- Platform information:
- Hardware: MacMini Intel Solo i386 2 Gb RAM
- OS: Ubuntu 16.04.5 LTS (GNU/Linux 4.4.0-138-generic i686)
- Java Runtime Environment: java version “1.8.0_191”
Java™ SE Runtime Environment (build 1.8.0_191-b12)
Java HotSpot™ Client VM (build 25.191-b12, mixed mode) - openHAB version: 2.3.0 stable
- Issue of the topic: I am trying to install telldus-core and telldusd using Openhabian-config but the installation fails with the following error messages:
Fetched 6199 B in 1s (4535 B/s)
Reading package lists... Done
N: Skipping acquire of configured file 'main/binary-i386/Packages' as repository 'https://s3.eu-central-1.amazonaws.com/download.telldus.com unstable InRelease' doesn't support architecture 'i386'
E: The value 'xenial' is invalid for APT::Default-Release as such a release is not available in the sources
$ apt -y install libjna-java telldus-core
FAILED
2018-11-01_12:01:59_CET [openHABian] Setting up systemd service for telldusd...
$ cp /opt/openhabian/includes/tellstick-core/telldusd.service /lib/systemd/system/telldusd.service
cp: cannot stat '/opt/openhabian/includes/tellstick-core/telldusd.service': No such file or directory
$ systemctl daemon-reload
$ systemctl enable telldusd
Failed to execute operation: No such file or directory
$ systemctl start telldusd.service
Failed to start telldusd.service: Unit telldusd.service not found.
FAILED
Help appreciated. In my installation Tellstick switches and Tellstick DUO and Tellstick Live are essential components.
