I’m trying to get my system able to compile bindings again, and have decided to reinstall the development system.
I note that in the instructions, it states to install using a repo that is not part of the OH framework, but is from @maggu2810 - is this really correct?
I know things are very fluid at the moment with these changes, but I’d really like to get a working system . Are these instructions still valid, and if so, any thoughts as to what is wrong would be appreciated.
Thanks David - it might pay to add this to the build instructions .
However, it didn’t completely resolve all the dependancies. I still have a lot of the annotations (eg the OSGi Component/Reference annotations), and org.apache.commons - maybe others as well as I’ve not looked through everything yet. This is just with the single astro binding installed as per the instructions…
Chris : it’s strange the guide does not work for you: it has been tested several times starting from a clean situation (clean local maven repo and no previous eclipse install)
try solve dependencies with this step:
From the openhab2-addons directory run: mvn -DskipChecks -DskipTests clean install to rebuild the list of bindings in the BOM (Bill Of Material) and make your new binding visible from the demo.app project
Hope it helps.
Btw I just pushed a PR for a new guide version that does not use Maggu demo app but the openHAB distro instead. You might try to start from that one.
I have also removed maggus demo app instructions from the openhab2-addons readme.
Although our current approach is not optimal in terms of build time, at least it somehow works.
List of things to solve:
Add binding and other archetypes to the Eclipse oomph setup. That way you could simple click on “New project -> From Archetype” in Eclipse to create a new addon.
Use one approach for VScode and Eclipse: At the moment the distro app doesn’t seem to use Karaf, while the VScode approach does.
Note that the mention about running mvn clean is not in the main install section - it is only in a section further down about writing a new binding which I didn’t get to as from the instructions it should have compiled earlier with existing bindings (as I understand it). I think adding the fact that you must run maven is a kind of important step as it simply doesn’t work without this and following the instructions at the moment does not do this.
