halloween
(Hallo Ween)
February 10, 2017, 7:16am
1
i have installed a new debian installation (64bit) with latest debian 8 version.
Now i installed Java 8 with this how-to https://debian-blog.org/java-8-installieren/
Oracle Java 8 from webupd8 servers.
Now i get this outpoot:
root@debian:/# java -version
java version "1.8.0_121"
Java(TM) SE Runtime Environment (build 1.8.0_121-b13)
Java HotSpot(TM) 64-Bit Server VM (build 25.121-b13, mixed mode)
root@debian:/#
Is this the right java version for OH2? Or is this 64bit version and i have to install 32bit version?
What do i have to do if i have the wrong version installed?
Dim
(Angelos)
February 10, 2017, 8:03am
2
Yes, it’s fine for OH2.
You have installed the 64-bit version of Java JDK 8 (Java Development Kit), which includes JRE (Java Runtime Environment).
The latest recommendation from the openHAB team is to use Zulu (see: http://docs.openhab.org/installation/index.html#prerequisites ) but Oracle JDK 8 update 101 and above should be fine.
The 32-bit version of Java is recommended for ARM systems running a 64-bit O/S to get the serial connections to work.
This limitation does not apply to regular x64 systems
You can always switch by:
update-alternatives --config java
halloween
(Hallo Ween)
February 10, 2017, 8:11am
3
Hm, few days ago i looked into the openhab manual and there was nothing written with zulu… Oracle Java was the recommended version.
But if it´s working with this oracle java too, than no reason to switch.
Thank you.
