when I add an item for boschindego:indego:<XXX>:batteryVoltage (Number:ElectricPotential) I get only something between 9.2V and 9.6V.
I was a bit surprised when I saw it with the “old” battery - but I just exchanged it with a brand new one. I measured the new battery and it was - not surprisingly - OK.
So is there a bug in the indego firmware (I have FW 30068.01459 - current version) - or is this a problem with the binding?
It looks like the voltage is half of what it actually is.
Which model do you have? Some models only report percentage, and unfortunately they also report that as voltage. You need to use the batteryLevel channel instead.
I have thought about removing the channel for models not supporting it, but that would be inconvenient if Bosch fixes this issue in the future. Also, I don’t actually know which models report voltage correctly through the service. Mine is M+ 700 and it doesn’t support it either.
I also thought about mentioning this in the documentation, but it seems I never got around to do that.
