Increase in logging verbosity in 5.1.0?
I see this in my log now with source: entries, can they be removed easily?
16:59:42.059 [INFO ] [openhab.event.ItemStateChangedEvent  ] - Item 'Solar_Garage_Voltage' changed from 239.9 to 240.1 (source: org.openhab.core.thing$fronius:powerinverter:809abad4df:d5e0145e76:inverterdatachanneluac)
16:59:42.060 [INFO ] [nhab.event.GroupItemStateChangedEvent] - Item 'gSolar_EnergyDay' changed from 49.303 kWh to 49.321 kWh through Solar_GarageDay_Energy
16:59:44.288 [INFO ] [openhab.event.ItemStateChangedEvent  ] - Item 'vSun_Azimuth' changed from 265.2514657501675 ° to 265.125264675021 ° (source: org.openhab.core.thing$astro:sun:sunrise60mins_before:position#azimuth)
16:59:44.292 [INFO ] [openhab.event.ItemStateChangedEvent  ] - Item 'vSun_Elevation' changed from 36.96117439677017 ° to 36.754398017451386 ° (source: org.openhab.core.thing$astro:sun:sunrise60mins_before:position#elevation)
16:59:56.753 [INFO ] [openhab.event.ItemStateChangedEvent  ] - Item 'EnsuiteThermostat_Temperature' changed from 24.5 °C to 24 °C (source: org.openhab.core.thing$broadlinkthermostat:floureonthermostat:BroadLink_OEM-T1-2a-e2-dd-lan:roomtemperature)
16:59:56.754 [INFO ] [openhab.event.ItemStateChangedEvent  ] - Item 'Floureon_Thermostat_BroadLink_OEMT12ae2ddlan_Time' changed from 2026-01-02T16:08:29.000+1100 to 2026-01-02T16:09:29.000+1100 (source: org.openhab.core.thing$broadlinkthermostat:floureonthermostat:BroadLink_OEM-T1-2a-e2-dd-lan:time)
17:00:00.621 [INFO ] [ipting.rule.Calculate_Energy_Consumed] - Energy Engine | Rate: Peak | Sufficiency: 69.6% | House Load: 17.7kWh
17:00:00.625 [INFO ] [openhab.event.ItemStateChangedEvent  ] - Item 'Energy_Status' changed from -1.22 kW to -1.2 kW (source: org.openhab.automation.jsscripting$rule:Calculate_Energy_Consumed)
17:00:00.627 [INFO ] [openhab.event.ItemStateChangedEvent  ] - Item 'Energy_Used' changed from 0.93 kW to 0.95 kW (source: org.openhab.automation.jsscripting$rule:Calculate_Energy_Consumed)
17:00:00.629 [INFO ] [openhab.event.ItemStateChangedEvent  ] - Item 'Daily_Total_Usage' changed from 17.7 kWh to 17.72 kWh (source: org.openhab.automation.jsscripting$rule:Calculate_Energy_Consumed)
17:00:00.629 [INFO ] [openhab.event.ItemStateChangedEvent  ] - Item 'Daily_Electricity_Cost' changed from -0.78 DEF to -0.79 DEF (source: org.openhab.automation.jsscripting$rule:Calculate_Energy_Consumed)
17:00:00.630 [INFO ] [openhab.event.ItemStateChangedEvent  ] - Item 'Solar_SelfConsumption_Rate' changed from 69.5% to 69.6% (source: org.openhab.automation.jsscripting$rule:Calculate_Energy_Consumed)
17:00:06.044 [INFO ] [nhab.event.GroupItemStateChangedEvent] - Item 'gSolar_ACPower' changed from 2.149 kW to 2150 W through Solar_HouseAC_Power
17:00:06.045 [INFO ] [openhab.event.ItemStateChangedEvent  ] - Item 'Solar_HouseAC_Power' changed from 1154 W to 1155 W (source: org.openhab.core.thing$fronius:powerinverter:424268a658:4c7ff137ae:inverterdatachannelpac)
17:00:06.046 [INFO ] [openhab.event.ItemStateChangedEvent  ] - Item 'Solar_HouseDay_Energy' changed from 26.58 kWh to 26.6 kWh (source: org.openhab.core.thing$fronius:powerinverter:424268a658:4c7ff137ae:inverterdatachanneldayenergy)
17:00:06.049 [INFO ] [nhab.event.GroupItemStateChangedEvent] - Item 'gSolar_EnergyDay' changed from 49.32 kWh to 49.341 kWh through Solar_HouseDay_Energy
17:00:06.051 [INFO ] [openhab.event.ItemStateChangedEvent  ] - Item 'Solar_HouseTotal_Energy' changed from 38.9419 to 38.942 (source: org.openhab.core.thing$fronius:powerinverter:424268a658:4c7ff137ae:inverterdatachanneltotal)
17:00:06.052 [INFO ] [openhab.event.ItemStateChangedEvent  ] - Item 'Solar_HouseYear_Energy' changed from 42.1068 kWh to 42.1268 kWh (source: org.openhab.core.thing$fronius:powerinverter:424268a658:4c7ff137ae:inverterdatachannelyear)
17:00:06.052 [INFO ] [openhab.event.ItemStateChangedEvent  ] - Item 'Solar_House_Voltage' changed from 239.6 V to 239.5 V (source: org.openhab.core.thing$fronius:powerinverter:424268a658:4c7ff137ae:inverterdatachanneluac)
17:00:06.053 [INFO ] [openhab.event.ItemStateChangedEvent  ] - Item 'Solar_HouseGrid_Power' changed from -1202.78 W to -1209.11 W (source: org.openhab.core.thing$fronius:powerinverter:424268a658:4c7ff137ae:powerflowchannelpgrid)
17:00:06.054 [INFO ] [openhab.event.ItemStateChangedEvent  ] - Item 'Solar_HouseLoad_Power' changed from 48.77999999999997 W to 56.1099999999999 W (source: org.openhab.core.thing$fronius:powerinverter:424268a658:4c7ff137ae:powerflowchannelpload)
17:00:07.568 [INFO ] [openhab.event.ItemStateChangedEvent  ] - Item 'Meter_EnergyProduced' changed from 48198.961 kWh to 48198.982 kWh (source: org.openhab.core.thing$fronius:meter:172a3b9554:FroniusSmartMeter:energyrealsumproduced)
17:00:12.343 [INFO ] [openhab.event.ItemStateChangedEvent  ] - Item 'GarageAir_CurrentTemperature' changed from 24.4 °C to 24.3 °C (source: org.openhab.core.thing$sensibo:sensibosky:82e2ca1d6a:b32c32e69c:currentTemperature)
17:00:12.345 [INFO ] [openhab.event.ItemStateChangedEvent  ] - Item 'GarageAir_CurrentHumidity' changed from 61 % to 61.2 % (source: org.openhab.core.thing$sensibo:sensibosky:82e2ca1d6a:b32c32e69c:currentHumidity)
17:00:44.290 [INFO ] [openhab.event.ItemStateChangedEvent  ] - Item 'vSun_Azimuth' changed from 265.125264675021 ° to 264.99930202924355 ° (source: org.openhab.core.thing$astro:sun:sunrise60mins_before:position#azimuth)
17:00:44.292 [INFO ] [openhab.event.ItemStateChangedEvent  ] - Item 'vSun_Elevation' changed from 36.754398017451386 ° to 36.54765708541909 ° (source: org.openhab.core.thing$astro:sun:sunrise60mins_before:position#elevation)
17:00:44.304 [INFO ] [openhab.event.ItemStateChangedEvent  ] - Item 'Solar_GarageAC_Power' changed from 995 W to 987 W (source: org.openhab.core.thing$fronius:powerinverter:809abad4df:d5e0145e76:inverterdatachannelpac)
17:00:44.309 [INFO ] [nhab.event.GroupItemStateChangedEvent] - Item 'gSolar_ACPower' changed from 2.15 kW to 2142 W through Solar_GarageAC_Power
17:00:44.310 [INFO ] [openhab.event.ItemStateChangedEvent  ] - Item 'Solar_GarageDay_Energy' changed from 22.741 kWh to 22.756 kWh (source: org.openhab.core.thing$fronius:powerinverter:809abad4df:d5e0145e76:inverterdatachanneldayenergy)
17:00:44.311 [INFO ] [nhab.event.GroupItemStateChangedEvent] - Item 'gSolar_EnergyDay' changed from 49.341 kWh to 49.356 kWh through Solar_GarageDay_Energy
17:00:44.313 [INFO ] [openhab.event.ItemStateChangedEvent  ] - Item 'Solar_GarageYear_Energy' changed from 0.0364955 to 0.0365121 (source: org.openhab.core.thing$fronius:powerinverter:809abad4df:d5e0145e76:inverterdatachannelyear)
Thanks!
I have the same questions.
Are you taking about the source? No, there is no way to disable it as far as I know.
Note that this additional information is often really useful when diagnosing problems. I’ve already depended on it three times since last week to help solve problems for posters to the forum.
The source is also available in rules.
For the Android app, I think it even includes which device the command came from, not just that it came from an Android device. I imagine iOS is the same. So you can add logic to rules now to do something different based on where the command came from.
This will certainly be helpful for troubleshooting.
For another user, this option wasn’t installed after updating to version 5.1.0!
So there must be some difference somewhere.
I always check the log to optimize the rules.
With this new information, things are getting quite confusing.
I’m using the openHAB Log Viewer (Frontail) in a web browser on port 9001.
I was able to remove the suffix “(source…)” by editing the log4j2.xml file.
It’s not disabled, but simply filtered out.
in this section:
<RollingRandomAccessFile fileName="${sys:openhab.logdir}/events.log"
                         filePattern="${sys:openhab.logdir}/events.log.%i.gz"
                         name="EVENT">
    <PatternLayout pattern="%d{yyyy-MM-dd HH:mm:ss.SSS} [%-5.5p] [%-36.36c] - %m%n"/>
Change pattern to:
<PatternLayout pattern="%d{yyyy-MM-dd HH:mm:ss.SSS} [%-5.5p] [%-36.36c] - %replace{%m}{\(source: .*?\)}{}%n"/>
In case of an error, you can reset it or refer to the UI’s own log.
greeting
It’s part of core. There’s nothing separate to install. So what ever happened with that other user, either they are seeing events for which the source is not yet added to the event (I think there are still a few places that don’t do this yet) or their upgrade failed somehow.
