I have an 8 button insteon keypad. When a it receives a signal to turn on one of the buttons it always turns on button A (load) instead of the correct button. (turn on buttonB turns on A). I had this set up and working with OH2.5 under the InsteonPLM binding but can not seem to get it to work under the OH3 Insteon binding now that I have upgraded to OH3. Other insteon devices are working, just not the keypads.
OH3 Item Config:
Switch U_Mbr_Light "Master Main Light" <light> (U_Mbr,Lights) ["Lighting","MBR","FirstInRoom"] {channel="insteon:device:7131daa4:4B53AE:loadDimmer"}
Switch U_Mbr_Keypad_B "MBR Button B" <switch> {channel="insteon:device:7131daa4:4B53AE:keypadButtonB"}
Switch U_Mbr_Keypad_C "MBR Button C" <switch> {channel="insteon:device:7131daa4:4B53AE:keypadButtonC"}
Switch U_Mbr_Keypad_D "MBR Button D" <switch> {channel="insteon:device:7131daa4:4B53AE:keypadButtonD"}
Switch U_Mbr_Keypad_E "MBR Button E" <switch> {channel="insteon:device:7131daa4:4B53AE:keypadButtonE"}
Switch U_Mbr_Keypad_F "MBR Button F" <switch> {channel="insteon:device:7131daa4:4B53AE:keypadButtonF"}
Switch U_Mbr_Keypad_G "MBR Button G" <switch> {channel="insteon:device:7131daa4:4B53AE:keypadButtonG"}
Switch U_Mbr_Keypad_H "MBR Button H" <switch> {channel="insteon:device:7131daa4:4B53AE:keypadButtonH"}
OH2.5 Item Config that was working:
Switch U_Mbr_Light "Master Main Light" <light> (U_Mbr,Lights) ["Switchable","MBR","FirstInRoom"] {insteonplm="4B.53.AE:F00.00.16#loaddimmer"}
Switch U_Mbr_Keypad_B "MBR Button B" <switch> {insteonplm="4B.53.AE:F00.00.16#keypadbuttonB,group=0xf2"}
Switch U_Mbr_Keypad_C "MBR Button C" <switch> {insteonplm="4B.53.AE:F00.00.16#keypadbuttonC,group=0xf3"}
Switch U_Mbr_Keypad_D "MBR Button D" <switch> {insteonplm="4B.53.AE:F00.00.16#keypadbuttonD,group=0xf4"}
Switch U_Mbr_Keypad_E "MBR Button E" <switch> {insteonplm="4B.53.AE:F00.00.16#keypadbuttonE,group=0xf5"}
Switch U_Mbr_Keypad_F "MBR Button F" <switch> {insteonplm="4B.53.AE:F00.00.16#keypadbuttonF,group=0xf6"}
Switch U_Mbr_Keypad_G "MBR Button G" <switch> {insteonplm="4B.53.AE:F00.00.16#keypadbuttonG,group=0xf7"}
Switch U_Mbr_Keypad_H "MBR Button H" <switch> {insteonplm="4B.53.AE:F00.00.16#keypadbuttonH,group=0xf8"}
