Installing custom Bindings (OH3)?
I hadn’t touched my OH for about a year so I decided to use the upgrade to OH3 as a reason to port back over to a RPI from my PC.
How do I go about installing custom bindings var .jar files? In this case I’m trying to install a MyQ binding. I tried downloading it into the usr/share/openhab/addons folder but it doesn’t seem to show up on my the binding list after restarting OH service.
Thank you!
  • Platform information:
    • Hardware: CPUArchitecture/RAM/storage
    • OS: what OS is used and which version
    • Java Runtime Environment: which java platform is used and what version
    • openHAB version:
  • Issue of the topic: please be detailed explaining your issue
    • Items configuration related to the issue
    • Sitemap configuration related to the issue
    • Rules code related to the issue
    • Services configuration related to the issue
  • If logs where generated please post these here using code fences:
That is where you install addon OpenHAB 3 bindings. OpenHAB 2 ones will not work.
The specific binding is for OH3
https://github.com/digitaldan/openhab-addons/releases/download/myq-wip-1/org.openhab.binding.myq-3.0.0-SNAPSHOT.jar
Manually installed bindings never show up in the installed list in the UI.
Did you try manually adding a Thing? The binding should appear there as an option.
