- Platform information:
- Hardware: RaspberryPi5
- OS: openHABian
- Java Runtime Environment: ?
- openHAB version: v1.9c - the one that raspberry pi imager 1.8.5 pulls (latest)
- Issue of the topic: The installation stops at
Installing openHAB Log Viewer (frontail)...
when installing. Nothing happens even after waiting for hours. I’ve tried both 32bit and 64bit version following these instructions on openHAB Installation Guide - Please post configurations (if applicable):
- Items configuration related to the issue
- Sitemap configuration related to the issue
- Rules code related to the issue
- Services configuration related to the issue
- If logs where generated please post these here using code fences:
2024-03-15_15:09:13_UTC [openHABian] Storing configuration... OK
2024-03-15_15:09:13_UTC [openHABian] Starting webserver with installation log... OK
2024-03-15_15:09:18_UTC [openHABian] Changing default username and password... SKIPPED
2024-03-15_15:09:18_UTC [openHABian] Setting up NetworkManager and Wi-Fi connection... 2024-04-09_00:00:00_UTC [openHABian] Ensuring network connectivity... OK
2024-04-09_00:00:00_UTC [openHABian] Waiting for dpkg/apt to get ready... OK
2024-04-09_00:00:05_UTC [openHABian] Updating repositories and upgrading installed packages... OK
2024-04-09_00:00:19_UTC [openHABian] Updating myself from https://github.com/openhab/openhabian, openHAB branch... OK
2024-04-09_00:00:23_UTC [openHABian] Starting execution of 'openhabian-config unattended'... OK
2024-04-09_00:00:23_UTC [openHABian] Checking for root privileges... OK
2024-04-09_00:00:23_UTC [openHABian] Updating Linux package information... OK
2024-04-09_00:00:26_UTC [openHABian] Loading configuration file '/etc/openhabian.conf'... OK
2024-04-09_00:00:26_UTC [openHABian] Adjusting swap size to 16104 MB... OK (reboot required)
2024-04-09_00:00:26_UTC [openHABian] Setting timezone based on openhabian.conf... OK (Europe/London)
2024-04-09_02:00:26_CEST [openHABian] Setting locale based on openhabian.conf... OK (reboot required)
2024-04-09_02:00:33_CEST [openHABian] Setting hostname of the base system based on openhabian.conf... OK
2024-04-09_02:00:33_CEST [openHABian] Setting the GPU memory split down to 16MB for headless system... OK
2024-04-09_02:00:33_CEST [openHABian] Enabling Audio output... OK
2024-04-09_02:00:33_CEST [openHABian] Installing basic can't-be-wrong packages (screen, vim, ...)... OK
2024-04-09_02:01:56_CEST [openHABian] Installing additional needed packages... OK
2024-04-09_02:02:31_CEST [openHABian] Installing additional Python packages... 2024-04-09_02:02:31_CEST [openHABian] Installing python3 serial package... OK
2024-04-09_02:02:52_CEST [openHABian] Installing pigpio package... OK
2024-04-09_02:03:00_CEST [openHABian] Installing additional bluetooth packages... OK
2024-04-09_02:03:37_CEST [openHABian] Adding slightly tuned bash configuration files to system... OK
2024-04-09_02:03:37_CEST [openHABian] Adding slightly tuned vim configuration file to system... OK
2024-04-09_02:03:37_CEST [openHABian] tailscale VPN installation... SKIPPED (no preauthkey defined)
2024-04-09_02:03:37_CEST [openHABian] Applying miscellaneous system settings... OK
2024-04-09_02:03:37_CEST [openHABian] Downloading FireMotD... OK
2024-04-09_02:03:39_CEST [openHABian] Installing FireMotD... OK
2024-04-09_02:03:39_CEST [openHABian] Generating FireMotD theme... OK
2024-04-09_02:04:00_CEST [openHABian] Setting up FireMotD apt updates count service... OK
2024-04-09_02:04:17_CEST [openHABian] Fetching OpenJDK 17... OK
2024-04-09_02:04:24_CEST [openHABian] Installing OpenJDK 17... OK
2024-04-09_02:05:06_CEST [openHABian] Beginning install of latest openhab release (stable repo)... OK
2024-04-09_02:05:06_CEST [openHABian] Adding required keys to apt... OK
2024-04-09_02:05:07_CEST [openHABian] Installing selected openHAB version... OK
2024-04-09_02:07:21_CEST [openHABian] Setting up openHAB service... OK
2024-04-09_02:07:22_CEST [openHABian] Optimizing openHAB to run on low memory single board computers... OK
2024-04-09_02:07:22_CEST [openHABian] Setting openHAB HTTP/HTTPS ports... OK
2024-04-09_02:07:22_CEST [openHABian] Creating dependencies to jointly start services that depend on each other... OK
2024-04-09_02:07:22_CEST [openHABian] Adding an openHAB dashboard tile for 'openhabiandocs'... OK
2024-04-09_02:07:22_CEST [openHABian] Restarting openHAB service to play it safe... OK
2024-04-09_02:07:22_CEST [openHABian] Getting initial openHAB configuration... SKIPPED (backup not found at /boot/initial.zip)
2024-04-09_02:07:22_CEST [openHABian] Activating the openHAB console on all interfaces... OK
2024-04-09_02:07:22_CEST [openHABian] Installing tailscale VPN... SKIPPED (no pre auth key provided)
2024-04-09_02:07:22_CEST [openHABian] Adding openHAB syntax to vim editor... OK
2024-04-09_02:07:28_CEST [openHABian] Adding openHAB syntax to nano editor... OK
2024-04-09_02:07:29_CEST [openHABian] Adding openHAB scheme to multitail... OK
2024-04-09_02:07:29_CEST [openHABian] Preparing openHAB folder mounts under '/srv/openhab-*'... OK
2024-04-09_02:07:37_CEST [openHABian] Installing Samba... OK
2024-04-09_02:08:56_CEST [openHABian] Setting up Samba network shares... OK
2024-04-09_02:08:56_CEST [openHABian] Setting up Samba service... OK
2024-04-09_02:08:58_CEST [openHABian] Installing openHAB Log Viewer (frontail)...
log stops there (these are when I ssh into using MacOS Terminal.
Here is a screenshot when I access localhost:
Any help would be appreciated.
thanks,
