I installed influxdb + grafana as shown in the tutorial, but i can’t find my data saved in the database, i got this logging:
2018-08-29 01:18:00.160 [ERROR] [org.influxdb.impl.BatchProcessor ] - Batch could not be sent. Data will be lost
retrofit.RetrofitError: unexpected url: http(s)://192.168.137.246:8086/write?u=openhabs&p=AnotherSuperbPassword456-&db=openhab_db&rp=autogen&precision=n&consistency=one
at retrofit.RetrofitError.unexpectedError(RetrofitError.java:44) ~[225:org.openhab.persistence.influxdb:1.12.0]
at retrofit.RestAdapter$RestHandler.invokeRequest(RestAdapter.java:400) [225:org.openhab.persistence.influxdb:1.12.0]
at retrofit.RestAdapter$RestHandler.invoke(RestAdapter.java:240) [225:org.openhab.persistence.influxdb:1.12.0]
at org.influxdb.impl.$Proxy136.writePoints(Unknown Source) [225:org.openhab.persistence.influxdb:1.12.0]
at org.influxdb.impl.InfluxDBImpl.write(InfluxDBImpl.java:151) [225:org.openhab.persistence.influxdb:1.12.0]
at org.influxdb.impl.BatchProcessor.write(BatchProcessor.java:171) [225:org.openhab.persistence.influxdb:1.12.0]
at org.influxdb.impl.BatchProcessor$1.run(BatchProcessor.java:144) [225:org.openhab.persistence.influxdb:1.12.0]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) [?:?]
atjava.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) [?:?]
Caused by: java.lang.IllegalArgumentException: unexpected url: http(s)://192.168.137.246:8086/write?u=openhabs&p=AnotherSuperbPassword456-&db=openhab_db&rp=autogen&precision=n&consistency=one
at com.squareup.okhttp.Request$Builder.url(Request.java:157) ~[?:?]
at retrofit.client.OkClient.createRequest(OkClient.java:58) ~[?:?]
at retrofit.client.OkClient.execute(OkClient.java:53) ~[?:?]
at retrofit.RestAdapter$RestHandler.invokeRequest(RestAdapter.java:326) ~[?:?]
… 12 more
Also in the ssh when i try to check if my created database is working, I don’t have the authorization to check it:
[00:24:38] openhabian@openHABianPi:~$ influx -username admin -password SuperSecretPassword123+ -host localhost
Connected to http://localhost:8086 version 1.6.0
InfluxDB shell version: 1.6.0
show databases
ERR: authorization failed
Warning: It is possible this error is due to not setting a database.
Please set a database with the command "use ".
Please let me know if anyone faced this problem. and thanks
In openhab influxdb.conf you have setup the user as openhab
In your terminal you use admin succesfully
Use the correct password for the user openhab
Or change the user to admin
Hello Vincent,
thank you for your answer. I’m using the correct password for openhab as I think. I couldn’t understand your point of changing the user to admin, could you explain how ? (sorry am still noobi in influxdb ) thanks
Hi, I got the same error even when i changed the user and password, would you mind checking the loggings:
2018-08-29 07:07:35.608 [ERROR] [.internal.InfluxDBPersistenceService] - database connection error unexpected url: http(s)://192.168.137.29:8086/ping
2018-08-29 07:07:35.611 [ERROR] [.internal.InfluxDBPersistenceService] - database connection does not work for now, will retry to use the database.
2018-08-29 07:08:00.085 [ERROR] [org.influxdb.impl.BatchProcessor ] - Batch could not be sent. Data will be lost
retrofit.RetrofitError: unexpected url: http(s)://192.168.137.29:8086/write?u=admin&p=SuperSecretPassword123%2B&db=openhab_db&rp=autogen&precision=n&consistency=one
Do you have any idea how I can reset everything on influxdb? I can’t even create any user now or delete or any action, everytime I have the ERR: authorization failed…
Yeah You are right I forgot to remove the (s) in http(s), I can’t see this error again now, but the authorization is still failing
2018-08-29 07:33:00.630 [ERROR] [org.influxdb.impl.BatchProcessor ] - Batch could not be sent. Data will be lost
java.lang.RuntimeException: {“error”:“authorization failed”}
at org.influxdb.impl.InfluxDBErrorHandler.handleError(InfluxDBErrorHandler.java:19) [225:org.openhab.persistence.influxdb:1.12.0]
at retrofit.RestAdapter$RestHandler.invoke(RestAdapter.java:242) [225:org.openhab.persistence.influxdb:1.12.0]
at org.influxdb.impl.$Proxy135.writePoints(Unknown Source) [225:org.openhab.persistence.influxdb:1.12.0]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) [?:?]
I deleted it and reinstalled and it worked in the first time when i logged without authorization but once I restarted the service I found again the same authorization error. Do you know how to reset all the users? they still all exist after deleting influxdb
