Tried the following rule in openhab 2.2.0-SNAPSHOT, without getting an info…
/* ------------- Garage ist offen (länger als 15 Minuten zwischen 17:00 - 08:00) --------------------
items:
```csv
String GarageOutValue { http="<[beckhoff:2000:JSONPATH($.Garage)]" }
Switch GarageOut { http=">[ON:POST:URL] >[OFF:POST:URL2]" }
rule:
```php
rule "garage"
Item GarageOutValue received update
GarageOut.postUpdate(if(GarageOutValue.state == "on") ON else OFF)
rule "openGarage"
Time cron "0 0/15 17-8 * * ?"
if (GarageOutValue.state == "off" && !GarageOutValue.changedSince(now.minusMinutes(1))){
logInfo(filename, "Garage ist länger als 15 Minuten geöffnet")
//Sende Notification
sendPushbulletNote("DEFAULT", "mail@mail.at", "Garagentor ist seit über 15min geöffnet!", "Garagentor schließen!")
rule "Garage door state"
Item GarageDoor changed
if (GarageDoor.state == "open") {
say("La porte du garage est ouverte")
timerDoor = createTimer(now.plusSeconds(timervalueDoor)) [|
say("La porte du garage est ouverte depuis "+ timervalueDoor + " secondes")
sendMail(maillist, mailsubject, "Porte du garage ouverte depuis "+ timervalueDoor + " secondes " + df.format( new Date() ))
timerDoor.cancel
timerDoor = null
} else if (GarageDoor.state == "closed"){
say("La porte du garage est fermée")
timerDoor.cancel
timerDoor = null
thanks, getting the following error. I deleted the say( ) method. maybe this comes from this call. saved… but maybe not clear recognized, that I delted…
2017-12-11 21:20:58.387 [ERROR] [org.quartz.core.JobRunShell ] - Job DEFAULT.2017-12-11T21:20:58.375+01:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
logInfo(<XFeatureCallImplCustom>,<XStringLiteralImpl>)
sendPushbulletNote(<XStringLiteralImpl>,<XStringLiteralImpl>,<XStringLiteralImpl>,<XStringLiteralImpl>)
<XFeatureCallImplCustom>.cancel
<null>.timerDoor = <XNullLiteralImplCustom>
} ] threw an unhandled Exception:
java.lang.reflect.UndeclaredThrowableException: null
at com.sun.proxy.$Proxy148.apply(Unknown Source) [?:?]
at org.eclipse.smarthome.model.script.internal.actions.TimerExecutionJob.execute(TimerExecutionJob.java:49) [145:org.eclipse.smarthome.model.script:0.10.0.201712081218]
at org.quartz.core.JobRunShell.run(JobRunShell.java:202) [115:org.eclipse.smarthome.core.scheduler:0.10.0.201712081218]
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:573) [115:org.eclipse.smarthome.core.scheduler:0.10.0.201712081218]
Caused by: org.eclipse.smarthome.model.script.engine.ScriptExecutionException: The name 'filename' cannot be resolved to an item or type; line 29, column 27, length 8
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:131) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:901) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:864) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:223) ~[?:?]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.doEvaluate(ScriptInterpreter.java:215) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:203) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluateArgumentExpressions(XbaseInterpreter.java:1115) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._invokeFeature(XbaseInterpreter.java:1045) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeFeature(XbaseInterpreter.java:991) ~[?:?]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:141) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:446) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:227) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:189) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.ClosureInvocationHandler.doInvoke(ClosureInvocationHandler.java:46) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.AbstractClosureInvocationHandler.invoke(AbstractClosureInvocationHandler.java:29) ~[?:?]
... 4 more
2017-12-11 21:21:00.113 [ERROR] [org.quartz.core.ErrorLogger ] - Job (DEFAULT.2017-12-11T21:20:58.375+01:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
} ] threw an exception.
org.quartz.SchedulerException: Job threw an unhandled exception.
at org.quartz.core.JobRunShell.run(JobRunShell.java:213) [115:org.eclipse.smarthome.core.scheduler:0.10.0.201712081218]
Caused by: java.lang.reflect.UndeclaredThrowableException
at com.sun.proxy.$Proxy148.apply(Unknown Source) ~[?:?]
at org.eclipse.smarthome.model.script.internal.actions.TimerExecutionJob.execute(TimerExecutionJob.java:49) ~[?:?]
at org.quartz.core.JobRunShell.run(JobRunShell.java:202) ~[?:?]
... 1 more
... 1 more
So openHAB complains about a name filename. What’s the complete rule?
thank you that was in my logInfo… do I have to include some classes to use logInfo?
my exaclty code looks like this:
import org.openhab.model.script.actions.Timer
var int timervalueDoor = 900
rule "garage"
rule "openGarage"
Item GarageOutValue changed
if (GarageOutValue.state == "off") {
/*logInfo("Garage ist länger als 10 Minuten geöffnet")*/
sendPushbulletNote("DEFAULT", "mymail@mail.at", "Garagentor ist seit über 15min geöffnet!", "Garagentor schließen!")
timerDoor.cancel
timerDoor = null]
} else if (GarageOutValue.state == "on"){
timerDoor.cancel
timerDoor = null
now it sends pushbullet notes! But in my log I can find this error:
2017-12-12 19:49:41.381 [ERROR] [org.quartz.core.JobRunShell ] - Job DEFAULT.2017-12-12T19:49:39.228+01:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
at org.eclipse.smarthome.model.script.engine.ScriptError.<init>(ScriptError.java:66) [145:org.eclipse.smarthome.model.script:0.10.0.201712111157]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:130) [145:org.eclipse.smarthome.model.script:0.10.0.201712111157]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:901) [164:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:864) [164:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:223) [164:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.doEvaluate(ScriptInterpreter.java:215) [145:org.eclipse.smarthome.model.script:0.10.0.201712111157]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:203) [164:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:759) [164:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:219) [164:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:446) [164:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:227) [164:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:189) [164:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.xtext.xbase.interpreter.impl.ClosureInvocationHandler.doInvoke(ClosureInvocationHandler.java:46) [164:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at org.eclipse.xtext.xbase.interpreter.impl.AbstractClosureInvocationHandler.invoke(AbstractClosureInvocationHandler.java:29) [164:org.eclipse.xtext.xbase:2.12.0.v20170519-0752]
at com.sun.proxy.$Proxy145.apply(Unknown Source) [?:?]
at org.eclipse.smarthome.model.script.internal.actions.TimerExecutionJob.execute(TimerExecutionJob.java:49) [145:org.eclipse.smarthome.model.script:0.10.0.201712111157]
at org.quartz.core.JobRunShell.run(JobRunShell.java:202) [115:org.eclipse.smarthome.core.scheduler:0.10.0.201712111157]
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:573) [115:org.eclipse.smarthome.core.scheduler:0.10.0.201712111157]
2017-12-12 19:49:41.414 [ERROR] [org.quartz.core.ErrorLogger ] - Job (DEFAULT.2017-12-12T19:49:39.228+01:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
at org.quartz.core.JobRunShell.run(JobRunShell.java:213) [115:org.eclipse.smarthome.core.scheduler:0.10.0.201712111157]
Caused by: java.lang.NullPointerException
at org.eclipse.smarthome.model.script.engine.ScriptError.<init>(ScriptError.java:66) ~[?:?]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:130) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:759) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:219) ~[?:?]
at com.sun.proxy.$Proxy145.apply(Unknown Source) ~[?:?]
... 1 more
do I have to declare the variable timerDoor ? I only declared timervalueDoor…
Yes, you have to define timerDoor. As you use openHAB2.x, you don’t need to define Timer actions.
If using a timer, it’s recommended to test if the timer is already running:
val int timervalueDoor = 900 //val -> will not change, constant value
var Timer timerDoor = null
rule "openGarage"
if (GarageOutValue.state.toString == "off") {
if(timerDoor!==null) //no curly brackets, so only the next command will be executed
timerDoor.cancel
logInfo("garage","Garage ist länger als {} Sekunden geöffnet!",timervalueDoor)
timerDoor = null //timer already expired, no need to cancel
else if (GarageOutValue.state.toString == "on") {
timerDoor.cancel //cancel timer
timerDoor = null //and reset to null
Please keep attention to the .state.toString part. Actually, “on” or “off” are strings but not states. However, openHAB2 will silently convert the state to a string, but there are situations where this does not work as expected, so always be aware of the difference between a state and a string.
