I followed along with the Linux install guide here on OpenHab.org
I got to the point of run the command sudo systemctl start openhab2.service
After executing that command I went to grab coffee and toast. When I got back, I ran the next command sudo systemctl status openhab2.servic
and this is what it returns.
pi@RaspberryPi:~ $ sudo systemctl status openhab2.service
● openhab2.service - openHAB 2 - empowering the smart home
Loaded: loaded (/usr/lib/systemd/system/openhab2.service; disabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Sat 2017-11-25 08:22:58 CST; 10min ago
Docs: http://docs.openhab.org
https://community.openhab.org
Process: 1709 ExecStop=/usr/share/openhab2/runtime/bin/stop (code=exited, status=127)
Process: 1643 ExecStart=/usr/share/openhab2/start.sh server (code=exited, status=127)
Main PID: 1643 (code=exited, status=127)
Nov 25 08:22:58 RaspberryPi systemd[1]: openhab2.service: Control process exited, code=exited status=127
Nov 25 08:22:58 RaspberryPi systemd[1]: openhab2.service: Unit entered failed state.
Nov 25 08:22:58 RaspberryPi systemd[1]: openhab2.service: Failed with result 'exit-code'.
Nov 25 08:22:58 RaspberryPi systemd[1]: openhab2.service: Service hold-off time over, scheduling restart.
Nov 25 08:22:58 RaspberryPi systemd[1]: Stopped openHAB 2 - empowering the smart home.
Nov 25 08:22:58 RaspberryPi systemd[1]: openhab2.service: Start request repeated too quickly.
Nov 25 08:22:58 RaspberryPi systemd[1]: Failed to start openHAB 2 - empowering the smart home.
I can not get openhab2 to start.
