Installing openhab 3 unstable Release | repository does not have a Release file
hi fellow openhab users,
Error message
E: The repository 'https://openhab.jfrog.io/openhab/openhab-linuxpkg unstable Release' does not have a Release file.
I am trying to install a snapshot version of OH3.
I have a new raspberrie pi 4 with PI OS
I’m not that adept at working with repository
According to this page openHAB on Linux | openHAB
I have to do this:
echo ‘deb JFrog unstable main’ | sudo tee /etc/apt/sources.list.d/openhab2.list
When I do sudo apt-get update I get :
Hit:1 http://archive.raspberrypi.org/debian buster InRelease
Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
Ign:3 https://openhab.jfrog.io/openhab/openhab-linuxpkg unstable InRelease
Err:4 https://openhab.jfrog.io/openhab/openhab-linuxpkg unstable Release
  Unknown date format Bad header data [IP: 35.231.52.82 443]
Reading package lists... Done
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
what is wrong or what am I doing wrong?
Hi @micware, you’re not doing anything wrong. This is a bug with our repository which we are currently waiting on a fix. This issue comes and goes and I haven’t figured out a pattern to when it starts or stops yet.
Did you come from: Guide: Installing and testing OH3 snapshots/milestones using APT and YUM ?
If so, there’s a section in that same post for a workaround on the issue you’re experiencing:
wget https://openhab.jfrog.io/openhab/list/openhab-linuxpkg/pool/main/3.0.0~S1926/openhab_3.0.0~S1926-1_all.deb
sudo apt install ./openhab_3.0.0~S1926-1_all.deb
where S1926 should be the latest build inside this folder. (1926 is the latest at the time of writing this post).
Hi Ben,
Thank you for your comment!
Good to know it’s not my fault for once :slight_smile:
I did come from: Guide: Installing and testing OH3 snapshots using APT and YUM
i’m going to study the link you provided.
Thank you for this information
and I hope we have a bright future with Openhab 3
gr, Michiel
i have the same error but i am able to install snapshots correctly.
Note that the required repository is unstable main unstable main
echo ‘deb https://openhab.jfrog.io/openhab/openhab-linuxpkg unstable main
The error is for unstable release
`E: The repository 'https://openhab.jfrog.io/openhab/openhab-linuxpkg unstable Release' does not have a Release file.`
browse over to JFrog to see that this has artifacts
Hi candiesdoodle,
I have successfully installed openhab 3 with the url that Ben gave me.
Thx for your input /respons
Due to the fact that i am updating oh3 i got the following error.
openhab (3.0.0~S1926-1) wird eingerichtet ...
[openHAB] Performing post-update tasks for version 3.0.0:
  Replacing: String org.eclipse.smarthome.i18n to org.openhab.i18n in file /var/lib/openhab/config/org/openhab/i18n.config
  Replacing: String org.eclipse.smarthome.persistence to org.openhab.persistence in file /var/lib/openhab/config/org/openhab/persistence.config
  Replacing: String org.eclipse.smarthome.audio to org.openhab.audio in file /var/lib/openhab/config/org/openhab/audio.config
  Replacing: String org.eclipse.smarthome.inbox to org.openhab.inbox in file /var/lib/openhab/config/org/openhab/inbox.config
  Replacing: String org.eclipse.smarthome.folder to org.openhab.folder in file /var/lib/openhab/config/org/openhab/folder.config
  Replacing: String org.eclipse.smarthome.threadpool to org.openhab.threadpool in file /var/lib/openhab/config/org/openhab/threadpool.config
  Replacing: String org.eclipse.smarthome.autoupdate to org.openhab.autoupdate in file /var/lib/openhab/config/org/openhab/autoupdate.config
  Replacing: String org.eclipse.smarthome.lsp to org.openhab.lsp in file /var/lib/openhab/config/org/openhab/lsp.config
  Replacing: String org.eclipse.smarthome.rulehli to org.openhab.rulehli in file /var/lib/openhab/config/org/openhab/rulehli.config
  Replacing: String org.eclipse.smarthome.storage.json to org.openhab.storage.json in file /var/lib/openhab/config/org/openhab/storage/json.config
  Replacing: String org.eclipse.smarthome.storage.mapdb to org.openhab.storage.mapdb in file /var/lib/openhab/config/org/openhab/storage/json.config
  Replacing: String org.eclipse.smarthome.core to org.openhab.core in file /var/lib/openhab/jsondb/org.openhab.core.config.discovery.DiscoveryResult.json
  Replacing: String org.eclipse.smarthome to org.openhab.core in file /var/lib/openhab/jsondb/org.openhab.core.config.discovery.DiscoveryResult.json
  Replacing: String org.eclipse.smarthome.core to org.openhab.core in file /var/lib/openhab/jsondb/org.openhab.core.items.Item.json
  Replacing: String org.eclipse.smarthome to org.openhab.core in file /var/lib/openhab/jsondb/org.openhab.core.items.Item.json
  Replacing: String org.eclipse.smarthome.core to org.openhab.core in file /var/lib/openhab/jsondb/org.openhab.core.thing.link.ItemChannelLink.json
  Replacing: String org.eclipse.smarthome to org.openhab.core in file /var/lib/openhab/jsondb/org.openhab.core.thing.link.ItemChannelLink.json
  Replacing: String org.eclipse.smarthome.core to org.openhab.core in file /var/lib/openhab/jsondb/org.openhab.core.thing.Thing.json
  Replacing: String org.eclipse.smarthome to org.openhab.core in file /var/lib/openhab/jsondb/org.openhab.core.thing.Thing.json
dpkg: Fehler beim Bearbeiten des Paketes openhab (--configure):
 »installiertes openhab-Skript des Paketes post-installation«-Unterprozess gab den Fehlerwert 1 zurück
Trigger für systemd (241-7~deb10u4) werden verarbeitet ...
Fehler traten auf beim Bearbeiten von:
 openhab
E: Sub-process /usr/bin/dpkg returned an error code (1)
This is a separate issue to the one described in this thread. It looks like you’re on a standard Debian buster build right? I can’t replicate your problem on my virtual machine with that OS.
Hoi Thomas,
This is a totally different problem than what I had.
And not to confuse things even further in this post, it seems useful to make a separate post for this problem
and I think more info is needed for someone to help you any further.
if read it correct you are updating from an older version of openhab to a snapshot version (of openhab 3 which is not stable / producite ready at all.)
so version number of OS and current OH 2.x.x can be important to mention.
Perhaps not everything has been programmed yet for your starting situation (it’s not called “not stable” for nothing)
So make a new post in the hope someone can help you further
Since the Guide: Installing and testing OH3 snapshots using APT and YUM topic’s first post is updated with latest information. I’m happy that conversations and bug reports about the packaging happen there too, as I’ll try to fix any issue that arises quickly (and I track that thread already).
