Hi all,
I have configured openHAB 1.7.1 on my raspberry pi, and have a few insteon devices installed in my home. I recently acquired the thermostat (2441TH) and configured it thanks to pfrommer’s guide and Insteon Terminal. Everything has connected O.K.
The problem I now have is when openHAB starts. I configured my .items file per the binding wiki, replacing the I.D with my thermostat:
Number thermostatCoolPoint "cool point [%.1f °F]" { insteonplm="32.f4.22:F00.00.18#coolsetpoint" }
Number thermostatHeatPoint "heat point [%.1f °F]" { insteonplm="32.f4.22:F00.00.18#heatsetpoint" }
Number thermostatSystemMode "system mode [%d]" { insteonplm="32.f4.22:F00.00.18#systemmode" }
Number thermostatFanMode "fan mode [%d]" { insteonplm="32.f4.22:F00.00.18#fanmode" }
Number thermostatIsHeating "is heating [%d]" { insteonplm="32.f4.22:F00.00.18#isheating"}
Number thermostatIsCooling "is cooling [%d]" { insteonplm="32.f4.22:F00.00.18#iscooling"}
Number thermostatTempFahren "temperature [%.1f °F]" { insteonplm="32.f4.22:F00.00.18#tempfahrenheit" }
Number thermostatTempCelsius "temperature [%.1f °C]" { insteonplm="32.f4.22:F00.00.18#tempcelsius" }
Number thermostatHumidity "humidity [%.0f %%]" { insteonplm="32.f4.22:F00.00.18#humidity" }
Everything works except:
thermostatIsHeating
thermostatIsCooling
thermostatBacklight
items that return this when I run openHAB with start.sh:
item (item name here) references unknown feature: (feature), item disabled!
for example. this is how it appears in my log exactly for SystemMode:
item thermostatSystemMode references unknown feature: systemmode, item disabled!
and so on for the above 6 items. Other things like humidity, set point, etc come in fine and are updated. Has anyone experienced this before? Is anyone aware of a solution?
Thanks.
