But isn’t your topic then wrong?
If the installation fails, topic should be about that.
Not that ssh fails. Because if the installation fails of course SSH will fail too.
@ThomDietrich The mind of openHABian summoned to this topic.
Hello @Dustan_Ali,
the error shouldn’t occur and I’m confident it wouldn’t appear again if you tried once more with a fresh image flash.
Anyhow I’m confused wether or not the installation failed in the end. As we can see in the log, your system restarted and was after that able to establish a network connection and update apt. What happened next?
