Platform information:
Hardware: amd64, 4GB RAM
OS: Bullseye (Debian 11)
Java Runtime Environment: OpenJDK Runtime Enviroment (build 17.0.9)
openHAB version: oenHAB 3.4.2
Issue of the topic:
I would like to upgrade my operating system to Debian 11 (Bullseye). To transfer my existing openHAB installation (V3.4.2) with cli backup, I first need to install version 3.4.2 on Bullseye (Best way to upgrade to bullseye for openhabian). The procedure is described in the following instructions: Linux - Debian - Stable 3.4.4
However, since the current stable version (“stable main”) is downloaded in step 4 (“Add the repository”), I have to adjust the link so as not to download openHAB 4.
echo 'deb [signed-by=/usr/share/keyrings/openhab.gpg] https://openhab.jfrog.io/artifactory/openhab-linuxpkg stable main' | sudo tee /etc/apt/sources.list.d/openhab.list
The version I want is here: Index of openhab-linuxpkg/pool/main/3.4.2
Can someone explain how to install this version for a Linux beginner? (Is there a way to customise the link or is this procedure wrong?)
Many thanks in advance!
