I have a problemwith influxdb i get this error every switch item i think.
2020-12-09 12:19:00.406 [ERROR] [org.influxdb.impl.BatchProcessor ] - Batch could not be sent. Data will be lost
org.influxdb.InfluxDBException$FieldTypeConflictException: partial write: field type conflict: input field “value” on measurement “AThuis_Motion_Stamp” is type integer, already exists as type float dropped=5
at org.influxdb.InfluxDBException.buildExceptionFromErrorMessage(InfluxDBException.java:144) ~[bundleFile:?]
at org.influxdb.InfluxDBException.buildExceptionForErrorState(InfluxDBException.java:173) ~[bundleFile:?]
at org.influxdb.impl.InfluxDBImpl.execute(InfluxDBImpl.java:827) ~[bundleFile:?]
at org.influxdb.impl.InfluxDBImpl.write(InfluxDBImpl.java:460) ~[bundleFile:?]
at org.influxdb.impl.OneShotBatchWriter.write(OneShotBatchWriter.java:22) ~[bundleFile:?]
at org.influxdb.impl.BatchProcessor.write(BatchProcessor.java:340) [bundleFile:?]
at org.influxdb.impl.BatchProcessor$1.run(BatchProcessor.java:287) [bundleFile:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) [?:?]
the previous was a date type this is a switch type from mqtt
2020-12-09 12:18:59.531 [ERROR] [org.influxdb.impl.BatchProcessor ] - Batch could not be sent. Data will be lost
org.influxdb.InfluxDBException$FieldTypeConflictException: partial write: field type conflict: input field “value” on measurement “Bureau1onoff” is type integer, already exists as type float dropped=1
If you don’t need the historic data of those measurements you can try to log in to the influxdb CLI and drop the measurements or create a new influxdb for you OH3 installation (which is what i did when i first installed OH3).
To me this seems to be a problem on influx and not on OH
I think i found where the problem is that when i delete an item in the logging i can’t find any rule that says it’s removed. I remove a entire items file the channels in it and i don’t see anything’s getting removed. So it’s normal that influx is saying that it is already existing it is removed when i updated to openhab3. I will search a work around…
