Hi Wolfgang,
thanks for your hints, that sounds simple…
But:
InfluxDB instructions copy&paste via SSH, no errors
Grafana instructions copy&paste via SSH, error at the second command “persmission denied”
Nonetheless started the installation routine in openhabian-config, but I’ve got the same error again:
There was an error or interruption during the execution of: "20 | Optional Components"
$ influxdb_install admin [PASSWORD]
+ influxdb_install admin [PASSWORD]
+ local address=http://localhost:8086
+ local adminPassword=[PASSWORD]
+ local adminUsername=admin
+ local keyName=influxdb
+ local myOS
+ local myRelease
+ is_pi
+ is_pifour
+ [[ '' == \p\i\4 ]]
+ grep -q '^Revision\s*:\s*[ 123][0-9a-fA-F][0-9a-fA-F][0-9a-fA-F]11[0-9a-fA-F]$' /proc/cpuinfo
+ return 0
+ return 0
+ myOS=debian
++ lsb_release -sc
+ myRelease=bullseye
+ [[ bullseye == \n\/\a ]]
+ influxdb_is_installed
+ dpkg -s influxdb
+ return 1
+ add_keys https://repos.influxdata.com/influxdb.key influxdb
+ local repoKey=/usr/share/keyrings/influxdb.gpg
++ timestamp
++ printf '%(%F_%T_%Z)T\n' -1
+ echo -n '2023-02-11_16:50:36_CET [openHABian] Adding required keys to apt... '
2023-02-11_16:50:36_CET [openHABian] Adding required keys to apt... + curl -fsSL https://repos.influxdata.com/influxdb.key
+ gpg --dearmor
+ echo OK
OK
+ echo 'deb [signed-by=/usr/share/keyrings/influxdb.gpg] https://repos.influxdata.com/debian bullseye stable'
++ timestamp
+ echo -n '2023-02-11_16:50:36_CET [openHABian] Installing InfluxDB... '
2023-02-11_16:50:36_CET [openHABian] Installing InfluxDB... + cond_redirect apt-get update
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ apt-get update \033[39;49;00m'
$ apt-get update
+ apt-get update
Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
Hit:2 http://deb.debian.org/debian bullseye InRelease
Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
Hit:4 http://davesteele.github.io/comitup/repo comitup InRelease
Hit:5 https://repos.influxdata.com/debian stable InRelease
Get:6 https://repos.influxdata.com/debian bullseye InRelease [7,022 B]
Hit:7 https://deb.nodesource.com/node_16.x bullseye InRelease
Hit:8 http://archive.raspberrypi.org/debian bullseye InRelease
Hit:9 https://openhab.jfrog.io/artifactory/openhab-linuxpkg stable InRelease
Err:6 https://repos.influxdata.com/debian bullseye InRelease
The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
Reading package lists... Done
W: GPG error: https://repos.influxdata.com/debian bullseye InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
E: The repository 'https://repos.influxdata.com/debian bullseye InRelease' is not signed.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
+ return 100
+ echo 'FAILED (update apt lists)'
+ return 1
+ return 1
+ echo FAILED
FAILED
