Hi
I have troubles with the initlization of my Fibaro Door Sensor FGK101. Node shows up in openHab 2 PaperUI. But no data (Battery Level, Door Open Status) is displayed in the control panel.
No node.xml was created for the node.
I attached the log file and some screen shots:
12:39:06.342 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 13 00 49 84 02 0D 04 07 01 5E 59 22 80 56 7A 72 73 98 86 BA
12:39:06.343 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
12:39:06.343 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 13 00 49 84 02 0D 04 07 01 5E 59 22 80 56 7A 72 73 98 86 BA
12:39:06.344 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 13 00 49 84 02 0D 04 07 01 5E 59 22 80 56 7A 72 73 98 86 BA
12:39:06.344 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationUpdate[0x49], type=Request[0x00], priority=High, dest=255, callback=0, payload=84 02 0D 04 07 01 5E 59 22 80 56 7A 72 73 98 86
12:39:06.346 [DEBUG] [essage.ApplicationUpdateMessageClass] - NODE 2: Application update request. Node information received.
12:39:06.346 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: Node is ALIVE. Init stage is WAIT.
12:39:06.347 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveNodeStatusEvent
12:39:06.347 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 2: Node Status event during initialisation - Node is ALIVE
12:39:06.347 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 2: Node advancer - WAIT: queue length(0), free to send(true)
12:39:06.347 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 2: Node advancer: loop - WAIT try 1: stageAdvanced(false)
12:39:06.347 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 2: Node advancer: WAIT - Listening=false, FrequentlyListening=false
12:39:06.347 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 2: Node advancer: WAIT - Still waiting!
12:39:06.348 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Got an event from Z-Wave network: ZWaveNodeStatusEvent
12:39:06.348 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Setting ONLINE
12:39:06.352 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'zwave:device:984dd667:node2' changed from ONLINE: Node initialising: WAIT to ONLINE
12:39:06.349 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 2: Node Status event - Node is ALIVE
12:39:06.353 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 2: Creating new instance of command class ZWAVE_PLUS_INFO
12:39:06.354 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 2: Command class ZWAVE_PLUS_INFO, endpoint null created
12:39:06.358 [DEBUG] [essage.ApplicationUpdateMessageClass] - NODE 2: Application update is adding command class ZWAVE_PLUS_INFO.
12:39:06.359 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: Adding command class ZWAVE_PLUS_INFO to the list of supported command classes.
12:39:06.360 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 2: Creating new instance of command class ASSOCIATION_GROUP_INFO
12:39:06.361 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 2: Command class ASSOCIATION_GROUP_INFO, endpoint null created
12:39:06.361 [DEBUG] [essage.ApplicationUpdateMessageClass] - NODE 2: Application update is adding command class ASSOCIATION_GROUP_INFO.
12:39:06.362 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: Adding command class ASSOCIATION_GROUP_INFO to the list of supported command classes.
12:39:06.363 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 2: Creating new instance of command class APPLICATION_STATUS
12:39:06.363 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 2: Command class APPLICATION_STATUS, endpoint null created
12:39:06.364 [DEBUG] [essage.ApplicationUpdateMessageClass] - NODE 2: Application update is adding command class APPLICATION_STATUS.
12:39:06.365 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: Adding command class APPLICATION_STATUS to the list of supported command classes.
12:39:06.365 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 2: Creating new instance of command class BATTERY
12:39:06.366 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 2: Command class BATTERY, endpoint null created
12:39:06.366 [DEBUG] [essage.ApplicationUpdateMessageClass] - NODE 2: Application update is adding command class BATTERY.
12:39:06.367 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: Adding command class BATTERY to the list of supported command classes.
12:39:06.367 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 2: Creating new instance of command class CRC_16_ENCAP
12:39:06.368 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 2: Command class CRC_16_ENCAP, endpoint null created
12:39:06.369 [DEBUG] [essage.ApplicationUpdateMessageClass] - NODE 2: Application update is adding command class CRC_16_ENCAP.
12:39:06.369 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: Adding command class CRC_16_ENCAP to the list of supported command classes.
12:39:06.370 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 2: Creating new instance of command class FIRMWARE_UPDATE_MD
12:39:06.371 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 2: Command class FIRMWARE_UPDATE_MD, endpoint null created
12:39:06.372 [DEBUG] [essage.ApplicationUpdateMessageClass] - NODE 2: Application update is adding command class FIRMWARE_UPDATE_MD.
12:39:06.372 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: Adding command class FIRMWARE_UPDATE_MD to the list of supported command classes.
12:39:06.373 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 2: Creating new instance of command class MANUFACTURER_SPECIFIC
12:39:06.373 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 2: Command class MANUFACTURER_SPECIFIC, endpoint null created
12:39:06.374 [DEBUG] [essage.ApplicationUpdateMessageClass] - NODE 2: Application update is adding command class MANUFACTURER_SPECIFIC.
12:39:06.375 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: Adding command class MANUFACTURER_SPECIFIC to the list of supported command classes.
12:39:06.375 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 2: Creating new instance of command class POWERLEVEL
12:39:06.376 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 2: Command class POWERLEVEL, endpoint null created
12:39:06.376 [DEBUG] [essage.ApplicationUpdateMessageClass] - NODE 2: Application update is adding command class POWERLEVEL.
12:39:06.388 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: Adding command class POWERLEVEL to the list of supported command classes.
12:39:06.389 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 2: Creating new instance of command class SECURITY
12:39:06.390 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 2: Command class SECURITY, endpoint null created
12:39:06.391 [INFO ] [mmandclass.ZWaveSecurityCommandClass] - NODE 2: setupNetworkKey useSchemeZero=false
12:39:06.393 [DEBUG] [essage.ApplicationUpdateMessageClass] - NODE 2: Application update is adding command class SECURITY.
12:39:06.393 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: Adding command class SECURITY to the list of supported command classes.
12:39:06.394 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveSecurityCommandClassWithInitialization@2fb226fd already registered
12:39:06.394 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 2: Creating new instance of command class VERSION
12:39:06.395 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 2: Command class VERSION, endpoint null created
12:39:06.396 [DEBUG] [essage.ApplicationUpdateMessageClass] - NODE 2: Application update is adding command class VERSION.
12:39:06.397 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: Adding command class VERSION to the list of supported command classes.
12:39:06.400 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=IsFailedNodeID[0x62], type=Request[0x00], priority=High, dest=255, callback=0, payload=02
12:39:06.401 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=ApplicationUpdate[0x49], type=Request[0x00], priority=High, dest=255, callback=0, payload=84 02 0D 04 07 01 5E 59 22 80 56 7A 72 73 98 86
12:39:06.402 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=ApplicationUpdate, callback id=0, expected=IsFailedNodeID, cancelled=false MISMATCH
Some help would be much appreciated.
Many thanks,
Oliver
