This is great! How exactly might one go about testing this?
Is there a git command that can be used to fetch this particular commit into existing directory (/opt/openhabian/functions) of an existing openhabian setup?
followed by running the openhabian-config wizard?
If so, I could potentially give this a whirl on a fresh installation of a Raspberry Pi3B and report back.
… 2 days later…
Right or wrong, I manually merged your updated code to the 2 files (openhab.sh and packages.sh) in the folder /opt/openhabian/functions of my new install which seemed to do the trick!. Then I ran the command
$ sudo openhabian-config
I chose the option to install influxdba+grafana. and i believe it was running using this updated code. However, line 419 should be updated as the message still includes the text “Soon this procedure will also set up the connection between them and with openHAB.” which was misleading…
Anyway, here is the error I received on my raspberryPi 3B. It looks like the wrong package architecture was downloaded.
I corrected manually by downloading the following file:
wget https://dl.grafana.com/oss/release/grafana_5.4.0_armhf.deb
sudo dpkg -i grafana_5.4.0_armhf.deb
Here is the error I received.
$ dpkg -i grafana_5.3.4_arm64.deb
dpkg: error processing archive grafana_5.3.4_arm64.deb (--install):
package architecture (arm64) does not match system (armhf)
Errors were encountered while processing:
$ systemctl daemon-reload
$ systemctl enable grafana-server.service
Failed to enable unit: File grafana-server.service: No such file or directory
