Installing / running the Zwave snapshot addon
Hi all,
I’m trying to get the Zwave-snapshot addon to work.
Openhab version running: openHAB 4.0.3
Steps taken:
  • Removed Zwave binding through the UI
  • Stopped Openhab
  • Cleared cached
  • Downloaded the Zwave - snapshot JAR file
  • copied the JAR to the /usr/share/openhab/addons directory
  • checked file owner and permissions (ok)
  • Start Openhab again
Result is HANDLER_MISSING_ERROR on the Zwave things.
I’m missing steps I guess, but not sure which one(s)…
Can someone point me in the right direction?
Thanks in advance!
/Jasper
feature:install openhab-transport-serial
In karaf?
Did that, and the bundle:list gives me:
Blockquote
324 │ Installed │ 80 │ 4.1.0.202309250348 │ openHAB Add-ons :: Bundles :: ZWave Binding
So it shows the zwave addon, but it’s not active.
When I try bundle:start 324 it give me:
Error executing command: Error executing command on bundles: Error starting bundle 324: Could not resolve module: org.openhab.binding.zwave [324] Unresolved requirement: Import-Package: javax.measure; version="[2.2.0,3.0.0)"
I’m not familiar with that one. Try a search of the forum?
Still going through the posts… but thanks for assisting!
I did a quick check myself. You might need to try M1, but not sure. Also I always add order:latest for more recent posts
Apparently, the “stable” version is not working together with the latest Zwave-binding snapshot.
The solution was to change to the “Testing release” repo:
  • apt-get update
  • apt-get upgrade
Which upgraded the OH version to 4.1.0 M1
after which the Zwave-binding Snapshot binding was accepted. All seems up and running again now…
Thank you again!
