Hi
I’m using an openhabian installation with influxDB installed. Had an issue with my old SD card but unfortunately don’t have a backup of the influxDB! Have managed to recover the influxdb files and want to copy them over to a fresh openhabian installation into /var/lib/influxdb. However, i keep getting disk full errors. When looking at the filesystem it appears that influxdb filesystem is 100% full.
Is there a way to increase this filesystem size? I assume it was openhabian install that set this filesystem, but i can’t see anywhere i can change it.
Here;s my filesystem:
Filesystem Size Used Avail Use% Mounted on
/dev/root 29G 9.1G 19G 33% /
devtmpfs 916M 0 916M 0% /dev
tmpfs 950M 0 950M 0% /dev/shm
tmpfs 380M 2.6M 378M 1% /run
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
/dev/mmcblk0p3 30G 28K 28G 1% /storage
/dev/mmcblk0p1 255M 33M 223M 13% /boot
/dev/zram1 721M 36K 669M 1% /opt/zram/zram1
overlay1 721M 36K 669M 1% /var/lib/openhab/persistence
/dev/zram2 323M 316M 0 100% /opt/zram/zram2
overlay2 323M 316M 0 100% /var/lib/influxdb
/dev/zram3 974M 176M 731M 20% /opt/zram/zram3
overlay3 974M 176M 731M 20% /var/log
The old influxDB database files total to around 1gb
Any help appriciated
