Hey Hilbrand,
your binding is running in my OH 2.4 instance since yesterday without any problems. it seems to be like my last Version.
ralph
Hey Hilbrand,
ralph
Hey all, thanks for the effort taking the binding to the next level!
I did a quick test on my 2.4 setup and it works fine so far. Will keep an eye on it and reportâŠ
Hey Hilbrand,
just to let you know: the button-press behavior changed. Now every button press (not only the first) fires two button-pressed events as well as a button press that wasnât pressed. In this case on the device (dimmer switch) I was controlling with âbutton1â. If I control another device with no buttons, no additional button pressed event fires.
2019-11-19 12:25:12.626 [vent.ChannelTriggeredEvent] - innogysmarthome:WSC2:SMARTHOME10:51a5bfb1b4f543a99646116134cadcd7:button1 triggered PRESSED
2019-11-19 12:25:12.648 [vent.ChannelTriggeredEvent] - innogysmarthome:WSC2:SMARTHOME10:51a5bfb1b4f543a99646116134cadcd7:button1 triggered PRESSED
2019-11-19 12:25:14.720 [vent.ChannelTriggeredEvent] - innogysmarthome:ISD2:SMARTHOME10:e45e5bc6848b4dc6b5bac1a575271fa8:button2 triggered PRESSED
This is when you press a button on the device, right? Can you log with trace level some time before and after the press and send the log to me via direct message. Iâll have a look and see if Ican find what is going on.
Hello @hilbrand.
I recognized that the binding uses invertValueIfConfigured
for the values of the CHANNEL_ROLLERSHUTTER
As my home is configured to use 100% as âclosedâ and 0% as âopenâ I would really need to use this setting - but I was not able to find the corresponding config for the binding or the Rollershutter-Thing.
Could you provide some information on how to use the invert on ISR2? I know that some other bindings support the invert for shutter devices.
Thanks and have a good one,
Jörn
Iâve updated the binding on the location mentioned above (20/11/2019 15:00). Iâve added a channel option invert
to the rollershutter channel. If you configure it with true
it will work with 100% closed 0% open. Btw ON/OFF is not a valid state for rollershutters so Iâve changed this to UP/DOWN.
this behaviour comes from a change made by me.
before my Change the Event was only fired when different Buttons are pressed. i think there is a bug in the innogy-api because pressing buttons are not handled correct in the innogy-app too.
i have reported a bug at innogy but i have no Feedback from them.
perhaps somebody can do a WorkaroundâŠi was not able toâŠ
Ralph
Wow - Iâm impressed
I will update my binding tomorrow and test the channel option. I assume it needs to be applied like this:
Thing ISR2 Shutter_Some "Shutter" @ "Room" [ id="blablablubs", invert=true ]
Thank you.
Hi @RalphSester. Do you have detailed description of the bug? There might be a chance to clarify the behavior directly with the devâŠ
I did some investigating with Hilbrand. He was able to fix the button-press issue. With the updated binding everything works fine for me. Even long presses. Thank you again for that.
i have sent you some detailled stuffâŠâŠ
Thanks - I will try to clarify the behavior and come back with results (if I have some)
Hi @hilbrand,
I did a smoke test with the âinvertâ option as mentioned before on one of my shutters.
I did not recognize any changes to the displayed level of the shutter - the Item is still on 100% although the shutter is fully opened.
Next step is to change to debug loglevel and give it another tryâŠ
You used the configuration on the thing. I added it on the channel. I think it should be something like this:
Thing ISR2 Shutter_Some âShutterâ @ âRoomâ [ id=âblablablubsâ ] {
Channel: rollershutter:RollerShutterActuator [invert=true]
Ok, thanks - I will test it as soon as I have some time for it and come back with the results.
Hello @hilbrand.
I had the chance to test it:
My things-file:
Thing ISR2 Shutter_Bathroom "Shutter" @ "Bathroom" [ id="blablablubsid" ] { channel: rollershutter:RollerShutterActuator [invert=true] }
The items-file:
Rollershutter ShutterBathroomPosition "Bad [%.1f %%]" (Shutter, ShutterPosition) { channel="innogysmarthome:ISR2:zuhause:Shutter_Bathroom:rollershutter" }
The binding will not load any Things with a config entry like that.
Any idea?
Edit: also Rollershutter ShutterBathroomPosition "Bad [%.1f %%]" (Shutter, ShutterPosition) {channel="innogysmarthome:ISR2:zuhause:Shutter_Bathroom:rollershutter" [invert=true] }
in the items-file didnât change the value.
I guess it doesnât load the things file correct and therefor the item doesnât get updated. I think my example might not be correct. Iâm not very familiar with configuring channel parameters of existing channels. Here is an updated example:
Channels:
Type rollershutter:RollerShutterActuator [invert=true]
You could also try to create the thing in PaperUI. You should be able to configure the channel in PaperUI.
As mentioned before the binding works fine for me (OH 2.5 and SHC 2.0). I only note from time to time that communication stops. This might be related to issues of the new SHC 2.0 or the innogy backend.
To workaround I set WebSocket Idle Timeout in Seconds to 300 seconds.
This was a hint from Hilbrand who already looked a the trace files I provided.
By the way: @Hilbrand: Thank you very much for your help.
Juergen
This night my SHC 2.0 received a forced update to version 8.16-1.1.12.269. This caused the binding to close the connection â2019-11-29 03:30:50.278 [INFO ] [gysmarthome.internal.InnogyWebSocket] - Connection to innogy Webservice was closed normally.â
Unfortunately the connection was not reestablished automatically. After a restart of OH everything seems to be fine. Values are refreshed, commands can be sent.
Juergen
Hi at all,
first of all I would like to thank all those who develop this binding especially @hilbrand without his own hardware. Youâre doing a great job!
I can confirm the observation of Juergen that the binding from time to time loses the connection without reconnecting (version 2.5.0.201911042017):
3:15:36.344 [WARN ] [internal.handler.InnogyBridgeHandler] - Unknown exception
java.util.concurrent.TimeoutException: Idle
timeout expired: 900000/900000 ms
at org.eclipse.jetty.io.IdleTimeout.checkIdleTimeout(IdleTimeout.java:166) [75:org.eclipse.jetty.io:9.4.11.v20180605]
at org.eclipse.jetty.io.IdleTimeout$1.run(IdleTimeout.java:50) [75:org.eclipse.jetty.io:9.4.11.v20180605]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:?]
2019-11-30 03:15:36.347 [INFO ] [gysmarthome.internal.InnogyWebSocket] - Connection to innogy Webservice was closed abnormally (code: 1001). Reason: Idle Timeout
2019-11-30 03:16:06.399 [hingStatusInfoChangedEvent] - 'innogysmarthome:bridge:8423c0c3' changed from OFFLINE: Idle timeout expired: 900000/900000 ms to OFFLINE (COMMUNICATION_ERROR): java.util.concurrent.ExecutionException: java.io.EOF
Exception: HttpConnectionOverHTTP@28958fe6(l:/192.168.7.6:45010 <-> r:api.services-smarthome.de/193.25.80.79:443,closed=false)=>HttpChannelOverHTTP@15ea5ab9(exchange=HttpExchange@16b6fe24 req=TERMINATED/null@null res=PENDING/null@null)[
send=HttpSenderOverHTTP@2c28e050(req=QUEUED,snd=COMPLETED,failure=null)[HttpGenerator@2846b08c{s=START}],recv=HttpReceiverOverHTTP@6f3e08af(rsp=IDLE,failure=null)[HttpParser{s=CLOSED,0 of -1}]]<-DecryptedEndPoint@4ed88cb2{api.services-s
marthome.de/193.25.80.79:443<->/192.168.7.6:45010,OPEN,fill=-,flush=-,to=930307/0}->HttpConnectionOverHTTP@28958fe6(l:/192.168.7.6:45010 <-> r:api.services-smarthome.de/193.25.80.79:443,closed=false)=>HttpChannelOverHTTP@15ea5ab9(exchan
ge=HttpExchange@16b6fe24 req=TERMINATED/null@null res=PENDING/null@null)[send=HttpSenderOverHTTP@2c28e050(req=QUEUED,snd=COMPLETED,failure=null)[HttpGenerator@2846b08c{s=START}],recv=HttpReceiverOverHTTP@6f3e08af(rsp=IDLE,failure=null)[
HttpParser{s=CLOSED,0 of -1}]]->SocketChannelEndPoint@2599cf59{api.services-smarthome.de/193.25.80.79:443<->/192.168.7.6:45010,ISHUT,fill=-,flush=-,to=49/0}{io=0/0,kio=0,kro=1}->SslConnection@38c6d9b6{NEED_WRAP,eio=-1/-1,di=-1}=>HttpCon
nectionOverHTTP@28958fe6(l:/192.168.7.6:45010 <-> r:api.services-smarthome.de/193.25.80.79:443,closed=false)=>HttpChannelOverHTTP@15ea5ab9(exchange=HttpExchange@16b6fe24 req=TERMINATED/null@null res=PENDING/null@null)[send=HttpSenderOve
This was most probably not caused by an internet reconnect. Often itâs working
java.util.concurrent.TimeoutException: Idle timeout expired: 900000/900000 ms
2019-12-01 05:10:52.899 [INFO ] [gysmarthome.internal.InnogyWebSocket] - Connection to innogy Webservice was closed abnormally (code: 1001). Reason: Idle Timeout
2019-12-01 05:11:24.488 [INFO ] [gysmarthome.internal.InnogyWebSocket] - Connected to innogy Webservice.
With the newest version from 29/11/2019 I get following exception:
org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.innogysmarthome [239]
Unresolved requirement: Import-Package: com.google.gson; version="[2.8.0,3.0.0)"
at org.eclipse.osgi.container.Module.start(Module.java:444) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:383) ~[?:?]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundle(DirectoryWatcher.java:1260) [10:org.apache.felix.fileinstall:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundles(DirectoryWatcher.java:1233) [10:org.apache.felix.fileinstall:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startAllBundles(DirectoryWatcher.java:1221) [10:org.apache.felix.fileinstall:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.doProcess(DirectoryWatcher.java:515) [10:org.apache.felix.fileinstall:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.process(DirectoryWatcher.java:365) [10:org.apache.felix.fileinstall:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.run(DirectoryWatcher.java:316) [10:org.apache.felix.fileinstall:3.6.4]
Thanks again!
Martin
