- Platform information:
- Hardware: Raspberry Pi
- OS: Linux version 4.19.83-v7+
- Java Runtime Environment: openjdk version “1.8.0_152”
- openHAB version:
openHAB Distribution Version Information
build-no : Release Build
online-repo : https://dl.bintray.com/openhab/mvn/online-repo/2.5
Repository Version
openhab-distro : 2.5.0
openhab-core : 2.5.0
openhab1-addons : 1.14.0
openhab2-addons : 2.5.0
karaf : 4.2.7
Short stroy:
I have troubles installing the network binding:
It doesn’t show up under Paper UI -> Add-Ons -> Bindings
It isn’t installed Paper UI -> Configuration -> Bindings
I don’t find a jar at https://github.com/openhab/openhab2-addons/tree/2.5.x/bundles/org.openhab.binding.network to manually place in add-ons folder /usr/share/openhab2/addons/
Long story:
In my home/network I have a smart TV from philips. It’s going to deep sleep. In deepsleep, it can’t be powered on using the philipstv binding. I need wake-on-lan before. Binding installed and works fine, if the TV is on:
org.openhab.binding.philipstv-2.5.0-SNAPSHOT.jar
First task in the rule is to check if the TV is in deep-sleep.
I can do it with ping and iputils-arping from command line. I also can do it in a rule, example
executeCommandLine(“ping -c 1 192.168.178.39”, 60000)
But then I would need to write some code to parse the result. So I prefer to use the network binding - see “short story”.
Based on this result, I can execute the wake-on-lan:
sudo etherwake 44:D8:78:BD:xx:xx
This works with the TV via WLAN and settings Wake-On-WLAN.
Regards, Felix
