fanavity
(Patrik)
May 5, 2022, 12:29pm
#1
i have a Dahua VTO and want open the Door via HTTP-Binding. i Configured the item as followed:
UID: http:url:4c0a43d049
label: Klingeln
thingTypeUID: http:url
configuration:
ignoreSSLErrors: true
baseURL: https://192.168.178.15/cgi-bin/accessControl.cgi?action=openDoor&channel=1&UserID=101&Type=Remote
password: ***
delay: 0
stateMethod: GET
refresh: 30
commandMethod: GET
contentType: text/html
timeout: 3000
username: admin
bufferSize: 2048
authMode: BASIC
With this, i get the following Error:
Requesting ‘https://192.168.178.15/cgi-bin/accessControl.cgi?action=openDoor&channel=1&UserID=101&Type=Remote ’ (method=‘GET’, content=‘null’) failed: Received fatal alert: handshake_failure
What i want: a switch what i can switch on to open the door →
Switch switchKlingel {channel="http:url:4c0a43d049:KlingelSwitch", expire="5s, state=OFF"}
I only will post the URL on “ON”, not on “OFF”
This is my old PHP-Call wich works very well:
$url = "https://192.168.178.15/cgi-bin/accessControl.cgi?action=openDoor&channel=1&UserID=101&Type=Remote";
$ch = curl_init();
curl_setopt($ch, CURLOPT_URL, $url);
curl_setopt($ch, CURLOPT_HTTPAUTH, CURLAUTH_DIGEST);
curl_setopt($ch, CURLOPT_USERPWD, "admin:***");
curl_setopt($ch, CURLOPT_SSL_VERIFYPEER, 0);
curl_exec($ch);
curl_close($ch);
The Dahua VTO use a self sigend SSL-Certificate. I hope you can help me, because il will remove the old PHP Script
fanavity:
Check the binding’s docs for ignoreSSLErrors
. This option can be used to ignore SSL errrors because of problems with certificates.
fanavity
(Patrik)
May 5, 2022, 6:37pm
#3
Look at m thing description in the first post. I have set this option to true, but without any result change. If call this url ok the browser, I have to type user and password. After that the door opens.
Oops. Sorry, must have missed that row.
The source code contains these rows:
logger.info("Using the insecure client for thing '{}'.", thing.getUID());
logger.info("Using the secure client for thing '{}'.", thing.getUID());
Setting the log level to info is the line with the insecure message being shown ?
fanavity
(Patrik)
May 6, 2022, 7:07am
#5
Yes i see this output…
2022-05-05 13:54:12.288 [WARN ] [p.internal.http.HttpResponseListener] - Requesting 'https://192.168.178.15/cgi-bin/accessControl.cgi?action=openDoor&channel=1&UserID=101&Type=Remote' (method='GET', content='null') failed: Received fata$
2022-05-05 13:54:12.306 [INFO ] [nding.http.internal.HttpThingHandler] - Using the insecure client for thing 'http:url:4c0a43d049'.
Looks like the most interesting part of the warning ( first row ) is cut off.
fanavity
(Patrik)
May 8, 2022, 9:54am
#7
Sorry,
here is the message:
Requesting 'https://192.168.178.15/cgi-bin/accessControl.cgi?action=openDoor&channel=1&UserID=101&Type=Remote' (method='GET', content='null') failed: Received fatal alert: handshake_failure
fanavity
(Patrik)
May 10, 2022, 10:33am
#8
I have solved it by Bash-Script now. That works very well
