calevans
(Cal Evans)
February 26, 2019, 4:26am
1
Greetings!
I am running OH 2.4.0-1
I have - I believe - updated my z-wave binding to the 2.5.0-SNAPSHOT manually
I had originally installed it via PaperUI. I uninstalled it via Paper UI
I downloaded the jar fole
I placed it in addons
I open openhab-cli console
When I do a bundle:list I see:
272 │ Active │ 80 │ 2.5.0.201902252032 │ ZWave Binding
However, in PaperUI, it doesn’t show as installed.
Everything seems to be working just fine.
Should PaperUI only show the bindings it installed?
Is there a way to make PaperUI show that ZWave is installed and the proper version number?
Cheers!
=C=
sihui
(SiHui)
February 26, 2019, 7:47am
2
Manually added bindings are not showing up in PaperUI.
Nope. But you already found the solution: the console and bundle:list
calevans
(Cal Evans)
February 27, 2019, 4:02am
4
Followup question if I may. Is there a unified web interface that gives you everything known about an openHab instance? All bundles installed regardless of how, etc.
Cheers!
=C=
sihui
(SiHui)
February 27, 2019, 6:36am
5
Unfortunately not (yet). Maybe in openHAB3:
Hello community,
in this post I’m going to introduce a functional* design study for a next generation Paper UI.
I tried to consider all remarks and objections that we as a community discussed in https://community.openhab.org/t/next-generation-design-ideas-discussions/62575 .
*functional: You will see demo/example data only, not coming from a real OH instance. Most of the lists and pages are already dynamically populated, some are not.
Important: This is a design study and not set in stone. Yo…
