Hi everyone,
I am Using openHAB 3.3.0M3 with InfluxDB 2.2 as persistence service. The Setup is deployed as docker compose project. After trying to upgrade to openHAB 3.3.0M4 I got in openhab.log the following errors on starting up openhab container:
2022-05-08 08:39:24.565 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'QueryablePersistenceService.query()' on 'org.openhab.persistence.influxdb.InfluxDBPersistenceService@2c32516e': runtime error @4:5-4:54: keep: schema collision detected: column "_value" is both of type float and string
com.influxdb.exceptions.BadRequestException: runtime error @4:5-4:54: keep: schema collision detected: column "_value" is both of type float and string
at com.influxdb.internal.AbstractRestClient.responseToError(AbstractRestClient.java:96) ~[?:?]
at com.influxdb.internal.AbstractQueryApi$1.onResponse(AbstractQueryApi.java:145) ~[?:?]
at com.influxdb.internal.AbstractQueryApi.query(AbstractQueryApi.java:193) ~[?:?]
at com.influxdb.internal.AbstractQueryApi.query(AbstractQueryApi.java:104) ~[?:?]
at com.influxdb.client.internal.QueryApiImpl.query(QueryApiImpl.java:803) ~[?:?]
at com.influxdb.client.internal.QueryApiImpl.query(QueryApiImpl.java:105) ~[?:?]
at com.influxdb.client.internal.QueryApiImpl.query(QueryApiImpl.java:83) ~[?:?]
at com.influxdb.client.internal.QueryApiImpl.query(QueryApiImpl.java:73) ~[?:?]
at org.openhab.persistence.influxdb.internal.influx2.InfluxDB2RepositoryImpl.query(InfluxDB2RepositoryImpl.java:182) ~[?:?]
at org.openhab.persistence.influxdb.InfluxDBPersistenceService.query(InfluxDBPersistenceService.java:231) ~[?:?]
at jdk.internal.reflect.GeneratedMethodAccessor110.invoke(Unknown Source) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
at org.openhab.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:154) [bundleFile:?]
at org.openhab.core.internal.common.Invocation.call(Invocation.java:52) [bundleFile:?]
2022-05-08 08:39:24.604 [ERROR] [ence.internal.PersistenceManagerImpl] - Exception occurred while querying persistence service 'influxdb': runtime error @4:5-4:54: keep: schema collision detected: column "_value" is both of type float and string
2022-05-08 08:39:35.711 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'QueryablePersistenceService.query()' on 'org.openhab.persistence.influxdb.InfluxDBPersistenceService@2c32516e': runtime error @4:5-4:54: keep: schema collision detected: column "_value" is both of type float and string
2022-05-08 08:39:35.725 [ERROR] [ence.internal.PersistenceManagerImpl] - Exception occurred while querying persistence service 'influxdb': runtime error @4:5-4:54: keep: schema collision detected: column "_value" is both of type float and string
2022-05-08 08:39:36.159 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'QueryablePersistenceService.query()' on 'org.openhab.persistence.influxdb.InfluxDBPersistenceService@2c32516e': runtime error @4:5-4:54: keep: schema collision detected: column "_value" is both of type float and string
2022-05-08 08:39:36.166 [ERROR] [ence.internal.PersistenceManagerImpl] - Exception occurred while querying persistence service 'influxdb': runtime error @4:5-4:54: keep: schema collision detected: column "_value" is both of type float and string
2022-05-08 08:39:36.735 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'QueryablePersistenceService.query()' on 'org.openhab.persistence.influxdb.InfluxDBPersistenceService@2c32516e': runtime error @4:5-4:54: keep: schema collision detected: column "_value" is both of type int and string
com.influxdb.exceptions.BadRequestException: runtime error @4:5-4:54: keep: schema collision detected: column "_value" is both of type int and string
2022-05-08 08:39:36.742 [ERROR] [ence.internal.PersistenceManagerImpl] - Exception occurred while querying persistence service 'influxdb': runtime error @4:5-4:54: keep: schema collision detected: column "_value" is both of type int and string
2022-05-08 08:39:38.486 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'QueryablePersistenceService.query()' on 'org.openhab.persistence.influxdb.InfluxDBPersistenceService@2c32516e': runtime error @4:5-4:54: keep: schema collision detected: column "_value" is both of type float and string
2022-05-08 08:39:38.500 [ERROR] [ence.internal.PersistenceManagerImpl] - Exception occurred while querying persistence service 'influxdb': runtime error @4:5-4:54: keep: schema collision detected: column "_value" is both of type float and string
after switching back to M3 the errors are still there. I think some of my items have changed the type of output during the Update to M4. My Problem is, I can’t figure out which items are effected and producing theses errors in the log. I also checked influxDB2 to find out a query to show me which measurements are using STRING and FLOAT, but can’t even find a FLUX query to show only STRING measurements.
So I hope someone here can help me out. Would like to know which Items are causing the problem. After that I think I can convert or just delete them in InfluxDB.
regards
Andreas
