because I’m used to openHAB 3 I’m trying to get this version installed on a Rapsberry Pi 4.
I’m using the image for 32 Bit found here (1st link):
I’ve changed the config.txt to disable audio and some other things.
Also I’ve changed openhabian.conf:
username and password and most important: clonebranch=openhab3
After the initial boot and some waiting I see the following:
I need to use the default user name, the one from config.txt is not valid
audio etc. is not disabled
openHAB 4 is running
It seems that all the settings made in the respective configuration files are ignored. What have I missed? How can I install the latest openHABian with openHAB 3 on my Raspberry Pi?
Thanks for your reply. But I still don’t get it.
Using the configuration tool openhabian-config I can change some system settings and choose the branch of openHAB (e.g. release). But I don’t find where to choose openHAB 3.
I could not find official documentation about this but maybe I didn’t use the right search words and I missed it.
