242256._matter._tcp.local port: 5540 interface: br-3e21d1d2b60e
2024-11-29 20:02:03.008 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 785e8ace71dca77f/639902294 qname: 785E8ACE71DCA77F-0000000026242256._matter._tcp.local port: 5540 interface: br-7ac25da1f717
2024-11-29 20:02:03.008 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 785e8ace71dca77f/639902294 qname: 785E8ACE71DCA77F-0000000026242256._matter._tcp.local port: 5540 interface: br-9dd9e484c2d8
2024-11-29 20:02:03.008 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 785e8ace71dca77f/639902294 qname: 785E8ACE71DCA77F-0000000026242256._matter._tcp.local port: 5540 interface: br-0ac7bf6ea376
2024-11-29 20:02:03.008 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 785e8ace71dca77f/639902294 qname: 785E8ACE71DCA77F-0000000026242256._matter._tcp.local port: 5540 interface: br-10b953e5e977
2024-11-29 20:02:03.008 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 785e8ace71dca77f/639902294 qname: 785E8ACE71DCA77F-0000000026242256._matter._tcp.local port: 5540 interface: br-7837f96b44e0
2024-11-29 20:02:03.008 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 785e8ace71dca77f/639902294 qname: 785E8ACE71DCA77F-0000000026242256._matter._tcp.local port: 5540 interface: veth9f63a6c
2024-11-29 20:02:03.008 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 785e8ace71dca77f/639902294 qname: 785E8ACE71DCA77F-0000000026242256._matter._tcp.local port: 5540 interface: veth38c5666
2024-11-29 20:02:03.008 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 785e8ace71dca77f/639902294 qname: 785E8ACE71DCA77F-0000000026242256._matter._tcp.local port: 5540 interface: veth1aa2676
2024-11-29 20:02:03.008 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 785e8ace71dca77f/639902294 qname: 785E8ACE71DCA77F-0000000026242256._matter._tcp.local port: 5540 interface: veth73b0f7c
2024-11-29 20:02:03.008 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 785e8ace71dca77f/639902294 qname: 785E8ACE71DCA77F-0000000026242256._matter._tcp.local port: 5540 interface: veth4a180e0
2024-11-29 20:02:03.008 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 785e8ace71dca77f/639902294 qname: 785E8ACE71DCA77F-0000000026242256._matter._tcp.local port: 5540 interface: veth0ff681f
2024-11-29 20:02:03.008 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 785e8ace71dca77f/639902294 qname: 785E8ACE71DCA77F-0000000026242256._matter._tcp.local port: 5540 interface: veth6edbc88
2024-11-29 20:02:03.008 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 785e8ace71dca77f/639902294 qname: 785E8ACE71DCA77F-0000000026242256._matter._tcp.local port: 5540 interface: veth1fa94de
2024-11-29 20:02:03.009 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 785e8ace71dca77f/639902294 qname: 785E8ACE71DCA77F-0000000026242256._matter._tcp.local port: 5540 interface: vethe2c91fe
2024-11-29 20:02:03.009 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 785e8ace71dca77f/639902294 qname: 785E8ACE71DCA77F-0000000026242256._matter._tcp.local port: 5540 interface: veth2318292
2024-11-29 20:02:03.009 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 785e8ace71dca77f/639902294 qname: 785E8ACE71DCA77F-0000000026242256._matter._tcp.local port: 5540 interface: vethf25a038
2024-11-29 20:02:03.017 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: cdc71343318b253c/2043585585612848172 qname: CDC71343318B253C-1C5C4643428FFC2C._matter._tcp.local port: 33277 interface: eth1
2024-11-29 20:02:03.017 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: cdc71343318b253c/2043585585612848172 qname: CDC71343318B253C-1C5C4643428FFC2C._matter._tcp.local port: 33277 interface: docker0
2024-11-29 20:02:03.017 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: cdc71343318b253c/2043585585612848172 qname: CDC71343318B253C-1C5C4643428FFC2C._matter._tcp.local port: 33277 interface: br-3e21d1d2b60e
2024-11-29 20:02:03.017 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: cdc71343318b253c/2043585585612848172 qname: CDC71343318B253C-1C5C4643428FFC2C._matter._tcp.local port: 33277 interface: br-7ac25da1f717
2024-11-29 20:02:03.017 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: cdc71343318b253c/2043585585612848172 qname: CDC71343318B253C-1C5C4643428FFC2C._matter._tcp.local port: 33277 interface: br-9dd9e484c2d8
2024-11-29 20:02:03.017 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: cdc71343318b253c/2043585585612848172 qname: CDC71343318B253C-1C5C4643428FFC2C._matter._tcp.local port: 33277 interface: br-0ac7bf6ea376
2024-11-29 20:02:03.017 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: cdc71343318b253c/2043585585612848172 qname: CDC71343318B253C-1C5C4643428FFC2C._matter._tcp.local port: 33277 interface: br-10b953e5e977
2024-11-29 20:02:03.017 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: cdc71343318b253c/2043585585612848172 qname: CDC71343318B253C-1C5C4643428FFC2C._matter._tcp.local port: 33277 interface: br-7837f96b44e0
2024-11-29 20:02:03.017 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: cdc71343318b253c/2043585585612848172 qname: CDC71343318B253C-1C5C4643428FFC2C._matter._tcp.local port: 33277 interface: veth9f63a6c
2024-11-29 20:02:03.017 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: cdc71343318b253c/2043585585612848172 qname: CDC71343318B253C-1C5C4643428FFC2C._matter._tcp.local port: 33277 interface: veth38c5666
2024-11-29 20:02:03.017 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: cdc71343318b253c/2043585585612848172 qname: CDC71343318B253C-1C5C4643428FFC2C._matter._tcp.local port: 33277 interface: veth1aa2676
2024-11-29 20:02:03.017 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: cdc71343318b253c/2043585585612848172 qname: CDC71343318B253C-1C5C4643428FFC2C._matter._tcp.local port: 33277 interface: veth73b0f7c
2024-11-29 20:02:03.017 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: cdc71343318b253c/2043585585612848172 qname: CDC71343318B253C-1C5C4643428FFC2C._matter._tcp.local port: 33277 interface: veth4a180e0
2024-11-29 20:02:03.018 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: cdc71343318b253c/2043585585612848172 qname: CDC71343318B253C-1C5C4643428FFC2C._matter._tcp.local port: 33277 interface: veth0ff681f
2024-11-29 20:02:03.018 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: cdc71343318b253c/2043585585612848172 qname: CDC71343318B253C-1C5C4643428FFC2C._matter._tcp.local port: 33277 interface: veth6edbc88
2024-11-29 20:02:03.018 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: cdc71343318b253c/2043585585612848172 qname: CDC71343318B253C-1C5C4643428FFC2C._matter._tcp.local port: 33277 interface: veth1fa94de
2024-11-29 20:02:03.018 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: cdc71343318b253c/2043585585612848172 qname: CDC71343318B253C-1C5C4643428FFC2C._matter._tcp.local port: 33277 interface: vethe2c91fe
2024-11-29 20:02:03.018 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: cdc71343318b253c/2043585585612848172 qname: CDC71343318B253C-1C5C4643428FFC2C._matter._tcp.local port: 33277 interface: veth2318292
2024-11-29 20:02:03.018 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: cdc71343318b253c/2043585585612848172 qname: CDC71343318B253C-1C5C4643428FFC2C._matter._tcp.local port: 33277 interface: vethf25a038
2024-11-29 20:02:03.035 [TRACE] [internal.util.MatterWebsocketService] - MdnsScanner: Adding operational device CDC71343318B253C-1C5C4643428FFC2C._matter._tcp.local in cache (interface eth1, ttl=120) with TXT data: SII: 500 SAI: 300 SAT: 4000 T: 0 DT: undefined PH: undefined ICD: 0 VP: undefined DN: undefined RI: undefined PI: undefined
2024-11-29 20:02:03.285 [TRACE] [internal.util.MatterWebsocketService] - MessageExchange: Message « id: 0/61346/15528850 type: 0/35 acked: 125533764 reqAck: true duplicate: false payload: 15300141044076184f7dcb99dc395f6919945327e8ff1deadcbf4b149fc0310cc82e04f484e49afca52b11ffa5080a44f9fc17811c2b91ee1e75efb67ff1e24d732864208e30022060b3d51c3fc099e773f03d9e13481621f29e755909d8accc5be72a1753a7843f18
2024-11-29 20:02:03.294 [TRACE] [internal.util.MatterWebsocketService] - ExchangeManager: Message » id: 0/61346/125533765 type: 0/36 acked: 15528850 reqAck: true duplicate: false payload: 15300120ffe4ba236b93b0e56c4c668f0ac2cebe9cd19fad1a87db09aafb6df0d654ad2718
2024-11-29 20:02:03.380 [TRACE] [internal.util.MatterWebsocketService] - MessageExchange: Message « id: 0/61346/15528851 type: 0/64 acked: 125533765 reqAck: false duplicate: false payload: 00000000000000000000
2024-11-29 20:02:03.380 [TRACE] [internal.util.MatterWebsocketService] - SecureSession: Created secure PASE session for fabric index undefined secure/27281 idleIntervalMs: 5000 activeIntervalMs: 300 activeThresholdMs: 4000 dataModelRevision: 17 interactionModelRevision: 11 specificationVersion: 0 maxPathsPerInvoke: 1 caseAuthenticatedTags:
2024-11-29 20:02:03.380 [DEBUG] [internal.util.MatterWebsocketService] - PaseClient: Pase client: Paired successfully with udp://fe80::da13:2aff:fe4b:1028%eth1:5540.
2024-11-29 20:02:03.380 [DEBUG] [internal.util.MatterWebsocketService] - InsecureSession: End insecure session insecure/9675013274245749261
2024-11-29 20:02:03.380 [DEBUG] [internal.util.MatterWebsocketService] - PeerCommissioner: Start commissioning of node 7666489036447945721 into fabric 1 (index 1)
2024-11-29 20:02:03.380 [TRACE] [internal.util.MatterWebsocketService] - Controller~missioner: Commissioning options: {"regulatoryLocation":1,"regulatoryCountryCode":"XX","nodeId":"undefined","wifiNetwork":{"wifiSsid":"","wifiCredentials":""},"threadNetwork":{"networkName":"","operationalDataset":""},"fabric":{"fabricIndex":1,"fabricId":"1","nodeId":"2043585585612848172","rootNodeId":"2043585585612848172","operationalId":"cdc71343318b253c","rootPublicKey":"04db5795618fd8a4e75ebc93ad75793f5fbb43d686de133f2c1db31f38559dfd8a6512430f6e83921adf43ed61f3d0ce4a458b56b64b19918750f1ca8d6b240081","rootVendorId":65521,"rootCert":"15300101002402013703241400182604378bfb2c2605b7c1a84137062414001824070124080130094104db5795618fd8a4e75ebc93ad75793f5fbb43d686de133f2c1db31f38559dfd8a6512430f6e83921adf43ed61f3d0ce4a458b56b64b19918750f1ca8d6b240081370a35012901182402603004140d3813087187f3f867633044bf5740fdaad506d13005140d3813087187f3f867633044bf5740fdaad506d118300b40d1dad3ec822a494c67dfeca67a7aee8db390bf4cbca837c626117ea75e6abbebf77582e26f08f8b1deaf4be90d3bf6c69f7dd22b5de9b3a969759a0ef3c3bacc18","identityProtectionKey":"0e02f7b53c7769c428b8ea5abf3a7a2a","operationalIdentityProtectionKey":"dd05d6f7bea0ad903b636d4b5a1c7e5a","intermediateCACert":"undefined","operationalCert":"15300101012402013703241400182604378bfb2c2605b7c1a841370624150127112cfc8f4243465c1c1824070124080130094104793d2d127424e62d3abc2ce75089a5ac10b802e6c1202bae3c122fe670bc70757d4bbd014ecaccec875579a25d3d017e90a4de5178da5346b5da9c5cb1aa01a7370a3501280118240201360304020401183004141245fad1714d4730560f3c1f3d288c6834cb33723005140d3813087187f3f867633044bf5740fdaad506d118300b40f368cf3bac85f8f158d3e0f532b44c15e6ca1cb93fd2b022d2da1c04055487c0de785be21a46d309bebb19026a3ef53cb7b66235bac94cae52f7da3f3d89433218","label":""},"discovery":{"knownAddress":"undefined","identifierData":{"shortDiscriminator":12},"discoveryCapabilities":{"ble":false,"onIpNetwork":true}},"passcode":81565376}
2024-11-29 20:02:03.380 [DEBUG] [internal.util.MatterWebsocketService] - Controller~missioner: Skipping NetworkCommissioning steps because the device is already on IP network (udp)
2024-11-29 20:02:03.381 [DEBUG] [internal.util.MatterWebsocketService] - Controller~missioner: Executing commissioning step 0.1: GetInitialData
2024-11-29 20:02:03.381 [TRACE] [internal.util.MatterWebsocketService] - Controller~missioner: Creating new cluster client for cluster Descriptor (endpoint 0, isFeatureSpecific false)
2024-11-29 20:02:03.381 [TRACE] [internal.util.MatterWebsocketService] - InteractionClient: Sending read request: attributes: 0x0/Descriptor(0x1d)/partsList(0x3) and events: undefined
2024-11-29 20:02:03.381 [TRACE] [internal.util.MatterWebsocketService] - MessageExchange: New exchange channel: udp://fe80::da13:2aff:fe4b:1028%eth1:5540 on session secure/27281 protocol: 1 id: 61347 session: secure/27281 peerSessionId: 38802 active threshold ms: 4000 active interval ms: 300 idle interval ms: 5000 maxTransmissions: 5 useMrp: true
2024-11-29 20:02:03.381 [TRACE] [internal.util.MatterWebsocketService] - InteractionClient: Sending read request to udp://fe80::da13:2aff:fe4b:1028%eth1:5540 on session secure/27281 for attributes 0x0/Descriptor(0x1d)/partsList(0x3) and events undefined
2024-11-29 20:02:03.381 [TRACE] [internal.util.MatterWebsocketService] - ExchangeManager: Message » id: 38802/61347/148355229 type: 1/2 acked: undefined reqAck: true duplicate: false payload: 1536001724020024031d2404031818290324ff0c18
2024-11-29 20:02:03.732 [TRACE] [internal.util.MatterWebsocketService] - DeviceAdvertiser: Resubmission started, re-announce node 0
2024-11-29 20:02:03.732 [TRACE] [internal.util.MatterWebsocketService] - DeviceAdvertiser: Announcing fabric: 1
2024-11-29 20:02:03.732 [TRACE] [internal.util.MatterWebsocketService] - MessageExchange: Resubmit message 148355229 (retransmission attempt 1, backoff time 331ms))
2024-11-29 20:02:03.732 [TRACE] [internal.util.MatterWebsocketService] - ExchangeManager: Message » id: 38802/61347/148355229 type: 1/2 acked: undefined reqAck: true duplicate: false payload: 1536001724020024031d2404031818290324ff0c18
2024-11-29 20:02:03.749 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 5d3e66201db6817d/7835080616108383874 qname: 5D3E66201DB6817D-6CBBCC4EEDB05E82._matter._tcp.local port: 59600 interface: eth1
2024-11-29 20:02:03.749 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 5d3e66201db6817d/7835080616108383874 qname: 5D3E66201DB6817D-6CBBCC4EEDB05E82._matter._tcp.local port: 59600 interface: docker0
2024-11-29 20:02:03.749 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 5d3e66201db6817d/7835080616108383874 qname: 5D3E66201DB6817D-6CBBCC4EEDB05E82._matter._tcp.local port: 59600 interface: br-3e21d1d2b60e
2024-11-29 20:02:03.749 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 5d3e66201db6817d/7835080616108383874 qname: 5D3E66201DB6817D-6CBBCC4EEDB05E82._matter._tcp.local port: 59600 interface: br-7ac25da1f717
2024-11-29 20:02:03.749 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 5d3e66201db6817d/7835080616108383874 qname: 5D3E66201DB6817D-6CBBCC4EEDB05E82._matter._tcp.local port: 59600 interface: br-9dd9e484c2d8
2024-11-29 20:02:03.749 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 5d3e66201db6817d/7835080616108383874 qname: 5D3E66201DB6817D-6CBBCC4EEDB05E82._matter._tcp.local port: 59600 interface: br-0ac7bf6ea376
2024-11-29 20:02:03.749 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 5d3e66201db6817d/7835080616108383874 qname: 5D3E66201DB6817D-6CBBCC4EEDB05E82._matter._tcp.local port: 59600 interface: br-10b953e5e977
2024-11-29 20:02:03.749 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 5d3e66201db6817d/7835080616108383874 qname: 5D3E66201DB6817D-6CBBCC4EEDB05E82._matter._tcp.local port: 59600 interface: br-7837f96b44e0
2024-11-29 20:02:03.749 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 5d3e66201db6817d/7835080616108383874 qname: 5D3E66201DB6817D-6CBBCC4EEDB05E82._matter._tcp.local port: 59600 interface: veth9f63a6c
2024-11-29 20:02:03.749 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 5d3e66201db6817d/7835080616108383874 qname: 5D3E66201DB6817D-6CBBCC4EEDB05E82._matter._tcp.local port: 59600 interface: veth38c5666
2024-11-29 20:02:03.749 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 5d3e66201db6817d/7835080616108383874 qname: 5D3E66201DB6817D-6CBBCC4EEDB05E82._matter._tcp.local port: 59600 interface: veth1aa2676
2024-11-29 20:02:03.749 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 5d3e66201db6817d/7835080616108383874 qname: 5D3E66201DB6817D-6CBBCC4EEDB05E82._matter._tcp.local port: 59600 interface: veth73b0f7c
2024-11-29 20:02:03.749 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 5d3e66201db6817d/7835080616108383874 qname: 5D3E66201DB6817D-6CBBCC4EEDB05E82._matter._tcp.local port: 59600 interface: veth4a180e0
2024-11-29 20:02:03.750 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 5d3e66201db6817d/7835080616108383874 qname: 5D3E66201DB6817D-6CBBCC4EEDB05E82._matter._tcp.local port: 59600 interface: veth0ff681f
2024-11-29 20:02:03.750 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 5d3e66201db6817d/7835080616108383874 qname: 5D3E66201DB6817D-6CBBCC4EEDB05E82._matter._tcp.local port: 59600 interface: veth6edbc88
2024-11-29 20:02:03.750 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 5d3e66201db6817d/7835080616108383874 qname: 5D3E66201DB6817D-6CBBCC4EEDB05E82._matter._tcp.local port: 59600 interface: veth1fa94de
2024-11-29 20:02:03.750 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 5d3e66201db6817d/7835080616108383874 qname: 5D3E66201DB6817D-6CBBCC4EEDB05E82._matter._tcp.local port: 59600 interface: vethe2c91fe
2024-11-29 20:02:03.750 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 5d3e66201db6817d/7835080616108383874 qname: 5D3E66201DB6817D-6CBBCC4EEDB05E82._matter._tcp.local port: 59600 interface: veth2318292
2024-11-29 20:02:03.750 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 5d3e66201db6817d/7835080616108383874 qname: 5D3E66201DB6817D-6CBBCC4EEDB05E82._matter._tcp.local port: 59600 interface: vethf25a038
2024-11-29 20:02:03.757 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 785e8ace71dca77f/639902294 qname: 785E8ACE71DCA77F-0000000026242256._matter._tcp.local port: 5540 interface: eth1
2024-11-29 20:02:03.757 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 785e8ace71dca77f/639902294 qname: 785E8ACE71DCA77F-0000000026242256._matter._tcp.local port: 5540 interface: docker0
2024-11-29 20:02:03.757 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 785e8ace71dca77f/639902294 qname: 785E8ACE71DCA77F-0000000026242256._matter._tcp.local port: 5540 interface: br-3e21d1d2b60e
2024-11-29 20:02:03.758 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 785e8ace71dca77f/639902294 qname: 785E8ACE71DCA77F-0000000026242256._matter._tcp.local port: 5540 interface: br-7ac25da1f717
2024-11-29 20:02:03.758 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 785e8ace71dca77f/639902294 qname: 785E8ACE71DCA77F-0000000026242256._matter._tcp.local port: 5540 interface: br-9dd9e484c2d8
2024-11-29 20:02:03.758 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 785e8ace71dca77f/639902294 qname: 785E8ACE71DCA77F-0000000026242256._matter._tcp.local port: 5540 interface: br-0ac7bf6ea376
2024-11-29 20:02:03.758 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 785e8ace71dca77f/639902294 qname: 785E8ACE71DCA77F-0000000026242256._matter._tcp.local port: 5540 interface: br-10b953e5e977
2024-11-29 20:02:03.758 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 785e8ace71dca77f/639902294 qname: 785E8ACE71DCA77F-0000000026242256._matter._tcp.local port: 5540 interface: br-7837f96b44e0
2024-11-29 20:02:03.758 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 785e8ace71dca77f/639902294 qname: 785E8ACE71DCA77F-0000000026242256._matter._tcp.local port: 5540 interface: veth9f63a6c
2024-11-29 20:02:03.758 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 785e8ace71dca77f/639902294 qname: 785E8ACE71DCA77F-0000000026242256._matter._tcp.local port: 5540 interface: veth38c5666
2024-11-29 20:02:03.758 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 785e8ace71dca77f/639902294 qname: 785E8ACE71DCA77F-0000000026242256._matter._tcp.local port: 5540 interface: veth1aa2676
2024-11-29 20:02:03.758 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 785e8ace71dca77f/639902294 qname: 785E8ACE71DCA77F-0000000026242256._matter._tcp.local port: 5540 interface: veth73b0f7c
2024-11-29 20:02:03.758 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 785e8ace71dca77f/639902294 qname: 785E8ACE71DCA77F-0000000026242256._matter._tcp.local port: 5540 interface: veth4a180e0
2024-11-29 20:02:03.758 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 785e8ace71dca77f/639902294 qname: 785E8ACE71DCA77F-0000000026242256._matter._tcp.local port: 5540 interface: veth0ff681f
2024-11-29 20:02:03.758 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 785e8ace71dca77f/639902294 qname: 785E8ACE71DCA77F-0000000026242256._matter._tcp.local port: 5540 interface: veth6edbc88
2024-11-29 20:02:03.758 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 785e8ace71dca77f/639902294 qname: 785E8ACE71DCA77F-0000000026242256._matter._tcp.local port: 5540 interface: veth1fa94de
2024-11-29 20:02:03.758 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 785e8ace71dca77f/639902294 qname: 785E8ACE71DCA77F-0000000026242256._matter._tcp.local port: 5540 interface: vethe2c91fe
2024-11-29 20:02:03.758 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 785e8ace71dca77f/639902294 qname: 785E8ACE71DCA77F-0000000026242256._matter._tcp.local port: 5540 interface: veth2318292
2024-11-29 20:02:03.758 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: 785e8ace71dca77f/639902294 qname: 785E8ACE71DCA77F-0000000026242256._matter._tcp.local port: 5540 interface: vethf25a038
2024-11-29 20:02:03.766 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: cdc71343318b253c/2043585585612848172 qname: CDC71343318B253C-1C5C4643428FFC2C._matter._tcp.local port: 33277 interface: eth1
2024-11-29 20:02:03.766 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: cdc71343318b253c/2043585585612848172 qname: CDC71343318B253C-1C5C4643428FFC2C._matter._tcp.local port: 33277 interface: docker0
2024-11-29 20:02:03.766 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: cdc71343318b253c/2043585585612848172 qname: CDC71343318B253C-1C5C4643428FFC2C._matter._tcp.local port: 33277 interface: br-3e21d1d2b60e
2024-11-29 20:02:03.766 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: cdc71343318b253c/2043585585612848172 qname: CDC71343318B253C-1C5C4643428FFC2C._matter._tcp.local port: 33277 interface: br-7ac25da1f717
2024-11-29 20:02:03.766 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: cdc71343318b253c/2043585585612848172 qname: CDC71343318B253C-1C5C4643428FFC2C._matter._tcp.local port: 33277 interface: br-9dd9e484c2d8
2024-11-29 20:02:03.767 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: cdc71343318b253c/2043585585612848172 qname: CDC71343318B253C-1C5C4643428FFC2C._matter._tcp.local port: 33277 interface: br-0ac7bf6ea376
2024-11-29 20:02:03.767 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: cdc71343318b253c/2043585585612848172 qname: CDC71343318B253C-1C5C4643428FFC2C._matter._tcp.local port: 33277 interface: br-10b953e5e977
2024-11-29 20:02:03.767 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: cdc71343318b253c/2043585585612848172 qname: CDC71343318B253C-1C5C4643428FFC2C._matter._tcp.local port: 33277 interface: br-7837f96b44e0
2024-11-29 20:02:03.767 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: cdc71343318b253c/2043585585612848172 qname: CDC71343318B253C-1C5C4643428FFC2C._matter._tcp.local port: 33277 interface: veth9f63a6c
2024-11-29 20:02:03.767 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: cdc71343318b253c/2043585585612848172 qname: CDC71343318B253C-1C5C4643428FFC2C._matter._tcp.local port: 33277 interface: veth38c5666
2024-11-29 20:02:03.767 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: cdc71343318b253c/2043585585612848172 qname: CDC71343318B253C-1C5C4643428FFC2C._matter._tcp.local port: 33277 interface: veth1aa2676
2024-11-29 20:02:03.767 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: cdc71343318b253c/2043585585612848172 qname: CDC71343318B253C-1C5C4643428FFC2C._matter._tcp.local port: 33277 interface: veth73b0f7c
2024-11-29 20:02:03.767 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: cdc71343318b253c/2043585585612848172 qname: CDC71343318B253C-1C5C4643428FFC2C._matter._tcp.local port: 33277 interface: veth4a180e0
2024-11-29 20:02:03.767 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: cdc71343318b253c/2043585585612848172 qname: CDC71343318B253C-1C5C4643428FFC2C._matter._tcp.local port: 33277 interface: veth0ff681f
2024-11-29 20:02:03.767 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: cdc71343318b253c/2043585585612848172 qname: CDC71343318B253C-1C5C4643428FFC2C._matter._tcp.local port: 33277 interface: veth6edbc88
2024-11-29 20:02:03.767 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: cdc71343318b253c/2043585585612848172 qname: CDC71343318B253C-1C5C4643428FFC2C._matter._tcp.local port: 33277 interface: veth1fa94de
2024-11-29 20:02:03.767 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: cdc71343318b253c/2043585585612848172 qname: CDC71343318B253C-1C5C4643428FFC2C._matter._tcp.local port: 33277 interface: vethe2c91fe
2024-11-29 20:02:03.767 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: cdc71343318b253c/2043585585612848172 qname: CDC71343318B253C-1C5C4643428FFC2C._matter._tcp.local port: 33277 interface: veth2318292
2024-11-29 20:02:03.767 [TRACE] [internal.util.MatterWebsocketService] - MdnsBroadcaster: Announcement Generator: Fabric id: cdc71343318b253c/2043585585612848172 qname: CDC71343318B253C-1C5C4643428FFC2C._matter._tcp.local port: 33277 interface: vethf25a038
2024-11-29 20:02:04.064 [TRACE] [internal.util.MatterWebsocketService] - MessageExchange: Resubmit message 148355229 (retransmission attempt 2, backoff time 620ms))
2024-11-29 20:02:04.066 [TRACE] [internal.util.MatterWebsocketService] - ExchangeManager: Message » id: 38802/61347/148355229 type: 1/2 acked: undefined reqAck: true duplicate: false payload: 1536001724020024031d2404031818290324ff0c18
2024-11-29 20:02:04.685 [TRACE] [internal.util.MatterWebsocketService] - MessageExchange: Resubmit message 148355229 (retransmission attempt 3, backoff time 958ms))
2024-11-29 20:02:04.685 [TRACE] [internal.util.MatterWebsocketService] - ExchangeManager: Message » id: 38802/61347/148355229 type: 1/2 acked: undefined reqAck: true duplicate: false payload: 1536001724020024031d2404031818290324ff0c18
2024-11-29 20:02:05.645 [TRACE] [internal.util.MatterWebsocketService] - MessageExchange: Resubmit message 148355229 (retransmission attempt 4, backoff time 1425ms))
2024-11-29 20:02:05.646 [TRACE] [internal.util.MatterWebsocketService] - ExchangeManager: Message » id: 38802/61347/148355229 type: 1/2 acked: undefined reqAck: true duplicate: false payload: 1536001724020024031d2404031818290324ff0c18
2024-11-29 20:02:07.071 [TRACE] [internal.util.MatterWebsocketService] - MessageExchange: Wait additional 4804ms for processing time and peer resubmissions after all our resubmissions
2024-11-29 20:02:11.876 [TRACE] [internal.util.MatterWebsocketService] - InteractionMessenger: Retransmission limit reached, trying to reconnect and resend the message.
2024-11-29 20:02:17.346 [TRACE] [internal.util.MatterWebsocketService] - DeviceAdvertiser: Announcement duration reached, stop announcing
2024-11-29 20:02:18.093 [TRACE] [internal.util.MatterWebsocketService] - ServerSubscription: Sending subscription update message for ID 1038664263 with 0 attributes and 0 events
2024-11-29 20:02:18.093 [TRACE] [internal.util.MatterWebsocketService] - MessageExchange: New exchange channel: udp://fe80::3f94:8f04:f113:bf51%eth1:5540 on session secure/50965 protocol: 1 id: 45270 session: secure/50965 peerSessionId: 50367 active threshold ms: 4000 active interval ms: 300 idle interval ms: 500 maxTransmissions: 5 useMrp: true
2024-11-29 20:02:18.093 [TRACE] [internal.util.MatterWebsocketService] - ServerSubscription: Sending subscription changes for ID 1038664263:
2024-11-29 20:02:18.093 [TRACE] [internal.util.MatterWebsocketService] - InteractionMessenger: Sending DataReport chunk with 0 attributes and 0 events: 13 bytes (moreChunkedMessages: false, suppressResponse: true)
2024-11-29 20:02:18.093 [TRACE] [internal.util.MatterWebsocketService] - ExchangeManager: Message » id: 50367/45270/136561012 type: 1/5 acked: undefined reqAck: true duplicate: false payload: 15260047c2e83d290424ff0c18
2024-11-29 20:02:18.106 [TRACE] [internal.util.MatterWebsocketService] - MessageExchange: Message « id: 50965/45270/197847316 type: 0/16 acked: 136561012 reqAck: false duplicate: false payload:
2024-11-29 20:02:19.947 [TRACE] [internal.util.MatterWebsocketService] - MdnsScanner: Adding operational device 5D3E66201DB6817D-6CBBCC4EEDB05E82._matter._tcp.local in cache (interface eth1, ttl=120) with TXT data: SII: 500 SAI: 300 SAT: 4000 T: 0 DT: undefined PH: undefined ICD: 0 VP: undefined DN: undefined RI: undefined PI: undefined
2024-11-29 20:02:19.950 [TRACE] [internal.util.MatterWebsocketService] - MdnsScanner: Adding operational device 785E8ACE71DCA77F-00000000B033E626._matter._tcp.local in cache (interface eth1, ttl=4500) with TXT data: SII: undefined SAI: undefined SAT: undefined T: 0 DT: undefined PH: undefined ICD: 0 VP: undefined DN: undefined RI: undefined PI: undefined
2024-11-29 20:02:19.952 [TRACE] [internal.util.MatterWebsocketService] - MdnsScanner: Adding operational device 785E8ACE71DCA77F-00000000F87769F6._matter._tcp.local in cache (interface eth1, ttl=4500) with TXT data: SII: undefined SAI: undefined SAT: undefined T: 0 DT: undefined PH: undefined ICD: 0 VP: undefined DN: undefined RI: undefined PI: undefined
2024-11-29 20:02:20.010 [TRACE] [internal.util.MatterWebsocketService] - MdnsScanner: Adding operational device 785E8ACE71DCA77F-000000005EB98F0C._matter._tcp.local in cache (interface eth1, ttl=4500) with TXT data: SII: undefined SAI: undefined SAT: undefined T: 0 DT: undefined PH: undefined ICD: 0 VP: undefined DN: undefined RI: undefined PI: undefined
2024-11-29 20:02:20.032 [TRACE] [internal.util.MatterWebsocketService] - MdnsScanner: Adding operational device 785E8ACE71DCA77F-00000000E2A096A3._matter._tcp.local in cache (interface eth1, ttl=4500) with TXT data: SII: undefined SAI: undefined SAT: undefined T: 0 DT: undefined PH: undefined ICD: 0 VP: undefined DN: undefined RI: undefined PI: undefined
2024-11-29 20:02:20.041 [TRACE] [internal.util.MatterWebsocketService] - MdnsScanner: Adding operational device 785E8ACE71DCA77F-0000000038775A2C._matter._tcp.local in cache (interface eth1, ttl=4500) with TXT data: SII: undefined SAI: undefined SAT: undefined T: 0 DT: undefined PH: undefined ICD: 0 VP: undefined DN: undefined RI: undefined PI: undefined
2024-11-29 20:02:20.052 [TRACE] [internal.util.MatterWebsocketService] - MdnsScanner: Adding operational device 785E8ACE71DCA77F-00000000359AB6CB._matter._tcp.local in cache (interface eth1, ttl=4500) with TXT data: SII: undefined SAI: undefined SAT: undefined T: 0 DT: undefined PH: undefined ICD: 0 VP: undefined DN: undefined RI: undefined PI: undefined
2024-11-29 20:02:20.053 [TRACE] [internal.util.MatterWebsocketService] - MdnsScanner: Adding operational device 5D3E66201DB6817D-1602333CCE68D62E._matter._tcp.local in cache (interface eth1, ttl=4500) with TXT data: SII: undefined SAI: undefined SAT: undefined T: 0 DT: undefined PH: undefined ICD: 0 VP: undefined DN: undefined RI: undefined PI: undefined
2024-11-29 20:02:20.057 [TRACE] [internal.util.MatterWebsocketService] - MdnsScanner: Adding operational device 785E8ACE71DCA77F-000000003740146C._matter._tcp.local in cache (interface eth1, ttl=4500) with TXT data: SII: undefined SAI: undefined SAT: undefined T: 0 DT: undefined PH: undefined ICD: 0 VP: undefined DN: undefined RI: undefined PI: undefined
2024-11-29 20:02:20.098 [TRACE] [internal.util.MatterWebsocketService] - MdnsScanner: Adding operational device 785E8ACE71DCA77F-00000000D3F68AEA._matter._tcp.local in cache (interface eth1, ttl=4500) with TXT data: SII: undefined SAI: undefined SAT: undefined T: 0 DT: undefined PH: undefined ICD: 0 VP: undefined DN: undefined RI: undefined PI: undefined
2024-11-29 20:02:20.222 [TRACE] [internal.util.MatterWebsocketService] - MdnsScanner: Adding operational device 785E8ACE71DCA77F-00000000CE97878C._matter._tcp.local in cache (interface eth1, ttl=4500) with TXT data: SII: undefined SAI: undefined SAT: undefined T: 0 DT: undefined PH: undefined ICD: 0 VP: undefined DN: undefined RI: undefined PI: undefined
2024-11-29 20:02:20.267 [TRACE] [internal.util.MatterWebsocketService] - MdnsScanner: Adding operational device 785E8ACE71DCA77F-000000000698FAD0._matter._tcp.local in cache (interface eth1, ttl=4500) with TXT data: SII: undefined SAI: undefined SAT: undefined T: 0 DT: undefined PH: undefined ICD: 0 VP: undefined DN: undefined RI: undefined PI: undefined
2024-11-29 20:02:23.107 [DEBUG] [internal.util.MatterWebsocketService] - Controller: Error executing function pairNode:
2024-11-29 20:02:23.108 [DEBUG] [internal.util.MatterWebsocketService] - Controller: Stack trace: Error
2024-11-29 20:02:23.108 [TRACE] [internal.util.MatterWebsocketService] - matter: Sending response: {"type":"response","message":{"type":"resultError","id":"c1cf358b-1e39-40f1-9fa3-55e4ae315e12","result":"undefined","error":""}}
2024-11-29 20:02:23.108 [TRACE] [internal.util.MatterWebsocketService] - none:       at StandardTimer.eval [as callback] (webpack://matter-server/./node_modules/@matter/general/dist/cjs/util/DataReadQueue.js?:53:24)
2024-11-29 20:02:23.108 [TRACE] [internal.util.MatterWebsocketService] - none:       at Timeout.eval [as _onTimeout] (webpack://matter-server/./node_modules/@matter/general/dist/cjs/time/Time.js?:134:12)
2024-11-29 20:02:23.108 [TRACE] [internal.util.MatterWebsocketService] - none:       at listOnTimeout (node:internal/timers:573:17)
2024-11-29 20:02:23.108 [TRACE] [internal.util.MatterWebsocketService] - none:       at process.processTimers (node:internal/timers:514:7)
2024-11-29 20:02:23.109 [DEBUG] [internal.util.MatterWebsocketService] - Controller: Error name: Error
2024-11-29 20:02:23.109 [DEBUG] [internal.util.MatterWebsocketService] - Controller: Full error object: {"stack":"Error\n    at StandardTimer.eval [as callback] (webpack://matter-server/./node_modules/@matter/general/dist/cjs/util/DataReadQueue.js?:53:24)\n    at Timeout.eval [as _onTimeout] (webpack://matter-server/./node_modules/@matter/general/dist/cjs/time/Time.js?:134:12)\n    at listOnTimeout (node:internal/timers:573:17)\n    at process.processTimers (node:internal/timers:514:7)"}
2024-11-29 20:02:23.109 [DEBUG] [internal.util.MatterWebsocketService] - Controller: NoResponseTimeoutError
2024-11-29 20:02:23.109 [TRACE] [internal.util.MatterWebsocketService] - none:   at StandardTimer.eval [as callback] (webpack://matter-server/./node_modules/@matter/general/dist/cjs/util/DataReadQueue.js?:53:24)
2024-11-29 20:02:23.109 [TRACE] [internal.util.MatterWebsocketService] - none:   at Timeout.eval [as _onTimeout] (webpack://matter-server/./node_modules/@matter/general/dist/cjs/time/Time.js?:134:12)
2024-11-29 20:02:23.109 [TRACE] [internal.util.MatterWebsocketService] - none:   at listOnTimeout (node:internal/timers:573:17)
2024-11-29 20:02:23.109 [DEBUG] [nternal.client.MatterWebsocketClient] - onWebSocketText {"type":"response","message":{"type":"resultError","id":"c1cf358b-1e39-40f1-9fa3-55e4ae315e12","result":"undefined","error":""}}
2024-11-29 20:02:23.109 [TRACE] [internal.util.MatterWebsocketService] - none:   at process.processTimers (node:internal/timers:514:7)
2024-11-29 20:02:23.110 [DEBUG] [nternal.client.MatterWebsocketClient] - result type: resultError
2024-11-29 20:02:23.111 [DEBUG] [nal.discovery.MatterDiscoveryService] - startScan complete
The other log lines you asked about are from the plug itself, logged to the tasmota console. They look similar for this scan as well:
20:02:02.265 MTR: New Commissioning (PASE id=38802) from [fe80::abf:b8ff:fe3b:dcff%st1]:33277
20:02:02.392 MTR: MessageHandler::msg_received exception: value_error;Nonce size must be 7..13
HTH
Ah, i spaced this is a tasmota device, which has had a few issues, let me look at this more, will probably take back to the matter.js devs, who will then chat with tasmota (we had another issue earlier on as well), last time was a pretty quick turnaround.
Actually, what tasmota firmware are you running? I wonder if this is the same issue which was recently fixed upstream in the tasmota firmware.
EDIT: specifically this was fixed Matter provisioning with matter.js controller by s-hadinger · Pull Request #22470 · arendst/Tasmota · GitHub
Ha, you are right. I was on 13.3.0, which is pretty old. An update to the latest official release (14.3.0) didn’t help but when I switched to the dev build (14.3.7) it started to work. I could now pair the plug just fine.
I also receive changes to the relay state on the according channel, but something doesn’t seem to work when trying to change the state from withing openhab. Will need more debugging, though.
Thanks for your help so far!
If you run into issues, post your item config and the websocket messages back and forth here to help troubleshoot. Also it would be help full to have the endpoint JSON of the device, which shows up when you disable and then enable a endpoint thing or restart the binding.
What’s interesting is that in HomeKit, the EVE device shows up as one device. When I paired it with Alexa, it showed up as two devices: motion and luminescence. I wonder if that is why I could pair it from Alexa to OpenHAB instead of HomeKIT to OpenHAB. In OpenHAB, it shows up as two devices.
Regarding my stability issue with Tapo L535E, I found someone in HA community having very similar problem:
In my case, it never went completely offline.
Apparently behaviour in Apple Home was also impacted.
In my case, I discovered no problem with Google Home.
This message is old (beginning of year) and bulb firmware was certainly updated since this date. So maybe it was improved by TP-Link but not fully resolved.
Edit: last firmware was published in June and is supposed to fix an offline issue:
Modifications and Bug Fixes:
  1. Optimized the color changing performance in the Apple Home app.
  2. Fixed the offline problem in some cases.
  3. Fixed some minor bugs.
Problem also reported on TP-link forum:
My WiFi level is low in Tapo app. I moved the light to see if it helps.
Hi ,
I tired to expose OH items in sonoff NS panel pro and I was able to connect OH as bridge.
I m trying to expose a fan which is based on tasmota. Is there anyway to expose a fan with Light and Fan Speed.
If anyone has any idea/suggestion please let me know and thanks for this amazing binding.
Dan, with your version of 28th of November, color light is no more working. on/off and dim level is no more adjusted.
Might be due to a new version of matter.js ?
Will have to enable logs to see if I find something.
I have a Google Nest WiFi Pro and converted my lights in OH from Google Assistant to Matter (LightDimmableLight or OnOffLight, OutletOnOffPlugInUnit). @digitaldan, I’m impressed with how easy it was to switch and how well the Matter bridge works :smiley:. There is some slowness with updates when the devices change, but I see somebody already reported this.
FYI, the documentation has PlugInUnit which should be OnOffPlugInUnit
Fan is the only Google Assistant type that I have left to convert to Matter.
BTW, I found this page that maps that maps Matter devices to the corresponding Google Assistant devices. It might be helpful for others with the conversion.
