After using openhab since a few weeks I wanted to install the cloud extension.
Clicking install on the misc->openhab cloud connector shows me the “wait-state” symbol and then nothing more. After refreshing the browser the Extension is shown as installed. But there is no uuid / secret added on the file system. Opening the openhab.log shows:
2023-02-08 19:47:36.687 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-misc-openhabcloud': Keine Berechtigung
Could you support me? Where do openhab needs more rights and how can I provide it?
I´m a linux newbie
Do the permisions of these directories match ( first row is the command to be executed on your OH host; second and following lines are returned by the command ) ?
ls -ld /var/lib/openhab/uuid /var/lib/openhab/openhabcloud/ /var/lib/openhab/openhabcloud/secret
drwxr-xr-x 2 openhab openhab 4096 Oct 22 2021 /var/lib/openhab/openhabcloud/
-rw-r--r-- 1 openhab openhab 20 Oct 22 2021 /var/lib/openhab/openhabcloud/secret
-rw-r--r-- 1 openhab openhab 36 Oct 22 2021 /var/lib/openhab/uuid
First column shows the permissions; openhab is the user and openhab is the group the directories resp. files belong to.
Thanks for your reply… But these folders/files are not created. Even if the installation is shown as “installed” after browser refresh. So I think there is a problem by creating these folders / files during the installation and finally its a crashed installation.
But here is the output of that line:
server@server-TERRA-PC:~$ ls -ld /var/lib/openhab/uuid /var/lib/openhab/openhab cloud/ /var/lib/openhab/openhabcloud/secret
ls: Zugriff auf '/var/lib/openhab/uuid' nicht möglich: Datei oder Verzeichnis ni cht gefunden
ls: Zugriff auf '/var/lib/openhab/openhabcloud/' nicht möglich: Datei oder Verze ichnis nicht gefunden
ls: Zugriff auf '/var/lib/openhab/openhabcloud/secret' nicht möglich: Datei oder Verzeichnis nicht gefunden
These permissions should be ok although my directory also has w permissions for the goup.
Just to double check: the java process runs with user openhab permissions ?
How is the permission looking at /etc/openhab ??
Here it could be that I´ve changed something in the past because I wanted to share these both directories via samba to maybe edit scripts with visual studio code. But I never did since now and read it´s more for openhab 2.
In etc/openhab I can edit files via samba (Windows Client). In var/lib/openhab I can´t. I am logged in via windows client as user server. So it seems to be logic, right?
server@server-TERRA-PC:~$ ls -ld /etc/openhab
drwxr-xr-x 14 server server 4096 Feb 9 08:49 /etc/openhab
drwxr-xr-x 11 openhab openhab 4096 Dez 15 20:43 /var/lib/openhab/
So does normaly has openhab the rights for /etc/openhab or a standard user on the linux (in my case “server”) ?
If yes how can I go back or add openhab again as a owner / user to this directory?
Thanks a lot…
BTW: In the log there is nothing more Wolfgang… Just this one line “no permission and failed”
I changed this directoy to user and group openhab:
drwxr-xr-x 14 openhab openhab 4096 Feb 9 08:49 /etc/openhab
But trying to install the add on still leaves a comment with “no permission” in the log:
2023-02-09 10:40:36.305 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-misc-openhabcloud': Keine Berechtigung
Any other ideas?
EDIT: YES! It works
I noticed I only changed ONE directory and not the subfolders…
So you have to write chown -R for rekursiv to change the subfolders in the same time.
Now plugin is gettin installed… I will now try to use it.
