Hey guys,
currently I’m facing the problem that my binding is not passing the following if-statement
if (handler instanceof AbstractBrokerHandler) {...}
I checked the type via debugger and the type of the handler
object is indeed BrokerHandler
(inherits from AbstractBrokerHandler
). I also imported the correct type like the following: import org.openhab.binding.mqtt.handler.AbstractBrokerHandler;
Do you have any ideas why this is the case?
Greetings
