I am using OpenHAB 3.0.1 under Windows and have two Insteon questions:
I have an Insteon 2334-222 8-button KeypadLink (which appears to be mislabeled as an Insteon 2334-223 in the Insteon Binding documentation) and I can’t do some basic things with it. Specifically, if I try to change the state of the “Fast On/Off Button D” channel, it toggles the Button A channel (which turns on the load). In fact all Fast On/Off Button X channels do the same thing. Similarly, if I want to monitor the Button D state, I can’t seem to get to make it work. It’s like the buttons are all mapped from Button A.
The Insteon KeypadLink modules are powerful. You have 8 buttons which should each be able to launch events. There are 8 LEDs underneath those buttons which can be set independently. This is what I did in Homeseer. I cannot see any interface to control those LEDs separately in the bridge. For example, in Homeseer, here is an action I can create.
Is the Insteon bridge code in a state where this would be possible. If not, is this something someone is thinking about?
Thank you!
