I’ve changed one of my switch to a dimmer. Because of that, one of the value switched from integer to float and now, influxdb is throwing error
[.client.write.events.WriteErrorEvent] - The error occurred during writing of data
com.influxdb.exceptions.UnprocessableEntityException: failure writing points to database: partial write: field type conflict: input field “value” on measurement “Lumiere_Atelier” is type float, already exists as type integer dropped=6
well, v2 is a tough one but it’s not THAT hard, if you know what to do…
First step: You’ll need a token to login, best practice is to create one for the job (you’ve done it once before for openHAB… InfluxDB-Web UI…)
second step: As I have to delete some errors in some specific Items on a regular basis I’ve written a very basic shell script:
#! /bin/bash
TOKEN="<insert the complete token here>"
ORG="<your company>"
BUCKET="<bucket name>"
START="2023-11-27T00:00:00Z"
STOP="2023-11-27T23:59:59Z"
influx delete --bucket $BUCKET --predicate '_measurement="<name of the Item>"' --start $START --stop $STOP --org $ORG --token $TOKEN
with the given START and STOP only the values from Nov 27th, 2023 will be erased.
If you want to delete a measurement completely, omit --start and --stop parameter.
Please be aware that <> are only to indicate that text inbetween is a variable.
