I’m using the old SHC 1.0 from Innogy. In my log I can see, it reconnects sometimes to the Innogy service
... internal.InnogyWebSocket] - Connected to innogy Webservice.
Then it sends commands to my innogy remotecontrol or a lightswitch. Of course this makes little sense in a smarthome.
I don’t think, that one can provide a solution here, so my question is,
can anyone tell me, that the problem doesn’t exist with a SHC 2.0?
Then I would buy one …
Currently I have no time to invest it further. Maybe you could use proxy items so that the unwanted button push switches the proxy item. Then a rule reacts to the proxy item change and checks, if the SHC came back in the last 3 seconds and ignores in that case. Else is switches the real item like a light or in my case the tv.
This is a great idea, thank you. In fact I already use the Log Reader Binding to monitor the reconnection from Innogy service, but I could only correct the switching afterwards.
Do you have a different procedure for monitoring the Innogy service?
This is my rule to send me pushes when it changes connection state:
rule "InnogyBridgeThingUpdate"
Thing "innogysmarthome:bridge:SMARTHOME06" changed
val bridgeStatus = getThingStatusInfo("innogysmarthome:bridge:SMARTHOME06").getStatus()
logInfo("Thingstatus", "Innogy SHC ist nun " + bridgeStatus.toString())
sendPushoverMessage(pushoverBuilder("Innogy Bridge is " + bridgeStatus.toString()))
For information only.
I now have my SHC 2.0 and no more problems in openhab. All data from the SHC 1.0 was transferred without any problems and even in Openhab only a new Auth-Key was necessary.
