2017-11-29_02:37:42_UTC [openHABian] Starting the openHABian initial setup.
2017-11-29_02:37:42_UTC [openHABian] Storing configuration… OK
2017-11-29_02:37:42_UTC [openHABian] Changing default username and password… OK
2017-11-29_02:37:42_UTC [openHABian] Setting up Wi-Fi connection… OK, rebooting…
2017-11-29_02:37:56_UTC [openHABian] Starting the openHABian initial setup.
2017-11-29_02:37:56_UTC [openHABian] Storing configuration… OK
2017-11-29_02:37:56_UTC [openHABian] Changing default username and password… SKIPPED
2017-11-29_02:37:56_UTC [openHABian] Setting up Wi-Fi connection… OK
2017-11-29_02:37:56_UTC [openHABian] Ensuring network connectivity… OK
2017-11-29_02:38:15_UTC [openHABian] Waiting for dpkg/apt to get ready… OK
2018-01-04_22:06:05_UTC [openHABian] Updating repositories and upgrading installed packages… FAILED
2018-01-04_22:09:13_UTC [openHABian] Initial setup exiting with an error!
2018-01-04_22:05:41_UTC [openHABian] Starting the openHABian initial setup.
2018-01-04_22:05:41_UTC [openHABian] Storing configuration… OK
2018-01-04_22:05:41_UTC [openHABian] Changing default username and password… SKIPPED
2018-01-04_22:05:41_UTC [openHABian] Setting up Wi-Fi connection… OK
2018-01-04_22:05:41_UTC [openHABian] Ensuring network connectivity… OK
2018-01-04_22:05:42_UTC [openHABian] Waiting for dpkg/apt to get ready… OK
2018-01-04_22:05:52_UTC [openHABian] Updating repositories and upgrading installed packages… FAILED
2018-01-04_22:23:37_UTC [openHABian] Initial setup exiting with an error!
2018-01-04_23:33:54_UTC [openHABian] Starting the openHABian initial setup.
2018-01-04_23:33:54_UTC [openHABian] Storing configuration… OK
2018-01-04_23:33:55_UTC [openHABian] Changing default username and password… SKIPPED
2018-01-04_23:33:55_UTC [openHABian] Setting up Wi-Fi connection… OK
2018-01-04_23:33:55_UTC [openHABian] Ensuring network connectivity… OK
2018-01-04_23:33:55_UTC [openHABian] Waiting for dpkg/apt to get ready… OK
2018-01-04_23:34:15_UTC [openHABian] Updating repositories and upgrading installed packages… FAILED
2018-01-09_14:46:38_UTC [openHABian] Initial setup exiting with an error!
