Did that and it work! Great!
I think I need to fork the thing in GitHub to create pull requests, right?
Don’t know if that is the way you would go about it, I have never created a pull request on GitHub.
Unless you wanna talk me through that, you are probably better served to handle it yourself.
Thank you!
Yes! Fork openhab/openhab, and follow these instructions to get a full IDE setup. Then create a branch for your fix, commit your change on it, push it to origin, and go back to github to submit your branch as a pull request. I am happy to do it if it’s not high on your list.
It worked with my LGTV.
Copied the lgtv addon file (org.openhab.binding.lgtv-1.8.3.jar) into 2.0 addon directory. Created lgtv.cfg file with binding parameters under conf/services. It gave me javax.servlet error initially. Removed the below line from the MANIFEST.MF file inside the jar file as suggested. The error is gone and started working.
@watou I am very new this with little technical knowledge, not comfortable yet to work on eclipse to include this in the feature.
