I cannot add a thing for the GenerationMeter to openhab 3.
The Smart Home Controller is configured correctly and only. All other devices are working.
Steps:
- manually added Thing
- select binding: innogy
- select Generation Meter
- use the generated Unique ID as the ID for the Thing configuration
- select the Bridge
I get the following in the log:
2021-04-25 10:27:31.703 [WARN ] [internal.handler.InnogyDeviceHandler] - initializeProperties: The device with id 872c6cc176 isn’t found
2021-04-25 10:27:31.706 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘innogysmarthome:GenerationMeter:innogySHC:872c6cc176’ changed from INITIALIZING to OFFLINE (GONE): Device not found in innogy config. Was it removed?
Is it still needed to have a innogy config file in OH3?
Is the generated Unique ID the correct value for the ID in the configuration of the Thing?
Any help is appreciated.
[System is running on PI4 with openhab version 3.0.2 Release Build]
