i would greatly appreciate some hints regarding the solution, possible products or models for controlling relays.
Situation (pre-home automation):
Most installed lights are controlled via push-buttons, so every light is switched via a relay, that is triggered by push-buttons (look like ordinary light switches). I did this to have more flexibility when automating that later on.
The relays are all located in one place that happens to be near the openhab server. The relays (around 20) are “Eltako Stromstoßschalter”, something like this: Eltako ES12DX-UC
Desired goal:
“Later on” is more or less now, and i dont know what products to use. All push-buttons should remain active as they are, i just want additional control via openhab. Like an virtual additional push-button in form of openhab. Are there any network-attached devices that can control those relays? Standalone or something that connects to a server (USB, serial, …). Most important would be, that it is fully controllable via openhab of course
If anyone has suggestions regarding this matter it would be of great help, as i think there neat products out there, i just dont find them.
(Unfortunately) there will be many possible scenarios and solutions.
I would go back to the beginning and ask: what do you want to ultimately achieve?
This question is very important; because, while you’ve started with thinking ahead and by putting Eltakos in, another relay board of sort can then add the OH control. However, what if you then ask further: What if I want to dim these?
Then the relay board was the wrong answer. Instead of ripping out the Eltakos, you now rip out the relay board(s) too.
There will be heaps of possibilities; you may want to state, whether you want to build your own thing, or you are not a DIY person and want to buy a COTS system.
I am not discouraging DIY solutions, but there are insurance, resale value, and liability issues which need to be considered too.
I did something similar with my outdoor lights - starting from a very basic standard installation (no Eltakos’s) but every switch and light cabling was concentrated in one point. For me the least expensive way was:
Take an RPi ZeroW and a simple RelayBoard that is directly attachable to GPIO pins.
Connect each standard switch to a GPIO pin. I had to attach some simple R/C high pass to eliminate state flapping due to long and standard (non shielded) wires.
Use Node-RED to translate GPIO states to/from MQTT messages. That is really easy with Node-RED (used a python script before).
Use openhab to provide the switching logic based on incomming and outgoing MQTT messages.
Even if regular switches are used they behave like buttons - every state change is considered a switching action.
In my first approach I used not “Stromstoßschalter” but “Installationsrelais” switchable by low voltage until I noticed that the small relay boards are capable of directly switching 230V/10A.
Certainly an inspiration…
… and while it may work, it violates electrical code in most countries; e.g. low frequency induction, cross talk, differential mode noise, GPIO pins not protected; as ex 230V wires still run amongst the 230V wires, but now with 5V.
You could use ITEAD 4-channel relay devices like this and create 200ms 230V pulses like you do with your wall pushbuttons,
Then you don’t know the state of your Eltaco and need to read it back with an Opto Interface.
Next step could be to throw out the Eltacos and switch the load directly with the ITEAD Box. But then you need your OH running to get the lights on with the wall button.
That is very true. Right now there is only 1 light that can be dimmed via the push-button, a special kind of Eltako-Relay is taking care of that. Ideally the relay-board can control that function, too. The relay works that way that pressing the push-button longer starts dimming the light, releasing and pressing again alters the brightness in the other way, so nothing too fancy.
i’d really like to implement a solution that is conform to all or at least most of the standards regarding electricity.
I will look into the other proposed ideas later, thanks for the replys so far
I use pulse-type relays for lighting control. On/off without dimming is ok for me, it’s a warehouse. Multiple push switches allow manual control from more than one place, when Openhab (or rather my rules) can’t guess what is needed, or of course if any part of system is broken.
Getting some feedback to OpenHAB about the actual state of the lights is vital I think. You can get relays with spare contacts that can be linked to OH inputs, or fancy opto detectors. I found it most cost effective to simply put a cheap mains relay on the light circuit so its contacts could signal to OH the on/off state. I’ve the luxury of plenty of space in a cabinet.
Bonus of feedback; no need for timers to turn off OH’s simulated pushbutton, just cancel it when the feedback says the lights have changed state.
Bonus of feedback; smarter rules. If someone manually turned the lights OFF, they probably don’t want OH to turn them on again by motion detection in the next few minutes.
Bonus of feedback; presence detection. If lights change state while OH isn’t using its simulated pushbutton, there’s somebody there using a real pushbutton.
The practical, I chose Modbus in part because of long wiring runs (100 metre). Used Modbus modules with low-power relay contact outputs for the pushbutton simulation, and opto isolated digital inputs for the feedback contacts. Spare inputs used for PIRs etc.
Housed in a separate cabinet adjacent to the mains relays, and even though the linking ‘pushbutton’ and ‘feedback’ wires are low voltage, used mains rated wires between the boxes.
That’s all a bit industrial, but in a domestic setting would be best done at some kind of central box(es) if you can wire/rewire for that.
At home though, you’re likely to want at least some dimming and that might force a completely different approach.
That sounds alot like what i am doing. I could get additional main-relays in the circuit to detect wether the light is on or off, but how do you control your lights that way? What modules do you use to do that task?
Yes. It’s just a convenient way to hook up many on/off style inputs and outputs to OpenHAB.
The choice of Modbus was about distances, hardwired, expandable, common technology.
Yes, me. Just connected in parallel the touch buttons from the wall switch.
But i doubt that is legal after DIN standards…
IT works as expected and wanted.
Provided you use mains rated cable to run to the wall switches (in case of a fault it might need to carry the mains current of the supply breaker/fuse for the whole SONOFF) - and mains rated switches - I would say you’ve taken reasonable care, the same as if it were a purpose made unit.
The only iffy part is modifying the SONOFF board to provide connections for the external wiring.
I did it via a Koppelrelais (sorry i know only the german word…)
to get a safe and potentail free “sonoff button key press” ->on a GPIO Pin
The momentary wall switch(es) goes to the Eltako and the Koppelrelais
So i have full control via OpenHab and the momentary switches (with correct state in OH)
No change in the existing solution. The Sonoff Solution is on Top.
After carefully reading about the suggested ideas i came to the conclusion, that this doesnt solve my problem -
if i understood all correctly, that is.
I need some kind of ethernet-controlled push-button (not a switch). As i am not experienced with electrical installation i’d strongly prefer some out-of-the-box product.
To sum it up:
ethernet connection (not WLAN) or USB, RS232 … something with a cable
controllable by OpenHAB
emulates a push button (“Taster” in german), not a permanent switch with something like 12-24v
has security measures included, e.g. for handling inductive loads and a prevention of permanent switching (if OpenHAB somehow fails or something else happens it must always be the case that it is always a short impuls, as a permanent switching could possible damage my Eltakos)
satisfies all regulations for EU/GER as i dont like surprises with my insurance company in case all goes wrong …
out-of-the-box product, my electronical skills arent good enough to build a safe and working product on my own
Price is not a top priority, as is the load, because they just control the Eltakos which switch the load (lights etc). Is there any product that can do this? I found tons if relays which do switching by now, but none that genuinely have a “push button” feature.
No you don’t, the existing wires to your existing switch will do nicely. You only need to close a circuit! You’ll only need to replace your existing switch with a push button one. Available at all electrical supply shop.The trick is the other end of these wires, where do they go. Normally switched are wired in a loop with the light fixtures and don’t come back directly to the main board.
You are probably going to need an electrician anyway. So I would pass a cat5 wire from the switch socket in the wall to the electrival panel. That will give you 4 pairs of wires to play with. Potentially 4 push buttons on the wall forn different applications.
Yes, i need to close a curcuit. But only for a short amount of time, as if the real button on the wall is pushed. Maybe my description of the setup was not detailled enough, let me have another shot
I have the light(bulb) in the room, with 2 wires to the eltakos. I have the push button in the same room for that light, with another 2 wires to the eltako. If i push the button, the eltako (Stromstoßschalter Eltako ES12DX-UC) closes the releay and the light is switched on. If i push the button another time, the eltako switches it off again. The push buttons use a low voltage circuit for triggering the eltako.
Now i want to add control via OpenHAB, without removing any of the existing hardware. I want another pushbutton for every light, that can be controled via OpenHAB. The eltako supports multiple push buttons for one load, so that isnt an issue. I just need some kind of module that pushes the button for me
I hope that was more understandable … maybe i do a drawing when i am home, should be much clearer then.
Ok, I get is. You need to put a relay in parallel with the existing pushbutton wires going into the elkato. Follow?
You could use a wemos d1 mini with a relay (£5 to £10) total
Flash tasmota on the wemos and set up the relay with a timer in tasmota to send a pulse into the elkato simulating the pushbutton
Send command to the wemos via mqtt
