I am having trouble installing the latest OpenHabian image on a Raspberry Pi 3 Model B.
Watching an attached HDMI monitor, I get an Installation Failed message with a suggestion to look at first-boot.log. The contents of the log are:
2017-04-10_09:58:56_UTC [openHABian] Starting the openHABian initial setup. This might take a few minutes.
2017-04-10_09:58:56_UTC [openHABian] If you see this message more than once, something went wrong!
2017-04-10_09:58:56_UTC [openHABian] Storing configuration... OK
2017-04-10_09:58:56_UTC [openHABian] Changing default username and password... OK
2017-04-10_09:58:58_UTC [openHABian] Setting up Wifi connection... SKIPPED
2017-04-10_09:58:58_UTC [openHABian] Ensuring network connectivity... OK
2017-04-10_09:58:58_UTC [openHABian] Waiting for dpkg/apt to get ready... OK
2017-04-10_09:59:35_UTC [openHABian] Updating repositories and upgrading installed packages... OK
2017-04-10_10:32:48_UTC [openHABian] Installing git package... OK
2017-04-10_10:34:29_UTC [openHABian] Cloning myself... OK
2017-04-10_10:34:30_UTC [openHABian] Executing 'openhabian-setup.sh unattended'
2017-04-10_10:34:30_UTC [openHABian] Checking for root privileges... OK
2017-04-10_10:34:30_UTC [openHABian] Loading configuration file '/etc/openhabian.conf'... OK
2017-04-10_10:34:30_UTC [openHABian] Setting timezone based on IP geolocation... FAILED (pip)
2017-04-10_10:36:30_UTC [openHABian] Setting locale based on openhabian.conf... OK
2017-04-10_10:36:55_UTC [openHABian] Setting hostname of the base system... OK
2017-04-10_10:36:55_UTC [openHABian] Setting the GPU memory split down to 16MB for headless system... OK
2017-04-10_10:36:55_UTC [openHABian] Enabling Audio output... OK
2017-04-10_10:36:56_UTC [openHABian] Installing basic can't-be-wrong packages (screen, vim, ...)... OK
2017-04-10_10:45:45_UTC [openHABian] Installing additional needed packages... OK
2017-04-10_10:46:23_UTC [openHABian] Installing additional bluetooth packages... OK
2017-04-10_10:47:15_UTC [openHABian] Adding slightly tuned bash config files to system... OK
2017-04-10_10:47:15_UTC [openHABian] Adding slightly tuned vim config file to system... OK
2017-04-10_10:47:15_UTC [openHABian] Downloading and setting up FireMotD... OK
2017-04-10_10:48:35_UTC [openHABian] Installing etckeeper (git based /etc backup)... OK
2017-04-10_10:49:02_UTC [openHABian] Installing Zulu Embedded OpenJDK... OK
2017-04-10_10:52:56_UTC [openHABian] Installing openHAB 2.1 (stable)... FAILED (key)
2017-04-10_10:52:57_UTC [openHABian] Initial setup exiting with an error.
I haven’t been able to find and explanation of the “(key)” suffix to the FAILED line. I did try restarting the installation as suggested by the console text but it hung on a cleaning files line.
Suggestions?
Additional configuration information:
- The Raspberry Pi is connected to an Ethernet cable and WiFi is not being used.
- This Pi had an older version of OpenHab 2 running on it that I installed some time ago and never got properly configured.
- I used the latest version of Etcher on a Mac running 10.12 to burn the OpenHabian image onto the same 64GB SD card as the older version of OpenHAB had been running on.
