Hello all, I’m running openhab 2.2 on a pi 3+ and am just getting started but am far enough along that I’ve got a specific question that I can’t find an answer to. I’m running the insteon PLM binding with a USB PLM. Everything is working quite well.
My question is - how do I set up action triggers based on the fastonoff switches? I’m seeing the following lines in my log every time I double-tap my switches:
2018-05-23 21:05:33.303 [INFO ] [onplm.internal.device.MessageHandler] - LightOffSwitchHandler: device 46.B4.48 was switched off FAST.
2018-05-23 21:05:33.316 [INFO ] [onplm.internal.device.MessageHandler] - LightOffDimmerHandler: device 46.B4.48 was turned off FAST.
2018-05-23 21:05:33.335 [vent.ItemStateChangedEvent] - Fastcloset changed from NULL to OFF
2018-05-23 21:06:18.271 [INFO ] [onplm.internal.device.MessageHandler] - LightOffSwitchHandler: device 46.B4.48 was switched off FAST.
2018-05-23 21:06:18.276 [INFO ] [onplm.internal.device.MessageHandler] - LightOffDimmerHandler: device 46.B4.48 was turned off FAST.
2018-05-23 21:07:56.533 [INFO ] [onplm.internal.device.MessageHandler] - LightOnSwitchHandler: device 46.B4.48 was switched on FAST.
2018-05-23 21:07:56.539 [INFO ] [onplm.internal.device.MessageHandler] - LightOnDimmerHandler: device 46.B4.48 was turned on FAST. Sending poll request to get actual level
2018-05-23 21:07:56.550 [vent.ItemStateChangedEvent] - Fastcloset changed from OFF to ON
So clearly the binding is set correctly. How do I turn the “switched on/off FAST” or “turned on/off FAST” to be the trigger on my “when” rule?
Thanks in advance!
