Installation of InfluxDB aborts via openhabian-config
after installation of openHab 3.4.1 package with openhabian on Raspberry pi4 the installation of the optional components InfluxDB an Grafana fails:
“Installing InfluxDB… FAILED”
Debug log contains following:
Err:3 https://repos.influxdata.com/debian bullseye InRelease
  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
Reading package lists... Done
W: GPG error: https://repos.influxdata.com/debian bullseye InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
E: The repository 'https://repos.influxdata.com/debian bullseye InRelease' is not signed.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
I’m not a linux expert (I’m dependent on openhabian-config) but it seems that the public key is not known.
Any idea to fix it?
Kind regards
Same here
Err:7 https://repos.influxdata.com/debian bullseye InRelease
Because of an alert ( see CircleCI security alert: Rotate any secrets stored in CircleCI (Updated Jan 13) ) keys were rotated/new ones were created.
To get the new keys onto your system you may follow instructions described at
Update: Linux Package Signing Key Rotation | InfluxData for influxdb and https://packages.grafana.com/oss/ for grafana.
Hi Wolfgang,
thanks for your hints, that sounds simple…
But:
InfluxDB instructions copy&paste via SSH, no errors
Grafana instructions copy&paste via SSH, error at the second command “persmission denied”
Nonetheless started the installation routine in openhabian-config, but I’ve got the same error again:
 There was an error or interruption during the execution of: "20 | Optional Components"
 $ influxdb_install admin [PASSWORD]
+ influxdb_install admin [PASSWORD]
+ local address=http://localhost:8086
+ local adminPassword=[PASSWORD]
+ local adminUsername=admin
+ local keyName=influxdb
+ local myOS
+ local myRelease
+ is_pi
+ is_pifour
+ [[ '' == \p\i\4 ]]
+ grep -q '^Revision\s*:\s*[ 123][0-9a-fA-F][0-9a-fA-F][0-9a-fA-F]11[0-9a-fA-F]$' /proc/cpuinfo
+ return 0
+ return 0
+ myOS=debian
++ lsb_release -sc
+ myRelease=bullseye
+ [[ bullseye == \n\/\a ]]
+ influxdb_is_installed
+ dpkg -s influxdb
+ return 1
+ add_keys https://repos.influxdata.com/influxdb.key influxdb
+ local repoKey=/usr/share/keyrings/influxdb.gpg
++ timestamp
++ printf '%(%F_%T_%Z)T\n' -1
+ echo -n '2023-02-11_16:50:36_CET [openHABian] Adding required keys to apt... '
2023-02-11_16:50:36_CET [openHABian] Adding required keys to apt... + curl -fsSL https://repos.influxdata.com/influxdb.key
+ gpg --dearmor
+ echo OK
OK
+ echo 'deb [signed-by=/usr/share/keyrings/influxdb.gpg] https://repos.influxdata.com/debian bullseye stable'
++ timestamp
+ echo -n '2023-02-11_16:50:36_CET [openHABian] Installing InfluxDB... '
2023-02-11_16:50:36_CET [openHABian] Installing InfluxDB... + cond_redirect apt-get update
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ apt-get update \033[39;49;00m'
$ apt-get update
+ apt-get update
Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
Hit:2 http://deb.debian.org/debian bullseye InRelease
Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
Hit:4 http://davesteele.github.io/comitup/repo comitup InRelease
Hit:5 https://repos.influxdata.com/debian stable InRelease
Get:6 https://repos.influxdata.com/debian bullseye InRelease [7,022 B]
Hit:7 https://deb.nodesource.com/node_16.x bullseye InRelease
Hit:8 http://archive.raspberrypi.org/debian bullseye InRelease
Hit:9 https://openhab.jfrog.io/artifactory/openhab-linuxpkg stable InRelease
Err:6 https://repos.influxdata.com/debian bullseye InRelease
+ return 100
+ echo 'FAILED (update apt lists)'
+ return 1
+ return 1
+ echo FAILED
FAILED
The problem with influxdb installation seems to be that openhabian checks if influxdb is already installed ( dpkg -s influxdb ). If it is not installed then the gpg key is installed/written again. In case the same name is used then it is overwritten.
With regard to grafana error in second command: do you refer to the following one ?
wget -q -O - https://apt.grafana.com/gpg.key | gpg --dearmor > /etc/apt/keyrings/grafana.gpg
I suggest to do
sudo bash
with provides you with a root shell. Then execute the commands in that shell. Ones finished do exit to return to previous user’s shell.
This is the case with openhabian-config openHAB3 branch. The openhabian-config main branch contains a fix for the changed gpg key.
“sudo bash” and no error for Grafana, thanks.
But if there will be no error at installation I will see after successful installation of InfluxDB.
When openhabian-config ist started, there is no choise between main branch and openHAB3 branch. Maybe I’m blind… :wink:
In openhabian-config I choose “20 | Optional Components” and " 24 | InfluxDB+Grafana".
How to get the openhabian-config main branch, please?
Extract from openHABian | openHAB :
You can switch branches using menu option 01 in openhabian-config but ATTENTION you cannot up- or downgrade this way and you cannot arbitrarily change versions. There’s a high risk you mess up your system if you do.
Menu then looks like:
( ) release  recommended version that supports openHAB 3.x (openHAB3 branch)
(*) latest   the latest of openHABian, not well tested (main branch)
( ) legacy   no longer updated, use for openHAB 2.x support (stable branch)
Yes, I was blind…
Entry 01 in openhabian-config changes the branches.
Sorry.
Switched to openhabian main branch, the setup of InfluxDB and grafana is successful!
Thanks a lot!
Hello.
I switch the branch to latest in openhabian-config. The InfluxDB has been installed, but grafana is not.
Here is the log:
Creating InfluxDB user grafana
+ cond_redirect curl --user admin:PASSWORD --insecure http://localhost:8086/query --data-u                         rlencode 'q=CREATE USER grafana WITH PASSWORD '\''PASSWORD'\'''
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ curl --user admin:PASSWORD --insecure http://localhost:8086/quer                         y --data-urlencode q=CREATE USER grafana WITH PASSWORD '\''PASSWORD'\'' \033[39;49;00m'
$ curl --user admin:PASSWORD --insecure http://localhost:8086/query --data-urlencode q=CRE                         ATE USER grafana WITH PASSWORD 'PASSWORD'
+ curl --user admin:PASSWORD --insecure http://localhost:8086/query --data-urlencode 'q=CR                         EATE USER grafana WITH PASSWORD '\''PASSWORD'\'''
{"results":[{"statement_id":0}]}
+ return 0
+ cond_redirect curl --user admin:PASSWORD --insecure http://localhost:8086/query --data-u                         rlencode 'q=SET PASSWORD FOR grafana = '\''PASSWORD'\'''
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ curl --user admin:PASSWORD --insecure http://localhost:8086/quer                         y --data-urlencode q=SET PASSWORD FOR grafana = '\''PASSWORD'\'' \033[39;49;00m'
$ curl --user admin:PASSWORD --insecure http://localhost:8086/query --data-urlencode q=SET                          PASSWORD FOR grafana = 'PASSWORD'
+ curl --user admin:PASSWORD --insecure http://localhost:8086/query --data-urlencode 'q=SET PASSWORD FOR grafana = '\''PASSWORD'\'''
+ return 0
+ cond_redirect curl --user admin:PASSWORD --insecure http://localhost:8086/query --data-u                         rlencode 'q=GRANT READ ON openhab TO grafana'
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ curl --user admin:PASSWORD --insecure http://localhost:8086/quer                         y --data-urlencode q=GRANT READ ON openhab TO grafana \033[39;49;00m'
$ curl --user admin:PASSWORD --insecure http://localhost:8086/query --data-urlencode q=GRA                         NT READ ON openhab TO grafana
+ curl --user admin:PASSWORD --insecure http://localhost:8086/query --data-urlencode 'q=GR               ANT READ ON openhab TO grafana'
+ return 0
+ echo OK
OK
++ timestamp
+ echo -n '2023-03-19_09:50:31_MSK [openHABian] Installing Grafana.. '
2023-03-19_09:50:31_MSK [openHABian] Installing Grafana.. + cond_redirect grafana_install
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ grafana_install PASSWORD \033[39;49;00m'
+ grafana_install PASSWORD
+ local adminPassword=PASSWORD
+ local keyName=grafana
+ grafana_is_installed
+ dpkg -s grafana
+ return 1
+ add_keys https://packages.grafana.com/gpg.key grafana
+ local repoKey=/usr/share/keyrings/grafana.gpg
++ timestamp
+ echo -n '2023-03-19_09:50:31_MSK [openHABian] Adding required keys to apt... '
2023-03-19_09:50:31_MSK [openHABian] Adding required keys to apt... + curl -fsSL https://packages.gr                         afana.com/gpg.key
+ gpg --dearmor
curl: (22) The requested URL returned error: 403
gpg: no valid OpenPGP data found.
+ echo FAILED
FAILED
+ rm -f /usr/share/keyrings/grafana.gpg
+ return 1
+ return 1
+ return 1
+ echo FAILED
FAILED
+ return 1
+ '[' 1 -ne 0 ']'
The link to grafana site from the message number 2 is not working any more (“Sorry, the provided token is not valid”).
I`m not a Linux user. What should I do? Please help me to install grafana.
That’s strange I would say.
Accessing https://packages.grafana.com/gpg.key using a browser as well as using the curl command that is being used by openhabian-config both work.
I would suggest to try it again.
If that fails again try:
sudo bash
curl -fsSL https://packages.grafana.com/gpg.key | gpg --dearmor > /usr/share/keyrings/grafana.gpg
Although I would expect this then also to fail again as it is the same command that is used in openhabian-config.
You then also require to execute following command in the same root shell:
echo "deb [signed-by=/usr/share/keyrings/grafana.gpg] https://packages.grafana.com/oss/deb stable main" > /etc/apt/sources.list.d/grafana.list
That’s the problem: Grafana Labs’ enterprise binaries are subject to export regulations and are not made available in Russia.
