Same issue here, did you resolve?
I upgraded to 2.4.0 had minimal issues, ran an apt-get upgrade to latest OH 2.4 build (as of a couple days ago) and most things worked but still had the odd random runtime error in the logs, so decided to try clearing tmp and cache folders then restarting OH. After doing this, things went down hill fast.
Totally stumped now other than a complete wipe and rebuild (or restore)
2018-11-07 07:28:55.664 [INFO ] [control.internal.WebSocketConnection] - Web Socket close 1000. Reason: null
2018-11-07 07:28:59.701 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Started HABmin servlet at /habmin
2018-11-07 07:28:59.801 [ERROR] [org.eclipse.smarthome.io.rest.sse ] - FrameworkEvent ERROR - org.eclipse.smarthome.io.rest.sse
org.osgi.framework.BundleException: Exception in org.eclipse.smarthome.io.rest.sse.internal.SseActivator.start() of bundle org.eclipse.smarthome.io.rest.sse.
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:800) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:729) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:933) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:309) ~[?:?]
at org.eclipse.osgi.container.Module.doStart(Module.java:581) ~[?:?]
at org.eclipse.osgi.container.Module.start(Module.java:449) ~[?:?]
at org.eclipse.osgi.framework.util.SecureAction$23.run(SecureAction.java:474) ~[?:?]
at org.eclipse.osgi.framework.util.SecureAction$23.run(SecureAction.java:1) ~[?:?]
at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:472) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer.start(ModuleContainer.java:750) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer.applyDelta(ModuleContainer.java:741) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer.resolveAndApply(ModuleContainer.java:511) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer.resolve(ModuleContainer.java:457) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer.refresh(ModuleContainer.java:1001) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerWiring.dispatchEvent(ModuleContainer.java:1382) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerWiring.dispatchEvent(ModuleContainer.java:1) ~[?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340) [?:?]
Caused by: java.lang.LinkageError: ClassCastException: attempting to castbundleresource://31.fwk15675549/javax/ws/rs/ext/RuntimeDelegate.class to bundleresource://31.fwk15675549/javax/ws/rs/ext/RuntimeDelegate.class
at javax.ws.rs.ext.RuntimeDelegate.findDelegate(RuntimeDelegate.java:146) ~[?:?]
at javax.ws.rs.ext.RuntimeDelegate.getInstance(RuntimeDelegate.java:120) ~[?:?]
at javax.ws.rs.core.MediaType.valueOf(MediaType.java:179) ~[?:?]
at org.glassfish.jersey.media.sse.SseFeature.<clinit>(SseFeature.java:62) ~[?:?]
at org.eclipse.smarthome.io.rest.sse.internal.SseActivator.start(SseActivator.java:49) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:779) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:772) ~[?:?]
... 18 more
2018-11-07 07:29:13.842 [WARN ] [me.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.eclipse.smarthome.io.monitor.internal.EventLogger@152a60f' takes more than 5000ms.
2018-11-07 07:29:17.531 [INFO ] [lipse.smarthome.model.script.openhab] - SYSTEM STARTING UP!
2018-11-07 07:29:18.963 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-binding-exec, openhab-misc-openhabcloud, openhab-binding-network, openhab-persistence-influxdb, openhab-binding-wemo, openhab-binding-weather1, openhab-persistence-mysql, openhab-transformation-regex, openhab-binding-weatherunderground, openhab-transformation-jsonpath, openhab-binding-zwave, openhab-binding-mqtt1, openhab-binding-astro1, openhab-persistence-mqtt, openhab-persistence-rrd4j, openhab-ui-basic, openhab-transformation-map, openhab-binding-ntp, openhab-action-mail, openhab-ui-habmin, openhab-action-mqtt, openhab-transformation-exec, openhab-ui-paper, openhab-transformation-scale': Error restarting bundles:
I suspect it’s missing some framework file. Under the /var/lib/openhab2/cache/org.eclipse.osgi folder the latest framework file shown is framework.info.65 I usually see this slowly increment as OH downloads the necessary files, its like it is just stopped here and not downloading anymore, although folders above 65 do exist (assume it creates all folders first then populates them?)
EDIT: A number of bindings are showing as uninitialized too. Uninstalling those bindings from PaperUI or reinstalling the hour glass sits there indefinitely and it never appears (from a UI perspective) to complete. Refreshing the URL brings it back though. Doing this to the Astro 2.4 binding for example:
2018-11-07 08:16:51.715 [INFO ] [thome.binding.astro.internal.job.Job] - Scheduled Astro event-jobs for thing astro:sun:local
2018-11-07 08:16:51.823 [INFO ] [ding.astro.handler.AstroThingHandler] - Scheduled Positional job astro:sun:local every 300 seconds
2018-11-07 08:16:52.382 [INFO ] [thome.binding.astro.internal.job.Job] - Scheduled Astro event-jobs for thing astro:moon:local
2018-11-07 08:16:52.411 [INFO ] [thome.binding.astro.internal.job.Job] - Scheduled Astro event-jobs for thing astro:sun:local
2018-11-07 08:16:52.454 [INFO ] [ding.astro.handler.AstroThingHandler] - Scheduled Positional job astro:sun:local every 300 seconds
2018-11-07 08:16:56.291 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-binding-astro': Error restarting bundles:
