InfluxDB Binding NullPointer
Hi together,
my InfluxDB Binding keeps crashing and i have to restart the bundle via console all the time. Sometimes days sometimes hours.
It logs the following error:
2021-02-11 02:53:53.774 [ERROR] [org.influxdb.impl.BatchProcessor    ] - Batch could not be sent. Data will be lost
	at okio.Segment.push(Segment.java:111) ~[bundleFile:?]
	at okio.Buffer.writableSegment(Buffer.java:1307) ~[bundleFile:?]
	at okio.Buffer.writeUtf8(Buffer.java:980) ~[bundleFile:?]
	at okio.Buffer.writeUtf8(Buffer.java:961) ~[bundleFile:?]
	at okio.RealBufferedSink.writeUtf8(RealBufferedSink.java:53) ~[bundleFile:?]
	at okhttp3.internal.http1.Http1ExchangeCodec.writeRequest(Http1ExchangeCodec.java:196) ~[bundleFile:?]
	at okhttp3.internal.http1.Http1ExchangeCodec.writeRequestHeaders(Http1ExchangeCodec.java:141) ~[bundleFile:?]
	at okhttp3.internal.connection.Exchange.writeRequestHeaders(Exchange.java:72) ~[bundleFile:?]
	at okhttp3.internal.http.CallServerInterceptor.intercept(CallServerInterceptor.java:43) ~[bundleFile:?]
	at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:142) ~[bundleFile:?]
	at okhttp3.internal.connection.ConnectInterceptor.intercept(ConnectInterceptor.java:43) ~[bundleFile:?]
	at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:117) ~[bundleFile:?]
	at okhttp3.internal.cache.CacheInterceptor.intercept(CacheInterceptor.java:94) ~[bundleFile:?]
	at okhttp3.internal.http.BridgeInterceptor.intercept(BridgeInterceptor.java:93) ~[bundleFile:?]
	at okhttp3.internal.http.RetryAndFollowUpInterceptor.intercept(RetryAndFollowUpInterceptor.java:88) ~[bundleFile:?]
	at org.influxdb.impl.BasicAuthInterceptor.intercept(BasicAuthInterceptor.java:22) ~[bundleFile:?]
	at org.influxdb.impl.GzipRequestInterceptor.intercept(GzipRequestInterceptor.java:42) ~[bundleFile:?]
	at okhttp3.logging.HttpLoggingInterceptor.intercept(HttpLoggingInterceptor.java:152) ~[bundleFile:?]
	at okhttp3.RealCall.getResponseWithInterceptorChain(RealCall.java:229) ~[bundleFile:?]
	at okhttp3.RealCall.execute(RealCall.java:81) ~[bundleFile:?]
	at retrofit2.OkHttpCall.execute(OkHttpCall.java:188) ~[bundleFile:?]
	at org.influxdb.impl.InfluxDBImpl.execute(InfluxDBImpl.java:819) ~[bundleFile:?]
	at org.influxdb.impl.InfluxDBImpl.write(InfluxDBImpl.java:460) ~[bundleFile:?]
	at org.influxdb.impl.OneShotBatchWriter.write(OneShotBatchWriter.java:22) ~[bundleFile:?]
	at org.influxdb.impl.BatchProcessor.write(BatchProcessor.java:340) [bundleFile:?]
	at org.influxdb.impl.BatchProcessor$1.run(BatchProcessor.java:287) [bundleFile:?]
	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) [?:?]
How would one continue to debug this or is it a known issue?
Thanks for the help.
I have the same issue here with exactly same error message.
Already tried to delete the Influx Database and started from scratch but problem is still there.
Did you solve the problem in the meantime?
